Wheels spacers; your story
03-06-2010, 06:53 PM | #1 |
35
Rep 430
E90 2007 here. I am tempted to install 12mm spacers in the rear w/longer bolts of course.
I would like to know if it is much harder to install. It is already a PITA with no spacer. I hate bolts as opposed to studs. Any bad experience or rubbing with 12mm? |
03-06-2010, 07:11 PM | #3 |
91
Rep 499
Drives: F36 440i
I have 20mm rear spacers and it just barely rubbed before I rolled the fenders, but my car is lowered. I would go at least 15mm on an E90.
Putting them on is as simple as it gets, but removing them can be a different story. Make sure that you buy a set that has reliefs machined into the back side to give you something to pry against when removing them and use plenty of anti-seize when installing them. I highly recommend these: https://www.turnermotorsport.com/htm...&subcat_id=157 Last edited by DV; 03-06-2010 at 07:39 PM.. |
03-06-2010, 07:14 PM | #4 |
27
Rep 468
Drives: 07 335i e90
I have a 07 3351 e90 w/15 mm spacers lowered on H&r sport springs w/no rubbing
03-06-2010, 08:00 PM | #6 |
531
Rep 43,411
03-06-2010, 09:09 PM | #7 |
23
Rep 366
I had 8 and 15mm spacers when I had my jetta (also had lug bolts). pain in the ass but as long as they're hubcentric you should be good. I know the bigger h&r spacers have the lip for the wheels (I think it's called wheelcentric) so it makes it easier to hold the wheel up so you can align the holes and get the lug bolts in.
I'm seriously considering a stud conversion lol |
03-06-2010, 10:51 PM | #9 |
Rep 322
03-07-2010, 10:48 AM | #10 |
91
Rep 499
Drives: F36 440i
I have 10mm in the front. No issues here.
03-07-2010, 11:55 AM | #11 |
35
Rep 430
Txs, good info here. I will possibly go with 15mm spacers instead of 12... and with lips.
My 18" wheels are not staggered and I have 8" in the rear. I have a problem with the look... hopefully the spacers will help. |
03-07-2010, 05:29 PM | #12 |
35
Rep 430
BTW, are longer locking bolts available? What length do I need? Is it doable that I order the same locking code as the other locking bolts I have?
03-07-2010, 09:02 PM | #14 |
669
Rep 7,148
depends on ur set up...
Im lowered on H&R Race. Stock 230s with 225/35/19 F, 265/30/19 R. Im running 15mm spacers up front with no issues 12mm spacers out back, but I had to roll my fenders, they rubbed a little
2016 F80 M3 Mineral White/Sakhir Orange
2013 BMW S1000RR Flat Silver <stolen> 2007 BMW E92 335i Jet Black/Jade Grey <sold> |
03-08-2010, 01:42 AM | #16 |
118
Rep 2,215
03-08-2010, 09:03 PM | #18 |
Me
12
Rep 246
im about to put my summer setup back, and was wondering the same thing... bump for an answer
Dan
Scuderia Ferrari Marlboro |
03-08-2010, 09:08 PM | #19 |
Rep 51
Just installed 12mm Macht Schnell spacers in the rear, looks way better. My set-up:
2007 E90 328i Wheels: 20x8.5 +35mm/os TSW Donington Tires: 245/30/20 Nitto Invo Suspension: Eibach-Pro kit 1.2f/1.0r Spacer: 12mm MS Kit w/longer bolts I could've gone to 15mm on the rear but I didn't want any issues so I was conservative, plus I could go even lower with the 12mm. Now I am thinking about spacers for the front too. DIY INSTALL - READ: Here is my only issue with the DIY install, and I wished I would've known this before I started and got VERY frustrated . On my 2007 E90 there were very thin shim rings on the hub-centric flange located on the brake disc and with that thin shim ring in place the spacers would not fit at all. Once figured this out and removed the shim ring the spacers went on without any problem. I searched all over the internet before I bought spacers and NEVER ONCE did I read about these thin shims as part of the install process. So I hope this tip helps someone with a future install. |
03-09-2010, 07:45 PM | #20 | |
35
Rep 430
I found this on ebay http://cgi.ebay.co.uk/EXTENDED-LOCKI...37215648307449 I wonder if 40mm of thread is enough for 15mm spacers. |
03-17-2010, 10:58 AM | #22 |
91
Rep 499
Drives: F36 440i
