Defogger doesn't work-suggestions?
11-08-2006, 09:18 PM | #1 |
990
Rep 6,381
I know the Florida weather conditions don't help but it seems like my defogger doesn't work at all. I hit the defogger button and it goes on super high blast and it either does absolutely nothing or clears a very small section and I can leave it on for like 10 minutes and nothing happens. Sometimes I try putting the a/c on but that doesn't help.
My friend had an E46 and when he used his defogger it like blew away the fog instantaneously. ?
Nikki
11-08-2006, 09:21 PM | #2 |
35
Rep 1,169
Drives: 67 GT500,69 Boss 429, 335i
What temp are you using? Cold or hot? Try switching.
PS. Why are the windows so fogged in the first place? |
11-08-2006, 09:22 PM | #3 |
pull my finger to get your kinder® surprise
148
Rep 10,455
usually, I don't even use teh defogger, just press the auto climate, and it defogs the windshield right away, try using the auto-climate
11-08-2006, 09:29 PM | #5 |
148
Rep 10,455
hit the "auto", and it cools/warms to whichever temperature (indicated on the display) you set it at
and that usually does the trick for me to clear the fog, I've never had to hit the defogger thus far
11-08-2006, 09:33 PM | #6 | |
990
Rep 6,381
Nikki
11-08-2006, 09:35 PM | #7 |
27
Rep 520
Drives: 2012 F30
Garage List 2012 BMW 328i [10.00]
(retired) 2009 528i [10.00] (retired) 2006 325i [10.00] (retired) 2002 325ci [10.00] |
Make sure the AC compressor is on too- no matter what temp you are setting the air...
2012 F30 328i, Melbourne Red, Premium, Sportline, Steptronic, Xenon, Harmon Kardon.
11-08-2006, 09:35 PM | #8 |
148
Rep 10,455
I sually set it at a temp that's comfortable to me, which is about 20-22 celcius (68-72 F)
11-08-2006, 09:37 PM | #9 |
990
Rep 6,381
Mine is always on 60 and then I hit the defogger and it sets the fan up to like max and then sometimes I hit the a/c if it doesn't work but that doesn't do anything. I guess I'll try the auto function and maybe a higher temperature.
Nikki
11-08-2006, 09:39 PM | #10 |
57
Rep 1,019
Drives: Monaco Blue E92
Move back north; the results are mindboggling.
'07 Monaco Blue 335i ordered 9/4 built 9/21 shipped 9/28 arrived 10/12 at dealership 10/18 vroom 10/19 christened 11/3... |
11-08-2006, 09:48 PM | #12 |
Rep 358
may sound silly, but after you've hit the defogger and it's turned the fans up to max have you stuck your hand over the dash to make sure there is air being blown onto the windscreen? It could be a blocked vent.
11-08-2006, 09:56 PM | #13 | ||
990
Rep 6,381
I try opening my windows also unless it is raining. Quote:
Nikki
11-08-2006, 10:05 PM | #14 |
Shadow Warrior
139
Rep 2,095
First time I hit the defogger button I discovered that it was blowing cold air, so I adjusted the temp to 70 and moved the heat dial (whatever it's called) towards the hot setting and that did the trick... windows cleared fairly quickly. Granted it hasn't been super cold down here but I'd say no more than 5 mins later and the whole thing was cleared up.
After that I turn it off and re-adjust to a cooler temp for the A/C. If there's some "auto" feature that detects the temp and knows when to turn it hot I'd like to hear about it... BTW I use recycled air... wouldn't pulling the cold air from outside take longer?
335i E90 / Arctic / Gray / Burl Walnut / Steptronic / ZPP / ZSP / Paddles / CA / Nav / PDC / OEM Spoiler
Mods: PIAA Angel Eyes, Rear Fog Switch, Escort X50 Blue hardwire, 30% Charcoal Llumar Installing soon: Rear Power Outlets (Happy Robot mod!) |
11-08-2006, 10:12 PM | #15 | |
990
Rep 6,381
Nikki
11-08-2006, 10:16 PM | #17 |
57
Rep 1,019
recycled air will likely have lower humidity but I would guess if there is a problem in FL, use a warmer setting; cooler air will only aid in condensation.
11-08-2006, 10:17 PM | #18 | |
990
Rep 6,381
Nikki
11-08-2006, 10:23 PM | #19 |
Shadow Warrior
139
Rep 2,095
Here's a question on a related note: my side-view mirrors were slightly wet / fogged up, and usually I'd wipe them down but on 2 different days I neglected to do so... or I was planning to do so after I had already hit the defogger button to clear the windshield... well, before I could get to it, I noticed that the side-view mirrors had cleared up.
So is there some heating function that I'm not aware of? I thought that was a CW pkg thing (I don't have that). Or maybe this was just a coincidence and they just cleared up on their own somehow heh...
11-08-2006, 10:25 PM | #20 | |
990
Rep 6,381
Nikki
11-08-2006, 10:27 PM | #21 | |
29
Rep 633
The "advantage" of living with cold weather is that you only need to heat the outside air to lower its RH so it can haul that moisture without having to do that A/C thing then reheat. |
11-08-2006, 10:28 PM | #22 | |
57
Rep 1,019
