Coby Wheel
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > e92 exhaust bypass valve - 335i
      11-07-2006, 10:35 PM   #1
RiXst3r
RiXst3r's Avatar
273
Drives: M235i
Is the golf tee mod possible on the e92 335?
      11-07-2006, 10:37 PM   #2
OpenFlash
1736
Drives: A Lot
Yes.
      11-07-2006, 10:38 PM   #3
RiXst3r
RiXst3r's Avatar
273
Drives: M235i
Originally Posted by shiv@vishnu
Yes.
Anyone know what difference in sound this makes for the 335?
      11-08-2006, 07:53 AM   #4
RiXst3r
RiXst3r's Avatar
273
Drives: M235i
Nobody has done this to a stock 335i exhaust yet, that can compare before and after?
      11-08-2006, 08:21 AM   #5
RiXst3r
RiXst3r's Avatar
273
Drives: M235i
Originally Posted by NaViT
prolly not bro give it a few weeks maybe
Maybe i need to be the one to do it, and post my results...
      11-08-2006, 11:24 AM   #6
OpenFlash
1736
Drives: A Lot
With the exhaust bypass open (vacuum hose pulled off the actuator on the driver's side exhaust tip), the car will be slightly louder at idle and cruise. It will sound the same under boost. Try it. It takes 10 seconds to do and easy to put back to stock if you don't like it.
-shiv
      11-08-2006, 12:03 PM   #7
jjw3477
Guest
n/a
Drives:
does this mod have any affect on performance?
      11-08-2006, 12:05 PM   #8
RiXst3r
RiXst3r's Avatar
273
Drives: M235i
The car might idle a bit stronger, but i doubt it... i would say sound only
      11-08-2006, 02:05 PM   #9
trick50
trick50's Avatar
56
Drives: E92 335i Space Gray
can someone please explain in detail what this "golf Tee" thing is, and how to do it?
Thanks
      11-08-2006, 02:23 PM   #10
Borti
Borti
Drives: 335i
Thanks
Pull the vacuum tube off of the solenoid attached to your driver's side muffler and plug it with a golf tee and zip tie it off somewhere if you can... Atleast that is how you did it on the R32.
Originally Posted by climkt
fabulous, nothing like a stick shift e92 to add adrenaline and enthusiasm.
Originally Posted by aarnt
Drivers over here get their license with MT. Most cars have MT, and all of my friends can drive MT. My chick had an auto once and she sold it in less than a year because she didn't like it. The only replacement to MT for me would be shifters in the steering wheel (ala F1)! Still MT but no clutch.
I don't drink,smoke,eat in my car, ever. And I don't hold the hand of my GF of her thigh or anything else unless there is traffic or stoped in a traffic light. When the car moves, I'm meant to drive it both hands... and god I do it with pleasure
Kudos!
      11-08-2006, 04:28 PM   #11
trick50
trick50's Avatar
56
So....this hose is right in the back of the car...by the muffler? Does it help performance at all? Will it make the exhaust dramatically louder? I guess I will just try for myself whenever the rain stops here and we have a relativly warm day.
As long as it does not hurt performance./
      11-08-2006, 04:32 PM   #12
ehhhwik
ehhhwik's Avatar
Hong Kong
114
Drives: 09' BMW 335d, 07' BMW E92 328i
Does this "golf-tee" mod possible for e92 328i? Ive looked at the muffler in my car and i dont see any vaccume tube close to my muffler
      11-08-2006, 04:39 PM   #13
///Matt
United States Marine
///Matt's Avatar
316
Drives: 2007 Dodge Ram 1500
2006 330i  [0.00]
it makes the car VERY slightly louder. There will be a deeper tone at low to medium low rpm. There should be NO performance gain. At higher RPMs, the flap is open ANYWAY. at LOWER RPM you may actually LOSE some torque. The flap is designed to decrease noise AND increase backpressure at low RPM. This backpressure increase is designed to help low end torque.
Also guys.... You should take a look at the flap with the car OFF and the hose unplugged.
Some of BMW's cars are a little backwards. For instance, on the E65, early in production the valve was closed by vacuum, so if you unplugged it, it would be always open. But then they changed it so that it's OPENED by vacuum, so if you unplugged it, it'd never open! (I may be backwards, it MAY have gone from vacuum open to vacuum close. Doesn't change the statement!)
I don't beleive the 328 HAS the exhaust flap.
      12-10-2006, 07:55 PM   #14
Chio
Chio's Avatar
106
Drives: G80 M3 Comp Xdrive
2018 S6  [10.00]
Going to do this this week!!!
      06-07-2007, 10:15 PM   #15
Definitive
definitivecars.com
Definitive's Avatar
353
Drives: Elsa - 2015 F80 M3 - YMB/SS
So does anyone know if the 328 coupe have this flap?
Definitive
      06-08-2007, 03:24 AM   #16
E90Fleet
South Africa
1311
Drives: BMW
Definitive
No, it does not have it
Only 330i and 335i have
BMW if you are reading, I need a job, Please.
      06-11-2007, 06:31 PM   #17
Booster
Pave The Rainforest
269
Drives: Wagon
2007 335i Coupe  [0.00]
Did it this weekend...
Took around 10 seconds...
Louder at idle and a little louder under throttle to around 3500 RPM.... Nothing drastic...
Sold: 2015 Pyrite Brown M3
Sold: 2020 Sunset Orange M340i Xdrive
Sold: 2021 Bluestone 540i Xdrive Msport
      06-11-2007, 08:37 PM   #18
BoostedBMW
Moderator
BoostedBMW's Avatar
132
Drives: TiAg E92 335
2003 S2000  [0.00]
I'm not too sure if you would lose torque on the 335 though since back pressure really has no benefit with a turbo engine. If anything, less back pressure would mean faster spool, but the difference either way from an exhaust flap shouldn't be too large in any case.
-Michael.
Berlina Black S2000 CR is now in the garage
l 19" Rial Daytona Race l KW V2 l Eisenhaus Race Exhaust l
      06-17-2007, 03:51 AM   #19
E90330iS
Germany
143
Drives: BMW M4
2006 330i  [0.00]
Did it on my 330i and my brother's E92 335i both sound a little louder at low RPM, at around 2000 is the most obvious.
      06-17-2007, 10:18 AM   #20
BayernMuenchen
BayernMuenchen's Avatar
13
Drives: 2007 335i Coupe
it just sounds different (better in my opinion). It's easy to just try and put back if you don't like the change. All it takes is the tee (or a screw is what I used) and a ziptie.
2007 335i Coupe
