TNT Racewerks
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Wash, Wax, Detailing and Cosmetic protection/repairs > Disk brakes "tar"
      05-08-2010, 03:54 PM   #1
mcacciola
mcacciola's Avatar
29
Drives: 09 335i, Silver - M Sport
Disk brakes "tar"
hello; i got a second car recently. A pre-owned Carrera 4 with 30k miles.
Every time I wash the car carefully go to disk brakes for cleaning the same way i do on my Bimmer. The difference is that when I roll back from the yard to the parking spot it drips from inside the disks a black (sometimes brownish/black) sticky residue.
The first couple of times i thought that the car was not well washed so i was running into old residues. So I bought the 3M brake disks cleaner, widely recommended, and I did it 2 times with not much coming out. Now after 10 or 15 washes it keeps coming every weekend. As a note is fare to say that the car is driven by my wife most of the week, no racing or aggressive braking at all.
Question: it could be the drilled shape of disks that hold dust? It could be cheap brake pads? Or is just Porsche normal wear of breaks?
      05-09-2010, 11:40 AM   #2
mcacciola
mcacciola's Avatar
29
wow... 52 views and no clues yet....
      05-09-2010, 12:07 PM   #3
I335
I335's Avatar
123
Drives: '08 335i Coupe
Probably because most of us don't have much Porsche experience. Did you try searching a Porsche forum?
      05-09-2010, 12:25 PM   #4
jopa489
122
Drives: Anything with Wheels
I'm really not sure. You could maybe use a blower to try the brakes after you wash so nothing drips?
X7 LCI // Incoming
C7 ZR1 ZTK // Sebring + TRX // Hydro + Raptor Gen1 Roush // Tuxedo
      05-10-2010, 08:55 AM   #5
mcacciola
mcacciola's Avatar
29
I went to some Porsche's forums and they all suck. Nothing like the way Bimmerpost organize subjects and threads.
      05-10-2010, 04:09 PM   #6
Jeff@TopGearSolutions
Jeff@TopGearSolutions's Avatar
3441
so your saying the rotors (inside) have caked up brake residue that drips after you wash the car?
what a pain that can be...
I would say pull the wheels off and try brake cleaner to get rid of all of it. I'm not sure if that 3m stuff is the same as regular brake cleaner found at any parts store?
Thats where I would start.
      05-10-2010, 05:22 PM   #7
mcacciola
mcacciola's Avatar
29
Yap, that exactly how it looks to be. Greasy, oily, black dark sticky droppings....almost look like old oil coming out of an engine.
I know is a pain, but I guess i will need to take them all off and see for myself whats inside and where....
      05-11-2010, 03:26 AM   #8
TOGWT
TOGWT's Avatar
11
Drives: 630i
Sounds like a normal mixture of brake dust and pad adhesive, rinse with water, apply a wheel cleaner (P21S or Sonax) rinse away debris and dry with a blower.
You could also try ceramic brake pads next ime they need to be changed
      05-11-2010, 08:23 AM   #9
mcacciola
mcacciola's Avatar
29
thanks TOGWT
I'll do some research and go after those products.
      05-12-2010, 11:10 AM   #10
jeffvb9
29
Drives: 2022 BMW x4m comp
Just rinsing doesnt get this stuff off. I get it all the time as well. It takes something very strong to get off and I only know this from basically ruining my wheels clear coat getting it off.
      05-13-2010, 03:30 AM   #11
TOGWT
TOGWT's Avatar
11
Drives: 630i
Agreed-the idea of rinsing is to get rid of any loose residue, the wheel cleaner (like Sonax, P21S) will remove brake dust etc. all as per posting
      05-13-2010, 03:41 AM   #12
MalM3
4 pot warrior
MalM3's Avatar
No_Country
37
Drives: E90 318I
2006 e90  [10.00]
i saw this on a maserati recently also
The perforations in his disc collected brake dust, combined with road grease and gunk made a kind op paste.. strange soft gunk .
I bet this is the crap your talking about
Been there, done that, wanna do it again
      05-13-2010, 05:41 AM   #13
bimbopper
Car Guy for life
bimbopper's Avatar
Drives: '10 E90 328xi
I have owned Porsches for the past 9 years, including a 996 C4S and I have never seen anything like that. I would get it on a lift and take a closer look to see if there is a leak that may be causing this to happen. If it is actually coming out of the inside of the rotors on both sides of the car, I would suspect inferior brake pads, or maybe an issue with the pads dragging on the rotors. If you want a good independent source for some feedback, contact: http://www.pedrosgarage.com
      05-16-2010, 12:21 PM   #14
mcacciola
mcacciola's Avatar
29
It sounds to me that it has cheap brake pads on it. And it happens on EVERY single wheel. So I've take of the table that it could be some sort of leaking.
I'll contact predro's
Thanks for advice and comments.
      05-16-2010, 12:24 PM   #15
mcacciola
mcacciola's Avatar
29
Yap, those perforations are nasty. They also keep the baked dust on it.
Just this weekend I've tried a degreaser combined with regular disk brake pads cleaner and got out some serious stuff out, but at the end it just happened again. Sticky, black tar came out when I rolled out and I have to dry out again with a clean clothe.
Will try next weekend with some of those products mentioned here.
      05-16-2010, 12:26 PM   #16
mcacciola
mcacciola's Avatar
29
Do you guys know if Sonax or P21S could damage the clear coat of the rims? I just want to try the product without having to take out the wheels.
      05-16-2010, 12:48 PM   #17
bimbopper
Car Guy for life
bimbopper's Avatar
Having used P21S wheel cleaners on my Porsche in the past, I can confirm it will not hurt the clearcoat. Now I do not use wheel cleaner anymore. Since I keep them well waxed with P21S after using P21S Gloss Enhancing Paintwork Cleanser, the brake dust comes off easily enough that I can avoid the added cost of wheel cleaners. And I figure one less chemical is better for the environment, too.
      05-16-2010, 04:21 PM   #18
JayKay335i
Egypt
189
Drives: ///M323 DCT
Both are great products. Both are 100% safe. Neither will harm your wheel. p21 is great for every day cleaning. Sonax can handle anything from just a dirty wheel to caked on death tar.
