angel eye problem..separate fuses?
05-18-2010, 09:20 PM | #1 |
AC Schnitzel
85
Rep 546
replaced my angel eyes to LED but the drivers side is not functioning at all..i will try and switch around the lights tomorrow and see if it is indeed the bulb (major pain)...but say it isnt the bulb..are there two separate fuses for each angel eye light? if so, maybe one of the fuses blew when the wires crossed and the car was on testing the other light?
05-19-2010, 07:00 PM | #2 |
AC Schnitzel
85
Rep 546
switched the light back to the oem one and still nothing..tried to check the fuses (although not sure i checked the right ones) thanks to the idiot that designed the legend..seems like all the ones i checked are ok...i also get two bulb warnings/errors one reading ccid-193..any ideas?
05-20-2010, 10:47 AM | #3 |
Vorstiener
17
Rep 364
Drives: 07' e90 335
There are different things it could be. If not fuses, it could be the bulb itself, did u check to see if the bulb works in the other housing?
I know I blew my cig lighter fuse during my rixterboost gauge install. Took me awhile to find the fuse with all the weird symbols. Search the forums there will be someone here with the info for you.
| 2007 335 e90 | KW V3 | AR DP | ICONZ | AFE | JB3 | VORSTIENER | MTEC | 3D DESIGN | SNOWS | STETT | FORGED DV | VANGUARD | GODSPEED FMIC | |
05-20-2010, 12:26 PM | #4 |
195
Rep 1,985
What brand/type of angel eyes do you have?
Have you tried swapping it over to the left/right side to isolate the problem? Also, be sure to check for the +/- connection and not get them mixed up |
08-06-2010, 12:28 PM | #6 |
AC Schnitzel
85
Rep 546
i tried to switch the bulbs back to stock and i still get nothing from the drivers side angel eye...i do get a bulb warning on my dash as well but i know the bulb is fine..checked the fuses (or what i think are the fuses) and they all seem to be good..cant figure this out and its really getting to be annoying..
the brand are WeissLicht btw
08-06-2010, 01:58 PM | #7 | |
8246
Rep 18,837
Drives: BMW
This can possibly be reset with the BavTech tool, I haven't tried since we primarly use the autologic.
08-06-2010, 04:30 PM | #8 |
AC Schnitzel
85
Rep 546
hmm thats what i was thinking too..well thanks..btw do you think its a huge deal if i dont switch the lights back to oem before bringing it to the dealer to do that reset? my dealer is pretty good with aftermarket stuff
08-06-2010, 05:16 PM | #9 |
8246
Rep 18,837
Drives: BMW
No, replace the WeissLicht with your OEM bulbs to allow your technician to troubleshoot properly. If the problem happens again - then you know it is related to the kit.
08-06-2010, 08:47 PM | #10 |
AC Schnitzel
85
Rep 546
kk..thanks a lot for the help
08-07-2010, 03:13 PM | #12 |
1313
Rep 2,441
Pop your OEM bulbs in, wait until it comes on, then pop your LEDs back in. There is no fuses from what I know, as Tom@EAS said, the FRM has cut power. This happened to me 2 times before, and I just put the OEMs back in, then waited, both times it came back on.
07-16-2013, 09:25 AM | #14 |
61
Rep 722
Bringing back an old post been searching for something related since yesterday just had the same problem happen with my 135i no response from either new led or halogen however did not leave the halogen in very long i will try this today if not i guess im going to the dealer unfortunately for something so little
11' m57 335d 165k Miles - JR 2, ATM Full Exhaust & Intake, Wagner FMIC, AAR Boost Pipe, AAR Swirl Delete, AAR EGR Delete
08' n54 135i FBO E85 - SOLD |
07-17-2013, 06:08 AM | #15 |
Rep 2
Hi, my led angel eyes of both side (right and left) went out suddenly at the same timing last week and been searching related post too. I haven't tried yet to put halogen back but E90 is time consuming to change the bulb.. need to put off wheels...
Miko226, it would be great help if you could post the outcome. |
07-17-2013, 10:01 AM | #16 | |
61
Rep 722
07-17-2013, 02:02 PM | #17 | ||
118
Rep 1,933
07-17-2013, 02:45 PM | #18 | |
61
Rep 722
07-17-2013, 04:18 PM | #20 |
61
Rep 722
So if I reset it and code comes right back the frm is blown for that angel eye?
08-10-2013, 05:52 PM | #21 |
Rep 12
I had the same problem with my OEM Valeo Angel eyes on my 07 328i. I found that the copper was touching each other and the rubber had dried off. My passenger side lowbeam was out. I then replaced my headlight modules with Halogen LED ones from ANZO. Still the passenger side low beam is out. It looks like an issue with the FRM. How do i reset the FRM? Also, if the resetting doesnt work, how can I replace the FRM if it is short? Where is this FRM unit located (i.e., how to reach there?
