When DTC is OFF I can't launch straight ahead
04-23-2010, 03:59 PM | #1 |
620
Rep 2,013
Today I was practicing before going to the 1/4 mile drag strip on Sunday.
My car is a 335i AT and when I switch DTC all the way off I can't launch straight ahead. My car always goes to the right that much that I am afraid I can hit a car on the other lane. If I press the DTC button just once and the DTC sign shows up on the dash everything is fine. You can see my mods in my signature. They include an LSD. What can be a reason for this ? I have read that it is better to turn the DTC off to achieve better times, so I am worried my times will not be that good. |
04-25-2010, 12:46 AM | #2 | |
Supreme Allied Commander
3847
Rep 54,376
Drives: F80 M3
Rear subframe deflection can cause the car to steer left or right when power is applied. The fix - M3 subframe bushings. Couple of other component to consider is the M3 guide rods, it takes away a rubber bushing and replace it with a bearing with almost no deflection at all. The last piece of the puzzle is a toe links. Toe changes will cause the rear of the car to steer. |
04-25-2010, 10:51 AM | #3 |
95
Rep 1,476
this one time at the strip, I had all nannies off. I was in the left lane. I launched then all of a sudden, I was in the right lane. Thank goodness the car I was heads up with was way quicker. Also, thank goodness I wasn't in the right lane.
It could have been expensive. I don't think I've been back to the strip with the e90 since. |
04-26-2010, 06:52 AM | #4 | |
620
Rep 2,013
Thanks Harold. I will have to seriously consider upgarding my rear suspension. |
04-26-2010, 06:54 AM | #5 | |
620
Rep 2,013
