The Tire Rack
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Regional Forums > UK > UK Technical Forum > How to - Replace your Fuel filter
      05-16-2010, 09:12 AM   #1
iamjim
iamjim's Avatar
Austria
157
Drives: BMW M3 F80 CP | DCT | SO | CB
This guide is done on an E90 330d (2005-2007).
Mileage recomendation:
45,000 miles
BMW Part Number:
327793672
Real OEM:
http://www.realoem.com/bmw/showparts...15&hg=13&fg=10
Time required:
1 hour
Tools required:
mini hacksaw
13mm ratchet bit
7mm ratchet bit
8mm ratchet bit
1/4 and 3/8 drivers
flat blade screw driver
T15 torx screw driver
First off, because Eurocarparts have provided me an incorrect fuel filter part (£19.00) - this will not fit. After further investigation it is for an E46 so I will be going to BMW for the correct part tomorrow (£40.00).
So now you have been warned about going for cheaper parts.
But, we can start the guide as the fuel filter will be identical to that of the old one coming off.
Jack car up, The Haynes Manual says to jack up the rear of the car but this is incorrect - jack the front passenger side up.
Place an axle stand under the car at the rear jacking point and I also decided to place one at the front (as shown) because I would rather live whilst my car is damaged (this is not a correct jacking location but secure enough to give you time to get out from under the car) - these M Sports BMWs are low and will crush you if the trolley jack fails.
Once the car is secure, you have to undo the scuttle cover under the car; this is fixed by seven (7) 8mm bolts easily accessed.
Above you can see the fuel filter (arrowed).
Pull the scuttle cover clear (it is hinged by a bracket on the driver’s side) so manoeuvre it off the latch.
Above is the fuel filter (to the right) and pre heater (to the left).
Get under the car proper, if you’re a chubby, good luck with this job as clearance is minimal.
Grab your hacksaw and saw off the fuel supply pipe retaining clip (this is the engine side of the fuel filter NOT the pre-heater side). If the fuel filter has been replaced before then you may be blessed with having a fuel pipe retaining clip with a hex bolt - in which case you can grab your 7mm ratchet bit (or flat blade screw driver) and untighten and remove.
Grab your 13mm ratchet bit and untighten and remove the bolt that holds the fuel filter in place the chassis of the car.
Now grab your washing up bowl (not the one that you do wash up with or be prepared for the missus to start releasing the trolley jack on you) and position in place under the fuel supply pipe...
Pull the fuel supply pipe (red arrow) from the fuel filter - a good tug ( ) will ensure this is done. Be prepared for fuel leakage!
Grab a flat blade screw driver and pull the pre-heater retaining clip out - again be prepared for more fuel leakage.
The fuel filter should now be clear of the car. Remove bracket of filter (T15 Torx screw driver bit needed) and despose off filter.
This is how much fuel was expelled:
About quarter of a pint.
Re-fitting is the reversal of the above with your new filter replacing the sawed off fuel supply clip with a new one with a 7mm hex head.
Once filter is back on car - put the ignition on (key in and hold start stop button for 10 seconds WITHOUT foot on clutch/brake pedals and release start stop button) and wait for 1 min whilst the fuel filter and supplies vents AND then start the car - may take a few cranks.
      05-16-2010, 01:02 PM   #2
Dr Dave
Zummerzet Zyder Drinker!
112
Drives: '06 330D Le Mans Blue
Great write-up, cheers!
      05-16-2010, 04:50 PM   #3
shane55
shane55's Avatar
Ireland
32
Drives: BMW 330d M-Sport Auto
Chaps I noticed on my service history it deesnt seem like the filter was ever changed on mine, with 76K on her now is there a need to do it?
Sapphire Black* Darklines* Black Dakota Leather* Heated Seats* Professional Navigation* Xenons* High Beam Assist* Hi-Fi* USB Audio* DAB* BMW Assist* Sun Protection Glass
      05-16-2010, 07:25 PM   #4
rabble
Drives: e93 330i M Sport
^^^i would
      05-17-2010, 03:06 AM   #5
tmarshall57
tmarshall57's Avatar
56
Drives: F10 530d M Sport, E87 118d M
My understanding (from the service book) is that the air filter and fuel filter should be changed at every 3rd oil change.
F10 530d M Sport, September 2012 Individual Amazonite Silver, Oyster Dakota Leather, Auto, Nav Pro, Bluetooth + USB Devices, Expanded BMW Online, Comfort Seats, Sunroof, Sun Protection Glass Individual Satin Walnut Honey Brown Trim Interior Inside/Outside Mirror with folding and autodip, M Rear Spoiler
      05-17-2010, 04:05 AM   #6
magic77
magic77's Avatar
258
Drives: ex- 335i
it seems its one of the items dealers forget, when I had my E46 (got it with 36k on clock) when I reviewed the history turned out it never got done,
After some irrate calls to the dealer who serviced the car and the time they paid for my local place to change it
F30 335i M Sport - now departed
      05-17-2010, 06:11 AM   #7
iamjim
iamjim's Avatar
Austria
157
Manufactures stipulate that the fuel filter is a lifetime part... But we all know this to be crap. So it is advised to change every 3rd oil change (as someone above stated - my Haynes Manual confirms this too {every 45,000 miles}).
However if you Google “fuel filter change”, you will come across a variety of opinions, but most seem to circle the topic of:
  1. The fuel quality and
  2. If the car is driven frequently
Personally I would change it every year.
      06-27-2010, 03:27 PM   #8
Walesy
24 cans in a case, 24 hours in a day Hmmmmmm
Walesy's Avatar
Scotland
79
Drives: BMW G30 MSport
Are the pic's still available for this thread???? Wondered if you could post them up please??
Thanks!
Present: G30 530D XD MSport
E84 X1 20D LUX
      09-03-2010, 11:45 AM   #9
tlak77
Drives: F30 335i
Nice write up Neversaydie
Can we get pictures back?
It looks like filter part number (Fuel filter cartridge 13 32 7 793 672 ) is the same for 335d, which we have her in USofA; so the thread is very helpful for us too
Thanks
T
2013 335i F30
B45, LCSW, ZMM, ZDH, ZPP, ZTP, 337, 2TV, 428, 494, 688, 6AA, 6AB, 6VA
Flickr
      09-03-2010, 04:32 PM   #10
Giff
Giff's Avatar
Drives: E90
The clip that hold the fuel pipe to the filter does not need to be sawn off, if you look around it you'll find the section where it folds onto itself, it will prise open at this point with a flat blade screwdriver.
Saves you risking damaging your fuel pipe...
      09-13-2010, 01:09 PM   #11
iamjim
iamjim's Avatar
Austria
157
Yeah I see the pictures have gone - that was my fault when I upgraded my web site - I'll get them back ASAP...
As for the saw and the pipe clip it is suggested as best practice to saw the clip with a small coping saw - I had no problems and if you are careful then you shouldn’t either. I did as instructed; I guess likewise forcing a sealed clip which is very tight with a screwdriver could equally cause damage to other parts of the car including the fuel line...
      09-16-2010, 05:56 PM   #12
tlak77
Drives: F30 335i
Thanks for "fixing" the pics
T
2013 335i F30
Flickr
      08-23-2011, 03:43 PM   #13
Najt
No_Country
Drives: e92 325D 2008
no pics!!!!!
      11-18-2011, 07:54 PM   #14
e90drvr
Drives: Graphite/Terra 330i
do you have pictures for this diy? it's the only write-up i've found so far on replacing the fuel filter and the text isn't enough by itself. i'd really love to see how to do this.
let me know if u need help hosting the pics or something.
thanks.
      11-19-2011, 03:46 AM   #15
Giff
Giff's Avatar
Drives: E90
      11-20-2011, 04:55 PM   #16
e90drvr
Perfect. Thanks.
      03-01-2012, 01:06 PM   #17
A_Brummie
Drives: 330d coupe
Did this today, thanks for the writeup.
      05-22-2012, 07:26 PM   #18
GreekboyD
411
Drives: 2009 BMW 335d
2009 BMW 335d  [8.00]
Would this be the fuel filter part# for my 2009 BMW 335d?:
13327793672
http://www.ecstuning.com/BMW-E90-335...lter/ES254301/
      12-15-2012, 10:35 PM   #19
rogerdiaz
28
Drives: 2015 335i
335d
Any 335d owners find differences on install process?
Same location? Same tools required?
      12-16-2012, 03:46 AM   #20
Dr Dave
112
I shouldn't think it is any different.
      01-21-2013, 01:51 PM   #21
Blackbird
Blackbird's Avatar
Drives: 2007 E90 Graphite Metallic
2007 E90  [0.00]
I'm a bit confused. What part is supposed to be replaced as part of regular maintenance? Is it...
1. Fuel filter as shown in this thread, or
2. Fuel Filter/Fuel Pressure Regulator Repair Kit - http://www.ecstuning.com/BMW-E90-335.../Fuel/ES36230/
'07 Graphite E90 | SSTT v.1 | Sprint Booster | Blacklines | PIAA Halos
      01-21-2013, 02:34 PM   #22
Dr Dave
112
The serviceable fuel filter, item 1 in your list.
The second item is inside the fuel tank, usually non-serviceable and there for the life of the vehicle.
