leatherette stain plz help!!!
03-23-2010, 09:28 PM | #1 |
22
Rep 176
ok... black leatherette. yesturday i bought some ready made food (singapore fried noodles) and the oil is bright yellow after cooked. it spilled out of the box on the seat, not knowing till the next morning. the seat is now stained with a green spot. it huge!!!
i have tried rubbbing as hard as i could with water already, and nothing comes off..... what can i buy/use to get this off. thanks Last edited by max_asdf; 03-25-2010 at 09:12 AM.. |
03-23-2010, 10:45 PM | #2 |
Rep 208
It might not be a stain.. it's possible that there was some sort of chemical reaction that change the color of the seat or completely ripped off the color... Just a guess though..
03-24-2010, 03:30 AM | #3 |
35
Rep 458
leatherette is tricky. my old 328i had leatherette. one time i came out of the ocean and sat in my seat in 100 degree cali wheather. i wasn't wet, just maybe moist, but it stained the shit out of the leatherette. be careful.
03-24-2010, 09:15 AM | #6 |
Mastermind
71
Rep 1,360
you deserve it for treating your car badly.
anywho, try AMODEX STAIN REMOVER or http://www.spinneybeck.com/Shop/Prod...t.aspx?type=MK |
03-24-2010, 11:29 AM | #7 |
79
Rep 1,073
Try to contact BMW first for Ideas.
I'd try a paste of water and baking soda first and gently rub. Try a sample first somewhere else. This could pull some of the oil out IF that is what his causing the discolor. If it is a chemical reaction find out what it is that is causing it. Was it the acid from a citrus ingrediant? Maybe Patience should be applied. Once clean give it time for perhaps the active ingrediant to wear off and maybe the color will return to normal. Make a few calls to who made the noodles and what they used, and to BMW. |
03-24-2010, 11:54 AM | #8 |
22
Rep 176
i doubt the color is ripped off the seat as i can still see black under the green.
i can only see the 'green' under the sun or with a bright flashlight, under not so bright lights, the green is not really visible. ive tried mr clean magic eraser earlier today, and it was no use. what can clean acid? does anyone know if dishwasher soap will work? because ive tried dishwaher soap on the plastic container the noodles came with and the yellow stains seem to come off, not totally, but somewhat. if i purchase a vinyl cleaner, will it do the job? edit: will an interior detailer be able to fix this? my car is due for an interior clean anyways. |
03-24-2010, 12:10 PM | #9 |
2286
Rep 12,565
Drives: Z4 M, X5, GX460
sounds stupid but i'd ask a good dry cleaner
03-24-2010, 12:10 PM | #10 |
2286
Rep 12,565
03-24-2010, 01:01 PM | #11 |
25
Rep 691
Don't use harsh chemical like brake fluid, it may do more harm than good, you don't want to risk ruining your seat, try this, believe it or not, left it under direct sunlight, it will get rid of the stain.
03-24-2010, 03:47 PM | #12 | |
Rep 291
Drives: 2008 328i, with 3 pedals
If those were Sing-chow noodles, what you have is a turmeric stain (that's the spice that gives it it's color). Turmeric is difficult to remove and you must act on it right away or it becomes permanent. Do a search on "how to remove turmeric stains" and you will get several hits with useful information. Here's one, as an example: http://www.ehow.com/how_5132224_remo...ic-stains.html Good luck, you've got a tough one there! Regards, Adnan |
03-24-2010, 03:56 PM | #13 |
Rep 303
DO NOT use nail polish remover; it may melt the vinyl.
ElRedOne
330 xi Electric Red/Beige Step-Premium-Sport-CW-CA-PDC-Shade Z4MR Interlagos/Black |
03-24-2010, 04:04 PM | #14 | |
26
Rep 144
Zaino leather cleaner and conditioner. I know it's not leather, but try it. that stuff is fantastic. |
