WTB: 18" light weight track wheels
03-03-2010, 06:39 PM | #1 |
83
Rep 1,861
Drives: 2008 E92 335i
Hey guys, Im looking for a set of 18" light weight track wheels (preferably not staggard) and a set of R-compound tires. Not sure on brand, but if you got em feel free to pm me with specs and price. Thanks Last edited by Asclepius; 03-04-2010 at 01:27 PM.. |
03-03-2010, 06:58 PM | #2 |
475
Rep 13,583
Drives: JB E92 335i
The Forgestar F14 in 18" is the perfect setup for you
This brand new lineup utilizes a combination of the best methods of forging and casting methods both in the same wheel. This is called Flow Form Casting, and is used by companies such as BBS and Enkei. Flow Form Casting is a production procedure that turns the wheel (or rim section) over a special mandrel and three hydraulic rollers using tremendous pressure. The pressure and turning then force the rim area to form against the mandrel, creating the shape and width of the rim. During Flow Forming, the rim actually "flows" down to create the full rim width. During Flow Forming, pressure applied to the cast rim actually changes its mechanical properties, so its strength and impact values become similar to those of a forged rim. That translates to up to 15% less weight when compared to a standard cast wheel. Weights: 18x8.5 ET48 - 17.6 Lbs. 18x9.5 ET48 - 18.4 Lbs. 18x10 ET42 - 18.2 Lbs. 18x12 ET68 - 20.0 Lbs. [IMG]http://www.**********s.com/images/Products/Forgestar%20Wheels/Gallery/king08.jpg[/IMG] [IMG]http://www.**********s.com/images/Products/Forgestar%20Wheels/Gallery/king01.jpg[/IMG] |
03-03-2010, 10:26 PM | #5 | |
83
Rep 1,861
[QUOTE=**********s.com;6841315]The Forgestar F14 in 18" is the perfect setup for you
This brand new lineup utilizes a combination of the best methods of forging and casting methods both in the same wheel. This is called Flow Form Casting, and is used by companies such as BBS and Enkei. Flow Form Casting is a production procedure that turns the wheel (or rim section) over a special mandrel and three hydraulic rollers using tremendous pressure. The pressure and turning then force the rim area to form against the mandrel, creating the shape and width of the rim. During Flow Forming, the rim actually "flows" down to create the full rim width. During Flow Forming, pressure applied to the cast rim actually changes its mechanical properties, so its strength and impact values become similar to those of a forged rim. That translates to up to 15% less weight when compared to a standard cast wheel. Weights: 18x8.5 ET48 - 17.6 Lbs. 18x9.5 ET48 - 18.4 Lbs. 18x10 ET42 - 18.2 Lbs. 18x12 ET68 - 20.0 Lbs. QUOTE] These look sick! I may give you a pm. Im gonna see if I can find something cheaper first..... Ill prob have to go used. If I cant find anything Ill consider these. Thanks Quote:
meh, not really feelin em. Ill keep em in mind though, thanks |
03-03-2010, 10:33 PM | #6 |
381
Rep 1,174
Drives: BMW
Check these out
http://www.e90post.com/forums/showthread.php?t=340834
BMWCCA member 429244
03-03-2010, 10:51 PM | #7 | |
83
Rep 1,861
03-07-2010, 07:28 PM | #9 |
83
Rep 1,861
03-08-2010, 01:07 AM | #10 |
69
Rep 2,385
I have these for sale. Great track wheels, and you'd have 2 as spares incase anything happens to a wheel!
http://www.e90post.com/forums/showthread.php?t=358939 |
03-08-2010, 11:04 AM | #11 | |
475
Rep 13,583
Drives: JB E92 335i
NP I'll shoot you over a PM anyway |
03-08-2010, 01:47 PM | #12 |
31
Rep 186
Im still waiting on a shipping quoto by email
04-08-2010, 12:33 PM | #13 | |
Booosted
44
Rep 832
2008 BMW 335i//Jet Black on Black Dakota Leather//Steptronic, Sport Package, Premium Package, Logic7 Sound, Aluminum Trim, iPOD & USB, Cobb S1+ Sport, ER FMIC, ER CP, K&N Filter, H&R Sport Springs, Koni Yellows, ECS Tuning spacers (F-10mm/R-15mm), Akebono pads, OEM Rear Aero Spoiler, OEM Sport Diffusor, Cyba 3.8" Tips, OEM Aluminum Pedals, M-tech Steering Wheel, Clear Reflectors
04-08-2010, 03:10 PM | #14 |
475
Rep 13,583
Drives: JB E92 335i
The Forgestar F14 is available in the following offsets:
18x8.5 offsets from +26 to +50 18x9.0 offsets from +20 to +55 18x9.5 offsets from +26 to +60 18x10.0 offsets from +16 to +42 18x11.0 offsets from +23 to +55 18x12.0 offsets from +36 to +68 |
04-08-2010, 04:06 PM | #15 | |
Booosted
44
Rep 832
What sizes/offsets would you recommend for a 335i coupe on H&R Sport springs? Any pix of a JB on 18" silver Forgestars?
