Faults for 2FBF DME: Release on Injection
04-23-2010, 04:23 PM | #1 |
126
Rep 1,419
I took my 4,000 miles 2010 335I to the BMW dealership yesterday because of extremely long cranks and told them I thought it was a sign of HPFP failure. They kept it over night and I got back my service receipt today....
They didn't replace the pump instead they diagnosed the cause of long cranks as "Reprograming: Interrogating Fault Memory in Diagnosing" Also on bottom of receipt it say "Found faults for 2FBF DME: Release on Injection" Anyone know what all this means?
'10 E92 335i|Le Mans Blue|Black Dakota|Light Burl Walnut Trim|Premium|///M-Sport|Steptronic|I-Drive|Comfort Access|
04-23-2010, 04:43 PM | #2 |
126
Rep 1,419
Got to love BMW, I turned the car on and got "SOS Call System Manufacturer" Message so I had to leave the car...
0 for 2 BMW
04-23-2010, 04:54 PM | #3 |
45
Rep 1,754
04-23-2010, 05:11 PM | #4 |
126
Rep 1,419
So why don't they check after they reprogram instead of calling me, telling me my car is ready only to discover I have to leave it again...
I got a 3.5L Dodge Charger the first loaner now a got an X3, I don't which is worse they both accelerate and handle like Sherman Tanks My stealership RARELY gives BMW loaners but shouldn't they do it everytime? It seems like when they run out of crap loaners (avengers, neons etc) they will part with a BMW
04-23-2010, 08:41 PM | #5 |
Rep 48
Some long cranks have now been solved by this software update.
If issues or faults continue and the HPFP has pressure issues they will replace.
04-23-2010, 08:44 PM | #6 | |
45
Rep 1,754
I know, I know, the SOS thing is different, but they STILL don't check. However, you don't have to take it back -- it's not malfunctioning, it just lost its connection to the database. Call BMW assistance on your cell phone from the car and they will walk it through and get you working again. You don't need to go to the dealer. |
04-23-2010, 08:51 PM | #7 |
485
Rep 10,309
Drives: A///MERICAN!!!
Get a new dealer
04-23-2010, 10:12 PM | #8 | |
45
Rep 1,754
However, my favorite re loaners is the independent shop I took my M3 to in Berkeley -- used to get modded cars a lot, an 80's M5 once, etc. Basically, whatever they had in the back lot of the shop at the time. |
04-23-2010, 10:34 PM | #9 |
Rep 117
No Long Crank But Sloppy Shifting
BEWARE Took my 335 because long cranks and they reprogram to 2.37.1 , if you can AVOID this program. It will turn your automatic gearbox into a old honda civic, shifts will be verryyyy soft and delayed, not the sporty shifts you are used to your car. I complained and the dealer says that the new software indeed takes care of the long cranks, but that does not mean your pump will fail. The new program supposedly helps the pump fail less, so I guess this is a patch from BMW to avoid so many fuel pump replacements. I regret taking the car to the dealer, now they say they can not revert back to the old software. I prefer a thousand times a ocassional long crank than the sloppy transmision shifts. Good Luck
335I, ZSP, Monaco\Saddle paddles,CA,PRS
ED Drop Off, Zurich, Oct 30, REDELIVERED DEC 29 '06 |
04-24-2010, 12:48 PM | #10 | |
45
Rep 1,754
04-24-2010, 11:41 PM | #11 |
Thats all you need to know.
43
Rep 1,188
+1 new software did nothing different to my trans.
- M2 2018 LBB / Black
- X5 F15 2016 Mineral White / Black 1981 Delorean number 6489 |
