PROGMAN 24.00.00 Released
12-05-2006, 07:02 AM | #1 |
20
Rep 374
Drives: '05 645Ci Coupe
Just to be sure I included the 23.xx items as well
SI B 61 03 05 General Electrical Systems December 2006 Technical Service This Service Information bulletin supersedes S.I. B61 03 05 dated November 2006. (New) designates changes to this revision SUBJECT Software Errors Corrected with Progman MODEL E90, E91, E92 (3 Series) Vehicles produced up to November 30, 2006 SITUATION Customer may complain of the following: (New) The following software errors were corrected with the release of Progman 24.00.00 (Target data Status E89x-06-12-510). 1. PDC (Park Distance Control) stops working if the vehicle stops running when reverse gear is selected and then the vehicle is restarted. 2. The headlight leveling system (LWR) is not working. Fault code "9CB6 LWR coil break" is stored in the FRM (Footwell Module). Coding of the FRM is necessary. 3. CCC (Car Communication Computer): The "dynamic route" SVS (Voice Recognition System) option is missing on vehicles with RTTI (Real Time Traffic Information). 4. There is no check control message when one of the tail light bulbs is defective. Coding of the FRM is necessary. The following software errors were corrected with the release of Progman 23.01.00 (Target data Status E89x-06-09-530). 1. The customer complains that the vehicle bucks slightly under acceleration or when pulling away after a cold start. E90 and E92 with N54 engine produced from 6/1/2006 through 9/15/2006. Refer to SI B12 46 06. The following software errors were corrected with the release of Progman 23.00.00 (Target data Status E89x-06-09-520). 1. The IHKA control panel LCD display temporarily dark during daylight. Refer to SI B64 05 05 for further information. 2. Under certain conditions (sliding visor open and panoramic roof closed) the panoramic roof does not open. E91 vehicles with panoramic roof (SA 402) and produced up to August 31, 2006. 3. The sunroof stops moving approximately 19 cm before the end position during convenience closing. 4. Rear window roller blind does not rewind at low ambient temperatures. Vehicles produced from November 30, 2004 to August 31, 2006. 5. "Check Gas Cap" warning lamp lights up. DME FC "2A17 – DMTL system error" |
12-05-2006, 07:06 AM | #2 |
550
Rep 6,563
I shoulda wait for this had I known they were coming out with 24. Just had 23 programmed for free. however, the bug list does not seems to applied to my car.
under construction! |
12-05-2006, 07:17 AM | #3 | |
51
Rep 921
your car. And it's a certainty if you have iDrive since a bug is expected to be corrected in navigation around March/April timeframe. I know cause I am waiting for it |
12-07-2006, 04:35 PM | #5 |
Freude am Fahren
336
Rep 5,254
Ja, my Sparkling Graphite 330xi is at the dealer waiting for the DVD to arrive with PROGMAN 24. Will report when it's back. Then the Japanrot 3er goes in for PROGMAN 24 upgrade.
Dealer was great, as always. Sent loaner 3er via valet to drop off the loaner and pick up the car. We'll then swap the Graphite 3er for the Japanrot 3er and hold onto the loaner when the first car is done, presumably early next week.
Freude am Fahren.
Jonathan E90 2006 330xi E90 2006 325i E39 2003 530i Sport* E46 2000 328Ci* E36 1996 328iS* E36 1992 325i* E30 1991 318is E21 1982 320iS* E21 1979 320 (6-Zyl)* *retired Nominated: Most Contributing Member |
