Fiber optic cables
05-22-2010, 10:17 PM | #1 |
Rep 183
Fiber optic cables
hello everyone, I was adding some XM and amp wires to my z110bt and I noticed that my fiber optic cable was not lighting up like it used too. Let me explain. I have the 2010 335 with the BASE system. The 2 fiber optic cables in the harness, one would always like up as soon as i opened the door or gave power to the car, Now it doesnt. What are the 2 fiber optic cables connected too? How do i test it? Please help, thanks
05-24-2010, 08:31 AM | #2 |
69
Rep 994
i'm not sure what the nearest MOST connection is closest to the amp (i'm assuming that's the harness you're referring to), but i do know that only one and not both should have light coming out of it. the other cable receives light to complete the loop. if you don't have light at all, i suspect that a lot of things wouldn't be working properly. is that the case?
iPhone 6 Plus (iTunes library/iTunes radio/Waze, etc) to Airport Express via AirPlay. Toslink out of Airport Express to Helix P-Six DSP. PHD AF 1.C tweeters, PHD FB 4.1 midranges. Jehnert Door Cards and mid-bass'.
05-24-2010, 12:09 PM | #3 |
Rep 183
I fixed it!!! Thanks mathamatics, don't know why it was, I hooked the original radio back up and it worked, then I just moved it back to trunk hooking up my fiber optic cables I ran and everything worked like a charm
