E92 Cold Start Problem
11-29-2006, 08:43 AM | #1 |
59
Rep 529
Greetings. Out of the blue, my E92 coupe is experiencing extended crank when starting first thing in the morning. I took it to the dealer and they saw some screwed up parameters with fuel pressure and updated with a new software. Unfortunately, the problem is still there. Before I start going nuts, I have a video of the long crank for everyone to see/hear. Is this normal? Surely not because it didn't do it before.
Thanks in advance http://s131.photobucket.com/albums/p...t=MVI_0583.flv http://s131.photobucket.com/albums/p...Picture281.flv Last edited by sbkim; 11-30-2006 at 04:20 PM.. |
11-29-2006, 12:09 PM | #3 |
90
Rep 2,707
I don't have an e92 but try something out.
If you have a garage this would be easier. When you put the key in do you her a the fuel pump going kind of around the rear wheel area? if so wait until it stops and then press the button. If this makes it easier then you basically have an issuer with fuel supply. Again I don't have an e92 so I am assuming it functions similarly as the e46
zhpregistry.net - ZHP stats and free classifieds.
11-29-2006, 01:25 PM | #5 | |
56
Rep 1,962
Peanut Butter Chunky
11-29-2006, 01:49 PM | #6 | |
90
Rep 2,707
but here you can find a ton here http://www.s14.net/photopost/
11-29-2006, 06:50 PM | #7 |
46
Rep 415
Drives: 2015 M5 CP
Interesting coincidence. This afternoon I pressed START and the engine cranked for at lesat 15 seconds. Much longer than in your video. That's the first time this ever happened, and it wasn't even cold outside. It was weird because when it happened, I didn't know what to do. It's not like you can stop turning the key to stop the thing. It just kept on going until the engine started. After it started up, I stopped the engine and restarted, but it started right up. If it happens again, I'm bringing her in.
2015 M5, Alpine White, Sakhir Orange/Black leather, 20"M Style 343M, forged black wheels, Carbon Fiber trim/mirror caps, Competition Package, Executive Package, Bang & Olufsen sound.
11-29-2006, 07:11 PM | #8 |
The 3 Day Diet!
19
Rep 630
Drives: Space Gray e92, 88 911 Cab
sorry but that m3 is uglee
11-30-2006, 04:20 PM | #9 |
59
Rep 529
Updated video - problem is now getting worse. I have another apointment with field rep.
http://s131.photobucket.com/albums/p...t=MVI_0583.flv |
11-30-2006, 05:50 PM | #11 | |
13
Rep 122
2006 E90 325i, Titianium silver, 6MT, Black interior, Aluminum trim, ZSP, ZPP.
11-30-2006, 06:15 PM | #12 | |
31
Rep 460
2020 M2 comp, 6mt, Hockenheim Silver, blue stitching, premium, STEK paint protection, 20% tint
2008 e92 335xi 6mt, Montego Blue, Jade Grey, Grey Poplar, Sport, Cold Weather, Comfort Access, KW V3s, M3 spoiler, 35% tint, 3M clear bra, GP Thunder H8 2007 E92 335i* 2003 E46 330Ci* 1994 Ford Probe SE* *Retired |
11-30-2006, 08:29 PM | #13 |
Rep 156
maybe you should have your car towed in. if the car needs to be cold to do that, driving it to the dealership and restarting it may not work.
11-30-2006, 08:40 PM | #14 |
***** noob
1370
Rep 10,479
Drives: 325xi>M235i>428GCx Mspor
sbkim.....try this out
when you hit the start button, do NOT just tap on it...hold it for 2-3 seconds, works everytime for me This is related to the ethanol in the USA gas.....we have discussed this topic before.... http://www.e90post.com/forums/showth...hlight=ethanol Will Using Fuel Mixed With Ethanol......... Using a fuel that contains up to 10% ethanol will not harm your vehicle. However, there are a couple of things to be considered. First, under some conditions (usually low temperatures) ethanol separates from the gasoline-alcohol mixture and absorbs water. The ethanol absorbed water is heavier than gasoline or ethanol and settles at the bottom of the fuel tank. When introduced into the combustion process, this leads to an extremely lean fuel mixture and can result in misfires, rough idles, and cold starting problems.
2006 325xi (Sold)
2014 M235I (Current) 2015 428xi Gran Coupe (STB) |
11-30-2006, 10:03 PM | #15 |
274
Rep 6,510
Shiv mentioned that one of the cars that he tuned with the XEDE had an extended cranking... he thought it was something from the software update.
Here is that post... http://www.e90post.com/forums/showpo...6&postcount=37 maybe he has some thought on this issue? I dont think he ever found out if it was a pre-existing condition, or something after the software update... |
12-01-2006, 09:11 AM | #16 | |
59
Rep 529
12-01-2006, 09:16 AM | #17 | |
59
Rep 529
12-01-2006, 09:25 AM | #18 | |
Rep 22
12-01-2006, 09:33 AM | #19 | |
274
Rep 6,510
Sorry to hear about you problem, i know i would be pissed if my car sounded like that when it started... I would be nervous to start it around people... |
12-01-2006, 09:37 AM | #20 | |
630
Rep 1,649
Umm, considering your choice of avatar, I'm going to go ahead and disregard your comment. E30's are one of the, if not the best looking BMW's ever made. End of story.
On topic - I have not noticed extended cranking with my 335, but I do notice a slight miss at idle even when its warm. Very reminiscent of my E30. My previous e46 and e36 were smooth as silk. Quote:
12-01-2006, 10:22 AM | #21 |
95
Rep 1,018
Drives: 2014 BMW M5
that sucks! keep us updated when u know what the problem is.
