WHY is cold startup jerky
12-07-2006, 12:06 AM | #1 |
Audi Convert
Rep 362
I know this topic has been discussed. Apparently, the new ECU flash reduces or eliminates this problem. Either I don't have the new flash or there is something else wrong.
NOW here is my question... WHY would the car be jerky at all? Ever? In my short 31 years I have had many cars ranging from an 84 Cutless to an 07 335i, none of them except for the 335i have ever had this kind of embaressing problem at startup and for the following 5 minutes. Does anyone know what the mechanical reason is for this well known problem? Engine warmup? Turbo warmup? Am I being too demanding or should a 40K or 50K run smoothly all the time? Three days after I got the car I brought it into the dealer and they said there was no problem and that I was just feeling the "adaptive transmission" adapt. Then, I did some research and it appears that was a lame excuse. I love everything about my new 335i except for the first 5 minutes of every morning. That pisses me off. |
12-07-2006, 12:30 AM | #2 |
231
Rep 2,366
Drives: 1 M Coupe
how many miles do you have
12-07-2006, 09:57 AM | #3 | |
Expert Road Racer
59
Rep 1,329
You love the brake dust Anyway, take it to the dealer and have the flash done. Your air-fuel mixture is not correct for the warm up period. |
12-07-2006, 11:05 AM | #4 |
Rep 148
According to the TSB it affects cars build prior to Sept 15.
Mine doesn;t do it if I put it in DS mode while cold. It probably has to do with the direct injection. Making an appointment today to have mine reflashed next week.
2007 335I, " Gray", Black Leather, Step, Comfort, ZCW, ZPP, ED - Oct 5, Dropoff Oct 9, redelivery Nov 15.
12-07-2006, 12:15 PM | #5 |
271
Rep 6,510
I'll have to try that DS mode trick... my car actually fully cut out during accelleration yesterday, and it was not the traction control... it was like 20 degrees out, cold start... I have an appointment on the 18th, also getting a free after break-in oil change... once its warm, everything is dandy.
12-07-2006, 12:24 PM | #6 |
27
Rep 290
Here in SLC, I live at the base of the mountains at about 5000 feet. It's routinely 15 degrees outside when I first start her up. I've also have noticed that my car simply starts and runs quite poorly when cold. I have started letting her warm up for about 15 minutes in the morning before I even take off. And then I don't drive faster than about 45mph for the first five miles in the morning. I think any car would have this problem when cold, and It makes sense it would be more pronouced when a car is new and everything is still so tight. Maybe it has something to do with the metal used on the turbo's? Maybe since it can handle such high temps it is challenged when facing such low temps? Just throwing that out there.....
12-07-2006, 01:11 PM | #7 |
Rep 18
12-07-2006, 05:55 PM | #8 | |
The limit of adhesion is my home.
1701
Rep 3,778
2019 X3 xDrive30i Glacier Silver | Cognac w/ Fine Cove | MSport | Premium | Dynamic Handling PKG | Drive Assist | HK w/ Bavsound Upgrade |
12-07-2006, 06:11 PM | #10 | |
Audi Convert
Rep 362
12-07-2006, 06:14 PM | #11 |
Audi Convert
Rep 362
Socalm3,
Under 2000 miles sdiver68, Brake dust does not bother me. It seems every car I have ever owned had more brake dust than anyone else. I have become an expert at cleaning wheels quickly. |
12-07-2006, 07:09 PM | #12 | |
271
Rep 6,510
12-08-2006, 01:16 PM | #13 | |
Expert Road Racer
59
Rep 1,329
