What's the code for the new M3?
11-06-2006, 08:41 AM | #1 |
Texas
311
Rep 769
We know the E90 code referes to the sedan, E91 for the wagon, E92 for the coupe and E93 for the convertible. How about the upcoming M3? Is it going to be E92 like the coupe or something else?
11-06-2006, 04:28 PM | #5 | |
Member
306
Rep 22,825
The numbers are getting really high after the big jump from 46 to 90. I wonder if they will eventually go with a tripple digit number (E100?) I guess they have to use these numbers sparingly. Same with the chassis code for the 911 which is reaching the 4our digit mark (currently at 997). |
11-06-2006, 04:29 PM | #6 | |
82
Rep 5,732
I meant the first part - you are correct about the numbering, that is why the codes are changing to F-* from E |
11-06-2006, 04:31 PM | #7 | |
Member
306
Rep 22,825
11-06-2006, 05:05 PM | #8 | |
105
Rep 1,181
Drives: G29 Z4 M40i Roadster
http://www.bmwarchiv.de/e-code/index...code&sort=desc |
11-06-2006, 05:21 PM | #9 |
42
Rep 1,096
The E* alone does not apply to Body style, as all BMW's since 1955 (I believe) have been with the letter "E" in the model/body style designation. E46 (2000-2005 3 Series Coupe and Sedan), E60 (New 5 Series).
Since BMW has run out of E's; the next Generation 5 Series will be under the Body Style designation F10 So the Body Style is defined by the full lettering, i.e.: E90 -> Sedan (323i, 325i, 328i, 330i, 335i + the diesels) E91 -> Touring (325i, 328i, 330i, 335i + the diesels) E92 -> Coupe (328i, 335i + the diesels) E93 -> Convertible (328i, 335i + the diesels) So for the "M"'s in the 3 series will be; E90 -> Sedan (M3 Sedan) E92 -> Coupe (M3 Coupe) E93 -> Convertible (M3 Convertible) or in our language E90 328i E90 335i E90 M3 E92 328i E92 335i E92 M3 *****You get the picture The Actual and Exact Model code, (Engine & Body Style --> for more precision) is a set of 4 digits in the serial number. WBAVB33 ........ -> E90 330i WBAWB73 ........ -> E92 335i WBAVB73 ........ -> E90 335i Hope this helps |
