Headlamp alignment at start-up?
11-08-2006, 09:24 PM | #1 |
15
Rep 575
I've noticed that when I plug in my key fob at night (with the headlights set to automatic), the beams do a little dance - first moving up and then down to a set level they then stay at. Is this normal? From outside, it probably looks kinda cool (unless you're being dazzled). The beams are straight ahead as the wheels are not turned (i.e. this doesn't seem to be the adaptive effect on cornering). Perhaps the lights auto-re-align at start-up?
11-08-2006, 09:31 PM | #4 | |
15
Rep 575
11-08-2006, 09:34 PM | #5 | |
pull my finger to get your kinder® surprise
148
Rep 10,455
uh, no, if the car was on an incline, it would point towards the road up ahead, a non self-levelling headlight would point to the sky if you think about ti
11-08-2006, 09:55 PM | #6 |
27
Rep 520
Drives: 2012 F30
Garage List 2012 BMW 328i [10.00]
(retired) 2009 528i [10.00] (retired) 2006 325i [10.00] (retired) 2002 325ci [10.00] |
My old e46 xenons did the same thing.. A very cool feature, kinda feels like having pop up headlights...
2012 F30 328i, Melbourne Red, Premium, Sportline, Steptronic, Xenon, Harmon Kardon.
11-08-2006, 10:24 PM | #7 |
33
Rep 403
They use to self check together, but now the driver goes first then the passenger.
In the Garage '10 E70 X5d Alpine White LOADED UP - '10 EVO X Wicked White
RIP '08 BMW E60 535i - '06 BMW E90 330i - '05 Acura EL - '98 Honda Prelude - '99 Audi A4 - '02 Honda Civic - '06 Nissan Xterra |
11-08-2006, 10:42 PM | #8 |
Rep 309
From e92 US brochure, page 46: "The dynamic auto-leveling feature adjusts for varying passenger and cargo loads, helping to keep headlight glare out of the eyes of oncoming drivers."
I only wish all cars with super bright headlights did this. Those high intensity lights are dangerous to other drivers at night. I'm sure we have all experienced a blinding by some kid in a Honda modded with Xenons that aren’t properly adjusted. |
11-09-2006, 08:28 AM | #9 |
Rep 115
It's normal, what isn't normal is what happened to me a week ago.
The headlight on the driver side didn't adjust it's level anymore, actually it did but it started pointing up A LOT. I could see trafic signs a mile away and was blinding just about every driver. Took it in and they updated the software since it was a software error. 2 days later...problem came back. It's back in today so I hope they will fix it. |
11-09-2006, 08:31 AM | #10 | |
Clutch pedal >> Dead pedal
18
Rep 709
Drives: '11 e92 335is 6MT
Related part for e90 330i: http://www.realoem.com/bmw/showparts...=31&fg=05&hl=2 (sorry, no e92 parts on realoem.com yet) Edit: To be clear, note that the part has a mechanical linkage (attaches to sway bar I believe). A tilt/incline sensor would need no such external linkage.
In my garage: '11 e92 335is 6MT (05/10) SpGrey/CoralRed/GlacSlvr ExecPkg/NavPkg/19" 225M
Retired: '07 e92 335i 6MT (12/06) SpklgGrpht/CoralRed/GreyPoplar Retired: '04 330Ci M-Sport 6MT SilverGrey/NaturalTan/MyrtleWood Retired: '00 328Ci 5MT SteelGrey/Grey/MyrtleWood Retired: '87 Pontiac Grand-Am 3AT White/Grey |
11-09-2006, 11:40 AM | #11 | |
15
Rep 575
11-09-2006, 12:09 PM | #12 | |
550
Rep 6,563
under construction! |
11-09-2006, 12:27 PM | #13 |
1312
Rep 10,185
The movement on startup is for calibration and self test. Its moves to all the stops and back
As for the aim on incline or declines: I have double checked the manuals on this On a level road the hardware on the suspension feeds information to sensors which feed info to the light control unit on how to set the lights. ( there isnt a mechanical link ) Going from a light to heavily loaded car will change the angle of the lights Braking ( thus having the nose dip down slightly) will cause the lights to move up Accelerating ( thus lifting the nose slightly) will cause the lights to go down a bit. On a uneven road the suspension will move up and down, causing the lights to adjust up or down Now there isnt a specific senfor for inclines or declines, but one can think of it this way On a sharp decline the weight of the car will cat mostly on the front suspension, causing the nose to dip, thus causing the lights to moce up a bit On a sharp incline the weight of the car will act mostly on the rear suspension, lifting the nose slightly, causing the lights to adjust down slightly
BMW if you are reading, I need a job, Please. |
11-09-2006, 12:31 PM | #15 |
550
Rep 6,563
when I hit a road that is wavy up/down, I actually see my light beam bouncing up and down (like the light bulb is loose).
01-29-2007, 02:31 PM | #17 |
Rep 9
I think the self leveling feature is some kind of European safety standard. It is not standard on ricers, and that's the reason you get blinded by Japanese cars with factory xeons when you meet them on an incline.
01-29-2007, 02:37 PM | #18 | |
Rep 98
Yes, people mod their headlights and don't adjust correctly, but not all Hondas are aftermarket HIDs. |
01-29-2007, 03:43 PM | #19 | |
41
Rep 3,200
328xi Coupe, Montego Blue on Black with Alum, Step, Sport, Premium, CA, PDC, Cold Weather (Damn Pennsylvania winters)
Current Mods: Heavy right foot - Planned Mods: Lightweight right foot |
01-29-2007, 04:05 PM | #20 | |
36
Rep 561
Always at night here in the NY metro area... either they got into an accident and the bodyshop didn't repair it properly missing the headlight alignment part...or they changed the headlamp or the bulb and don't even align it right as it's supposed to be. Everytime I change a headlight bulb or the housing in one of my cars, I print out the service manual section on headlight alignment. Fill up the gas tank to full, check all tire pressure. you find a place where there is a wall and a perfect level floor as possible...AFAIK park the car 20-30 feet away and shut it off. Draw a stright line from the car front end to the wall (I used a laser line beam from a construction leveling equipment) Best way to do this is start from the center of the diff from under the car to the front end center measurement...use that line to line up the true center of the car to the wall. Measure the distance from the center of the low beam headlight bulb to the other headlight and find the center of that by diving it by 2. Now transfer that measurement onto the wall (i used masking tape and a sharpie) starting from the center and out for each side. Should look like a cross now. Measure the height from the floor to the center of the low beam headlight bulb and transfer that height to the wall on the line from the center to the target from the center out (where the headlight bulb would be), now mark the beam aim target 2 inches lower from the level line. Turn the headlights on and adjust the headlights on each side to the target spot you marked with the sharpie... If the high beam is enclosed with the lowbeam, it should be in alignment already as you adjusted the low beam... if it's a seperate housing, then make the high beam on the the horz. line about a 1.5 to 2 ft away from the center on each sides. Other than that...there's those SUV's and ricers who put in a "HID" kit which has a ballast, bulb and wiring...but no headlamp assembly made for the HID bulb...the end result is that the light is fractured all over the place. 2 weeks ago I was driving home from VT with my gf and saw one car with a light beam aiming into the sky like 30 degrees from level! WTF r they trying to do...ET phone home?! |
01-30-2007, 11:03 AM | #21 |
Black Forest Bimmerphile
Rep 137
Have the xenons on my wifes E39iT. She likes to snug up to those concrete parking blocks when she is making her calls. Unknown to me she got too close and hit the leveling arm attached to the swaybar. It causes the lights to point straight down and we had to drive two hours in the morning without brights. Easily reattached with channel locks but had me baffled for a while.
01-30-2007, 03:17 PM | #22 |
Rep 10
This seems to be hit and miss... Some headlights will autolevel together and others not. Anyone else have headlights that do not autolevel in sync? My driver's headlight autolevels first and then the passenger but not sure if this is normal.
