UGH!!! Again!!
03-31-2010, 01:52 PM | #1 |
75
Rep 515
UGH!!! Again!!
bump
2013 F10 BMW 535i Alpine White / Oyster Dakota Leather / Anthracite Wood Trim / Steptronic transmission / M Sport Package / Premium Package / Technology Package / Rear-view camera / Park Distance Control
03-31-2010, 02:31 PM | #3 |
75
Rep 515
bump
03-31-2010, 02:45 PM | #5 |
119
Rep 2,312
I would think BMW's in general.
I can't remember the specifics, search it... alot of people have their racks replaced. I remember having it done on my old volvo too...it never drove the same way again. Its never as good as it is from factory. |
03-31-2010, 03:02 PM | #6 |
75
Rep 515
bump
03-31-2010, 03:23 PM | #7 |
21
Rep 582
I don't have the same problem. From time to time if I'm driving on a rough road, my car will want to track the imperfections in the road, but I believe that's probably the tires. On most roads my car tracks just fine.
03-31-2010, 03:36 PM | #9 |
55
Rep 1,495
I'm with you...If the road is perfectly smooth, my car drives like a dream and seems like it would drive straight indefinitely, but as soon as there is ANY imperfection in the road the damn thing goes haywire and wants to follow it all over the place. I have wondered if it's a byproduct of a staggered setup. BTW, I'm on OEM RFT's.
04-02-2010, 10:45 AM | #10 |
75
Rep 515
bump
04-02-2010, 11:33 AM | #12 |
3597
Rep 10,358
You didn't mention whether you have sport pkg, but if you're running wide/low profile tires this is the cost of admission. Also don't forget that many roads are paved with a crown going down the middle of the road for drainage purposes. I've heard that some car's have their alignment done to help compensate for this, but not all, and there are always trade-off's with that setup.
04-02-2010, 11:34 AM | #13 |
12
Rep 96
Try shifting to a non-staggered tyre formation and see if you have the same issue.
My winter setup is 225/40 all around, and the car drive much straighter, than when it's on the staggered setup. The problem you're facing is a common for all staggered setups - it's pronounced on concrete roads, compared to tarred roads. |
04-02-2010, 05:25 PM | #15 |
75
Rep 515
bump
04-02-2010, 06:12 PM | #16 |
342
Rep 1,325
On my E36, the difference is night & day between 225mm summer performance tires and 185mm winter tires or even 205mm all-seasons.
http://www.tirerack.com/tires/tirete....jsp?techid=47 The summer tires "tramline" VERY noticeably. You need constant correction to keep the car straight. Pretty much all paved roads have both a crown and minor "ruts" caused by years of traffic. Wide, summer tires follow these. You mostly need to hold left correction on the wheel as the tires want to follow the crow "down" (right) into the curb/shoulder. I noticed it at it's worst when braking firmly at an intersection (like for a yellow). You really have to hold onto the steering wheel to keep it going straight. It's just the price you pay for having wide, summer tires. When I put on my winter tires for the season the car tracks almost perfectly straight. Very little tramling and the steering resistance is nearly cut in half. Like I said, absolutely night/day. I'd suggest finding someone with a set of 17" wheels with all-seasons and see if you can mount them for a little drive. |
04-02-2010, 06:49 PM | #17 |
256
Rep 1,040
Quick Fix
If you are running larger than 17" wheels then the quick fix is to add more postive toe on the front wheels. This will force the car to track in a straight line but you will lose some of your crisp turn ins.
When I was on the track I would add a touch more toe and caster to the front wheels when running with a large negative camber. Car would track straight really well on the high speed straights and the negative camber let me carry more speed into the turns. The only loss was I had to really crank the wheel hard in sharper turns. |
