N55 versus N54 Dynos
04-28-2010, 01:08 PM | #1 |
Joint Chiefs of Staff
4912
Rep 115,980
A few of you were asking for this so I had BMS put a dyno graph together for you guys Both cars were run in similar conditions and both on Shell 91. Runs were both started around 2000-2200rpm.
Overall power is similar but from what I am told the N55 seems to suffer from a bit more lag. No idea on the potential of the N55 yet as BMS is just beginning the groundwork. There are some more details in my other thread. |
04-28-2010, 01:54 PM | #4 |
22
Rep 1,211
04-28-2010, 02:18 PM | #5 | |
654
Rep 10,587
there is the question, obviously both of these dyno's are on very restricted motors. Lets see what the n55 can do properly modd'd before any comparisons can really be made. my big question, being that its already a single turbo setup, is there room for a larger snail down there now?
04-28-2010, 02:40 PM | #7 |
Modder Raider
753
Rep 8,633
Drives: M3
This looks good.
The biggest thing I can see helping right away is developing a DP to get rid of that huge cat!
e36 M3 Coupe, e36 325i Sedan
e90 335i--SOLD Best 60-130-------------9.15 Seconds------------------WWW.MR5RACING.COM |
04-28-2010, 02:53 PM | #8 | |
Rep 320
04-28-2010, 03:24 PM | #10 |
313
Rep 3,262
It would have to be twin-scroll...or not ? I wonder if a classic single turbo can be fitted instead of the twin-scroll ?
04-28-2010, 03:37 PM | #11 |
324
Rep 2,663
Drives: BMW 335xi Sedan; BMW M3 ZCP
Looks like both these motors can handle well above 7K RPM
335xi Sedan 6AT | Weather(70-85°F) | N54 Tune Comparison Chart || N54 Turbo Upgrade Comparison Chart
-PROcede Rev. 2.5 ~ v5 (3/17 maps) / JB4 (8/21 maps) / COBB (Stg2+FMIC LT Aggressive maps) †Procede Map2(UT 45 - IGN 40) Aggression Target 2.0 | 0-60 in 4.0sec || †Cobb E30 LT (35% Ethanol/65% 93 Octane) | 0-60 in 3.9sec AR Design Catless DP | BMS DCI + OCC | ETS 5 FMIC | Alpina B3 Trans Flash |235/265 19" Michelin PSS |
04-28-2010, 03:52 PM | #12 |
254
Rep 1,391
04-28-2010, 03:52 PM | #13 |
254
Rep 1,391
04-28-2010, 04:06 PM | #15 |
313
Rep 3,262
No. One single-scroll instead of the stock twin-scroll. It's feasible in theory, the only problem is the mixing of the 2 exhaust paths and the 2 intake paths which somewhat negates the lower lag of the twin-scroll setup. It's kind of like the single-turbo upgrade for the N54 planned by HPF: it mixes the two intake paths, and the two exhaust paths.
04-28-2010, 04:38 PM | #17 |
53
Rep 488
04-28-2010, 04:43 PM | #18 |
333
Rep 4,632
Take these comparison with not being 100% dead on since the N54 dyno was done over a year ago.
Such little differences can be off set easily in diff. temps in the dyno and fan quality. |
04-28-2010, 07:40 PM | #20 | |
654
Rep 10,587
for example here is a sc61 which is a mid sized journal bearing, not even DBB on a s52 running pump gas. This is a sweet powerband. Put a turbo of this size but with DBB and billet wheel and you'll see a hell of a fun 335 or 135 to drive. Yes you wont have the 2,000rpm performance, but all you need to do is downshift and keep the revs above 3,500rpms and you have a rocket. Much like my car when it runs lol....I have full boost by 3100rpms or so w a gt35r. as a note, if the rpm pickup was accurate this run was let off a good 1,000rpm before redline where maxHP would have been seen.
04-28-2010, 08:20 PM | #21 |
129
Rep 1,629
There are plenty of larger snails that are twin scroll. Check out the selection over on ATP Turbo: http://www.atpturbo.com/
To help lag you can can go to a ceramic compressor/turbine wheel and a ball bearings.
Cars>Women
04-28-2010, 08:44 PM | #22 | |
654
Rep 10,587
