Software 37.XXXX Discussion
05-04-2010, 11:57 AM | #1 |
130
Rep 5,040
There have been numerous posts (including my observations) that this new version of software reduces the peak and sustained boost in our cars, in stock form. The S/W is applied when you get your HPFP replaced, or as a first step before your HPFP fails (their excuse for not changing your HPFP).
I would like to discuss what everyone's findings are w/ respect to this new software, tuned or not. So does your car feel slower or laggier after the software update? Related Threads http://www.e90post.com/forums/forumdisplay.php?f=2 http://www.1addicts.com/forums/showthread.php?t=375502 Last edited by bulldog_yyc; 05-08-2010 at 03:06 PM.. |
05-04-2010, 12:02 PM | #2 |
1706
Rep 14,829
I think the software would be deployed for any reason, in other words, whenever you need an update, you'll always go to the most current.
With that being said I do think it causes the car to be slower as I got it a week ago. Does that mean it adds longevity? If so, I'll accept it. If it's the difference between being able to drive my car or leaving it in the garage 24/7 indefinitely and having to move it with a flatbed, I'll also take it.... p.s. no hpfp replacement for me and I'm not tuned |
05-04-2010, 12:08 PM | #3 | |
130
Rep 5,040
05-04-2010, 12:11 PM | #4 |
Joint Chiefs of Staff
4920
Rep 115,999
I don't have 37.1 yet but all the logs I've seen from it look normal. Like this one from a customer on map 7. Post up your map 0 and 7 logs for comparison.
Mike |
05-04-2010, 12:26 PM | #5 |
130
Rep 5,040
05-04-2010, 12:29 PM | #6 |
161
Rep 7,377
kinda heard that ALL cars going in for any service work will be getting the newest BMW encrypted software as a mandatory upgrade.
07 335i AT - MOTIV 750 - MHD E85 BMS flash - BMS PI - JB4G5 - Okada Coils - NGK 5992 Plugs - Helix IC - Snow Stg. 3 - Stett CP - Custom midpipes with 100 HJS Cats - Bastuck Quad - PSS10 - QUAIFE LSD - BMS OCC - Forge DVs - AR OC - ALCON BBK - M3 Chassi - Dinan CP - Velocity M rear Toe arms - Advan RZ-DF - LUX H8 - Level 10 AT upgrade
05-04-2010, 12:46 PM | #7 | |
23
Rep 1,179
one will sacrifice for the other -- name one performance - true performance car that doesnt need care and feeding -- not withstanding the fact that cars that are more durable are considerably heavier, have more cylinders and may be considered gas guzzlers. the one exception is a relatively stock japanese car (like my Honda Civic) but what would i rather drive for performance?? my 86 Mustang 5.0LX lasted over 200,000 miles and all it needed was a T-5 tranny and 2 fuel pumps, again that was a 8cylinder car .. and no where near as stable and as fast as my 335 then again i had a small block v-8 Vega that ate fuel pumps and fuel pressure regulators for lunch, now that would kick both the 335 and mustang is the a** .. whats up with that -- it costs to go fast havent had the pump fail (fingers/toes crossed) .. but when it does itll be on BMW's dime .. not mine just my $.02 |
05-04-2010, 02:36 PM | #9 |
30
Rep 1,748
I can't say I noticed much lag after getting mine updated either, I put my tune back in the day i got the car back from service
BMW X5 35i: Boopie Exhaust & Intercooler, K&N Drop in Filter, JB3 (3+ psi) 2013 Dodge Challenger R/T: CAI, Catch Can, Custom Exhaust, Headers, 87MM Throttle Body, Diablo Custom 93 OCT Tune |
05-04-2010, 02:59 PM | #10 |
Modder Raider
755
Rep 8,633
Drives: M3
I didn't notice anything either but i drove to GIAC right after to get my car flashed back.
e36 M3 Coupe, e36 325i Sedan
e90 335i--SOLD Best 60-130-------------9.15 Seconds------------------WWW.MR5RACING.COM |
05-04-2010, 04:01 PM | #11 |
23
Rep 1,179
not gonna happen in the near future... poses a lot of issue unless warranted.. risky to implement and deploy all that software, and dealers only have so many programming stations for this use.. as it can tie up a car (depending on I-Level) up to 2.5 hours.... and there are plenty of un-programmed cars still out there ... so unless needed -- i see/hear no move in that direction..
05-05-2010, 08:39 AM | #13 | |
4920
Rep 115,999
BMW is not going to update your software if you go in for an oil change or a blown light bulb. I have seen cars have to be kept overnight for software upgrade as it didn't take or crashed halfway through. Not something you want to be tying your lifts up with at a busy dealership. Mike |
05-05-2010, 08:47 AM | #14 |
25
Rep 374
Mike any comments on compatibility between 37.2 and JB3? I don't see how a signal modifier wouldn't work with a new software revision-- but there has been some speculation that they are incompatible here: http://www.e90post.com/forums/showthread.php?t=382815
05-05-2010, 08:51 AM | #15 | |
4920
Rep 115,999
http://www.e90post.com/forums/showpo...96&postcount=4 The post you linked to was an older version of the JB3 (1.3) so can't speculate on that but its always best to keep updated as there have been huge advances since 1.3, 1.4 and now 2.0 Mike |
05-08-2010, 04:28 PM | #18 |
Rep 332
had first hfpf replaced 12k now at 21k long cranks again. took it to dealer they said they need to upgrade my soft to 37... took 3 days to get done seemed faster?? after one I was driving on the highway and as I was passing a truck in ds mode after my pass the car shut down into limp mode. back to the dealer.
05-09-2010, 04:04 PM | #19 |
11
Rep 55
Getting my 2nd HPFP replacement at 37k KM and they already updated the DME. They called me saying the software update did not fix the HPFP problem. So now im waiting for the new revised HPFP ending in "943" that has yet to arrive for me to test the new software to see if it lags or not.
05-09-2010, 09:18 PM | #20 |
196
Rep 2,486
had my hpfp replaced and 37.1 installed. The car actually feels a bit quicker and more responsive... And the cool thing is when your tire pressure is low an image comes up that shows you exactly what tire it is !!
05-10-2010, 09:14 AM | #21 |
Back in a BMW
205
Rep 5,208
we recently got the new software and the car is significantly slower than before. BMW refuses to do anything about it though..
Ian
05-10-2010, 07:58 PM | #22 |
Sticky Mess.
Rep 156
Drives: e90 DS 2
I just got my HPFP replaced, and then 37.1 or what I believe to be is, I had Dinan stage 2 tune on the car, and today, maybe its the rain, the car felt a lot slower then what it was. I hope BMW didn't change my car to worthless. I bought the 335 to stay up with m3s, not lose to 128s.
