High octane fuel
11-26-2006, 05:05 PM | #1 |
The limit of adhesion is my home.
1702
Rep 3,778
High octane fuel
The recommended Octane for our cars (US side) is 91 octane (or 93). There is a gas station near my house that sells 102 octane gas. Is it a bad idea to put it in or will the ECU automatically adjust to this fuel type? The last thing I want is the engine running too lean and detonating.
2019 X3 xDrive30i Glacier Silver | Cognac w/ Fine Cove | MSport | Premium | Dynamic Handling PKG | Drive Assist | HK w/ Bavsound Upgrade |
11-26-2006, 05:07 PM | #2 |
Rep 229
i am not sure about you question but i have my own:
Do you have to use 91 octane or higher, can you use Mid-Grade gas? or even Low-Grade?
Ordered: 2007 328i Sedan/ Montego Blue/ Beige interior with wood trim/ STEPTRONIC/ Sport package/ Premium Package/ Cold Weather Package/ Comfort Access
Comes in January |
11-26-2006, 05:13 PM | #3 | |
BMWCCA/NASA
24
Rep 471
Drives: E92 Coupe ZP/ZS/Dinan ECU+Exh
07 335 Coupe ZP ZS DinanECU+Exhaust
06 330I (retired) 97 M3 (retired)Dinan Stage 1 01 XK8 Conv 98 Navigator 99 M3 (race car)IP,PS1,and CR-3 |
11-26-2006, 05:16 PM | #4 |
United States Marine
318
Rep 2,748
if you use anything below 91 your DME (digital motor electronics) will retard your timing to avoid knock, and you will lose a LOT of HP. VERY noticable loss.
102 will make your car run better, faster, and get better mileage, except you'll have your foot in it all the time, so your mileage will go DOWN. lol. The problem with 102 is that it will wear out your Catalytic Converters more quickly. How much more quickly? can't say. but it will. |
11-26-2006, 05:29 PM | #5 |
318
Rep 2,748
Forgot to mention... you probably won't notice ANYTHING on your first tank of 102, unless you reset all the fuel trim adaptations at the dealer. Otherwise, it will take a couple tanks for the car to figure out it's a badass. =)_
11-26-2006, 05:35 PM | #6 |
335
Rep 7,719
on stock ECU, that high of an octane wouldn't do much good for the car.
A lot of my friends use c16 or 100+ octane gas when racing to go with race maps on their ECU. This helps shorten the 1/4 mile time down a bit, but since you are stock, it won't do much good. And let me take a guess, is this gas station happen to be a 76 by anychance? lol. |
11-26-2006, 05:42 PM | #7 |
Rep 229
so mid-grade is okay, and low-grade is a definent no-no
Comes in January |
11-26-2006, 05:43 PM | #8 |
318
Rep 2,748
anything under 91 is a no no. don't do that to your BMW bud. it's not a toyota.
Also... wj4.... You're wrong. I'm sorry to say, but you're wrong. I've tried high octane gas. It's a real benefit. i mean REAL. like about 20 hp real. I'm not kidding, or making it up. Again, I'm talking about putting high octane in and then resetting the DME adaptations, not just putting it in and driving. |
11-26-2006, 06:03 PM | #10 | |
Rep 21
http://www.cars.com/carsapp/national...odaysgas1.tmpl |
11-26-2006, 06:06 PM | #11 | |
335
Rep 7,719
100 octane isn't worth it if your car isn't prepped for it IMO. Just look at Shiv's post about his tuning in Canada where they have 94 octane, and compared his dyno result to his own car with Cali's inferior 91 octane. There's a reason why they sell high octane gas at LACR and other race tracks |
11-26-2006, 06:11 PM | #12 |
30
Rep 156
I wish that were the case
Unfortunately in this car, you will not gain any measurable HP with the higher octane. Believe me I wish this were true, but 20 years of racing everything from shifter karts, motocross, superbikes, to scca formula ford events has shown that the stock ECU's will not compensate for higher octane, the sensors(used to be knock, now are straight up timing) are unilateral, the ECU does not have the programming to detect higher octane and therefore compensate, bear in mind that the ECU does not have the parameters to advance the timing beyond factory only retard. Now that being said, if you look at any race vehicle(2 or 4 stroke), no one uses factory ignitions(for older low tech engines) or ECU's. I just recently went through this on a 5 valve yamaha engine in which I increased compression throughout the range, ported and polished the heads, and reprogrammed the ECU, all of this then requires me to run VP110 fuel, if gains could have been made with simply running higher octane without modifications, every R1 out there would do it. Again, once you start tweaking the engine, you benefit from the higher octane(although more accurately you require it), but I defy anyone to show increased wheel horsepower with simply increases the octane and nothing else. Of course you could have Shiv chime in and talk about how he tuned the 335's and see what he did with required fuel, but I am betting he'll say the same thing, he'll give you the best performance based on what fuel you say you're willing to run, not the other way around. If you speak with Dinan as well, they used to do custom programming for the old M3's for GT events and you would tell them what the spec fuel was for the class or specific event and they would tune the car for that. Now, one concession I will make is with regard to the recent ongoing reports of fuel coming in sub-spec on octane levels at the pump, and if you are buying 91 and only getting 89/89.5, and then you run a race gas, you will feel the horsepower, not because the extra 8 points of octane are benefitting you, but because you were not getting the minimum required to begin with. I'm in SE PA, and I stock GT100 gas for one motorcycle and one shifter kart, as well as VP110 for a moto, if anyone is interested in trying it on the dyno. I said if anyone is interested, because without witnesses, the forum will light up with people disputing the results! Best of Luck.
11-26-2006, 06:17 PM | #13 | |
45
Rep 1,738
2006 325i - Sparkling Graphite
2000 S2000 - New Formula Red 2007 Chev Silverado crew cab Z71 |
11-26-2006, 06:23 PM | #14 | |
45
Rep 1,738
11-26-2006, 06:32 PM | #15 | |
Texas
311
Rep 769
From HowStuffWorks.com - http://auto.howstuffworks.com/question90.htm
Other cool links - How turbochargers work - http://auto.howstuffworks.com/turbo.htm How to increase the HP of your car - http://auto.howstuffworks.com/question395.htm |
11-27-2006, 12:53 AM | #16 |
1702
Rep 3,778
Glacias......glacias everyone.....mucho greato informacion!!!!!! Thanks so much!
11-27-2006, 02:57 AM | #17 |
15
Rep 187
Here in Europe BMW manuals say that BMW engines are made for 98 octane fuel (ron) if you use 95E usually the lowest oct. we got, then you'll experience power loss and higher fuel consumption.
There was a test in a Swedish magazine(Teknikes Värld) between BMW 130 (claimed 265hp) and a Audi A3 Sportback 3.2 quattro (claimed 250hp). They also tetsted the cars with different fuels. The Audi was brought to the test with 95E in the tank while BMW had 99E in the tank. Well the Audi gave 219hp with 95E with 98E 248hp. BMW 265hp with 98E and 272hp with 99E. Here,s some result's from the test. Audi BMW 0-50 km/h 2,55 2,53 0-100km/h 6,54 6,40 0-200km/h 29,14 22,46 402m 14,76 14,39 402m 154,80 163,68 km/h Last edited by Convertible; 11-27-2006 at 04:20 AM.. |
11-27-2006, 05:42 AM | #18 | ||
571
Rep 7,519
Drives: 2009 E90 335i MT
2009 E90 335i Montego Blue · Black Leather · Burl Walnut · 6MT · US Spec
SatNav • ZPP • ZCW • 6FL • TPMS • iDrive • PDC • HWS • Xenons • BMW Assist • Power Rear Sunshade • Logic 7 European Taillights • Rear Foglamp • OEM Alarm • PicoTray • DataToys XM-DVR • Multi-view Processor Quaife ATB LSD • Short Shift Knob • Hartge Anti-Roll Bars • AP Racing Front Brakes • 19" Style 269 |
11-27-2006, 07:09 AM | #19 | |
BMWCCA/NASA
24
Rep 471
11-27-2006, 10:11 AM | #20 |
Rep 178
In Spain I'm using 95 octane -BMW reccomends here 95 to 98- and the car runs
ok. I'm going to do a few 98 fill ups and see if I can feel any difference.
[IMG][/IMG]
11-27-2006, 08:48 PM | #21 | |
576
Rep 6,750
11-28-2006, 09:15 AM | #22 | |
41
Rep 683
+1 Totally agree ... spot on.
2010 E90 335i M-Sport, 2005 E90 325i M-Sport, 2003 E60 520i, 2002 E46 330i Sport II, 2000 E46 325i Sport I, 1999 E46 318i, 1998 E46 323i SE, 1996 E36 323i SE, 1996 E34 518i, 1995 E36 320iA, 1994 E36 316i
