The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Tracking, Autocrossing, Dragstrip, Driving Techniques > I went with 265/40R17 all Around
      05-10-2010, 07:13 PM   #1
Mr. 5
Modder Raider
Mr. 5's Avatar
Scotland
753
Drives: M3
2007 e90 335i  [8.00]
Even though people say that the 265/40R17 is too big of a tire for an 8.5" wheel, I wanted to try it anyway. Especially when I find that some sites say that it will fit.
I know that they may look bulgy to some but I think they look pretty good.
I think I decreased the understeer.
One of the reasons why this setup works is because I have the M3 tesnion links and wishbone links installed in the front. This pushed my wheels out to the fender which gave me more clearance on the strut side.
EDIT
Never mind, I guess it doesn't make a difference so this setup will work even with a stock setup.
Here are some pics
e36 M3 Coupe, e36 325i Sedan
e90 335i--SOLD
Best 60-130-------------9.15 Seconds------------------WWW.MR5RACING.COM
      05-11-2010, 01:20 AM   #2
jbass524
jbass524's Avatar
99
Drives: 2011 E90 M3
mmm...more rubber is good. I would love to have 265s but I just don't see 265x18s working.
      05-11-2010, 06:20 AM   #3
marcel b
marcel b's Avatar
132
Drives: F31 340i
Isn't the strut pushed out together with the wheel when you install the M3 wishbone and tenion link? What I knoe the distance from the wheel to the strut doesnot change.
      05-11-2010, 10:42 AM   #4
The HACK
The HACK's Avatar
1821
Interestingly enough, more rubber != good. I was talking to someone running a successful team in SCCA national autocross and also works on a Speed World Challenge team about tires, and what they shared about tire sizes and width will surprise you.
What they told me was, on an autocross course, they were able to drop about a second a lap when they went with a THINNER tire. Originally they were running a 235mm width tire on their 7" wide rim for their Miata. When they switch to a 205mm width tire on the same rim their results improved. And this is a car driven by a national champion with hundreds of hours on autocross courses and their test data does not lie.
Of course, if and when customers ask, they will always recommend the wider tire because it's now a well "accepted" myth that wider tires always work better, and if they recommend a skinny tire it will only raise more questions, and they make a bigger margin on wider tires ANYWAY.
Just some food for thought.
      05-11-2010, 10:45 AM   #5
The HACK
The HACK's Avatar
1821
This. I don't think the E9Xes are on double wish-bone or double a-arm set-up where that could potentially work. I think changing the lower control arm and tension rods only move the BOTTOM of the wheel out, not the top (hence the increased camber).
      05-11-2010, 10:48 AM   #6
marcel b
marcel b's Avatar
132
Drives: F31 340i
sure, it only moves the bottom out, but also the bottom of the strut. so the distance to the strut remains the same... or
      05-11-2010, 08:08 PM   #7
kenneth
kenneth's Avatar
125
Drives: 335i Sedan
These are not 18s, the op mentioned 17s. Actually they look like Kosei K1 painted black
SB, Terra, 6MT. Only a few mods here and there.....nothing extreme!
      05-11-2010, 08:18 PM   #8
FotiosF90M5
///M Specialist South Shore BMW
FotiosF90M5's Avatar
772
Drives: 2021 M5 Comp BHG/Silverstone
I LOVE the bumper...and the fitment looks real good. where did you grab that?
2021 M5 COMPETITION LCI Brands Hatch Gray on SIlverstone, carbon roof, comp wheels, Mperf splitter, carbon pro spoiler, carbon diffuser , carbon paddles, executive pkg. Dinan HAS, RaceChip, dinan spacers, FC stud kit, etc
      05-11-2010, 10:34 PM   #9
Mr. 5
Modder Raider
Mr. 5's Avatar
Scotland
753
Drives: M3
I understand what you are saying but what you are saying may be a completely different scenario.
The main thing about using the wider tires for myself is creating less understeer for myself by putting the wider tires up front.
Going with a square setup is going to provide less understeer. On top of that, going with a wider tire up front will create even less understeer with this car.
I have a feeling that they dropped the second because either they didn't "need" the bigger tire and they were saving weight by using a smaller tire or they changed out the rears to a smaller tire, or... there could be so many possibilities why this happened.
e90 335i--SOLD
      05-12-2010, 01:20 AM   #10
HP Autosport
Supreme Allied Commander
3847
Drives: F80 M3
The distance of the wheel to strut does not change with the use of the M3 lower wishbones.
      05-12-2010, 12:12 PM   #11
Mr. 5
Modder Raider
Mr. 5's Avatar
Scotland
753
Drives: M3
This is good to know.
I thought it did.
e90 335i--SOLD
      05-14-2010, 06:34 PM   #12
m1bjr
LSD - No, you're not seeing things
m1bjr's Avatar
72
Drives: Baby F36 Gran Coupe
I switched to non-stagger on my S2000 for the same reasons.
And the Autocross is a totally different scenario, the little Miata probably just got less rolling resistance from smaller tyres too.
Or maybe it was easier to piroutte around the cones.
A lot of experts will tell you it doesnt work, but on a track or AutoX it will help the turn in significantly.
its not a mod for the noobs though, you switch the grip bias a lot further forward = more oversteer in general.
Most important to add is you WILL get more front roll especially with better R compounds.
More grip = more cornering G = more lean angle.
A good uprated ARB (Torsion Bar??) will keep things in check and switch the bias back towards understeer a little.
HTH
Steve
      05-15-2010, 12:59 AM   #13
The HACK
The HACK's Avatar
1821
Surprisingly the same result and conclusion was reached by the team testing tires for their Speed World Challenge car as well as by research conducted by Grassroot Motorsports, both on the track AND in autocross. That conclusion, wider is better ONLY up to a certain point, was verified by multiple sources.
There are multiple factors involved, of course. The GRM test was done on a Miata too, so a lighter car may be more susceptible to the phenomena. And the Speed World Challenge car that they tested the tires on was, well, a race car gutted and half a ton lighter than the E90.
Just offering some anecdotal evidence that going wider won't always cure your ills. Don't be surprised to see results that are not in-line with your expectations, or actually not being able to achieve the same speed/time on the track with wider tires. It'll probably help, but it's no guarantee.
      05-22-2010, 02:49 AM   #14
jgalaxy
Gearing
jgalaxy's Avatar
86
Drives: E46 M3, F22 M240
Mr 5, have you had a chance to try out the 265s on the track? Better turn in? Better mid corner grip on acceleration or better hold mid corner? Those K1s?
If at first you don't succeed ...
      05-23-2010, 09:28 PM   #15
DrewKo
DrewKo's Avatar
44
Drives: 335i Montego Blue Saddle Brown
2007 335i  [0.00]
Switched to 255's
I switched to 255's on all four corners for purposes of auto-crossing. You can check with the people at the auto-cross events and see their tire widths generally are on the wider side, not the opposite.
I believe comparing an e9x to a miata for purposes of tire analysis is a stretch. I would bet a miata, with its reduced weight, torque, wishbone suspension and lower stance, in contrast to a 335i, probably does not need as much tire width up front. It is probably the case that increasing the width did not add any additional benefit and reducing the width to its minimum necessary to provide for precision turning was sufficient. I wonder if there are any written reports out there analyzing tire width factors? Would be interesting to read more about.
Here is an example of a racing outfit that found larger width of tires in the front reduced understeer and improved track performance in a 135. http://www.evolutionracewerks.com/?q=node/55
      05-23-2010, 09:36 PM   #16
DrewKo
DrewKo's Avatar
44
2007 335i  [0.00]
After making the switch, I have noticed much better rear-tire grip (less skidding under hard acceleration), better turn-in grip but less than I had hoped for, better/quicker recovery after losing grip, and easier recovery, meaning i could better feel where the limits of cornering on the tires were reached. I definitely would not go back to 225s or 235s up front. There is no doubt in my mind that the 255s were an improvement generally for control purposes.
      06-25-2010, 11:04 AM   #17
Mr. 5
Modder Raider
Mr. 5's Avatar
Scotland
753
Drives: M3
I was running 255s all around before and was pleased but I'm going back to Laguna Seca in July with my 265 setup so it's going to be interesting to see if there's an improvement.
e90 335i--SOLD
      06-25-2010, 03:16 PM   #18
chaz58
chaz58's Avatar
15
Drives: 328iT
Bigger isn't always better.
For competition, the important thing is having the tire in its designed operating temperature (typically at least 160, optimium around 200 degrees). naturally you want the alignment and pressure to give you even temperatures across the tread width. You can see why this might be a problem on a miata autocrossing with wide tires - they never get into the tires optimum temperature range. Anything over 195 in a miata is iffy if you are trying to get the tires to heat up quickly.
Keep in mind that a bigger tires doesn't mean a bigger contact patch - it just changes the shape of the patch.
I rotated my 225/255 setup to put the 225's up front (just for kicks). I can't say it really handled any better - I had less turn in grip at lower speeds (autocross like).
_________________________________________________
      06-25-2010, 09:02 PM   #19
jgalaxy
Gearing
jgalaxy's Avatar
86
I'm not sure how the topic got switched to Miatas. Irrelevant to the discussion of going 265 all around on a 335.
Are you saying that you run normally 255 up front and 225 rear and for kicks you switched it around to 225 up front and 255 rear?
      04-02-2022, 11:12 AM   #20
dstevenson
Drives: BMW 1998 M3 Sedan
Kosei K1 Gun Metal
So you must have has these K1s repainted. I would love a gun metal color set.
