Aftermarket Limitations AT vs. MT
11-03-2006, 07:52 PM | #1 |
128
Rep 836
Hi All,
I've been lurking for a few months. I'll probably be picking up a 335i in April/May sometime...although reading all these fantastic reviews is making it pretty hard to be patient. I have an A4 Turbo and have done quite a bit over the years. It's a MT and I know for the Audi, having an AT limited what you could do as far as adding power via ECU/Upgraded turbo etc. as the AT couldn't handle as much power as the MT could. Do you think this will be the same case with the 335. I was pretty set on the MT anyways because my commute is mostly highway with not a lot of traffic and I do enjoy rowing through the gears but the step does sounds very good from all the posts i've read. I'll definately have to drive both. I love turbos because it allows you to do power additions at relatively low cost. |
11-03-2006, 09:31 PM | #2 |
QuickShifter
137
Rep 1,500
AT- PROs: Kickmode....feel that boost thing when you floor it and you get to be lazy sometimes, yet use the +/- or the paddles to shift if you want a little of your MT feeling back
MT- 100% control of your car, and enough said...haha |
11-03-2006, 10:12 PM | #3 | |
128
Rep 836
Not an AT vs. MT post....
11-03-2006, 11:19 PM | #4 | |
QuickShifter
137
Rep 1,500
but....not sure.....but i doubt there's a difference though... |
11-03-2006, 11:30 PM | #5 |
Moderator
618
Rep 10,855
Tough call. The 335d is step only, reportedly because the clutch in the manual could not handle all the torque. I would wait and see what happens to folks that get the Vishnu xede set-up. My guess? It's a BMW, it's solid either way.
11-04-2006, 12:21 AM | #6 | |
Addicted to AutoX
17
Rep 171
Since the 335 is already pushing ~320+HP to the crank, I imagine that it can run more, but I have not seen any specs on this. I'm sure someone here will push their car to the limit and then we'll know. I can't recall off the top of my head, but is the tranny in the 335s made by ZF or GM? or some other manufacturer? EDIT: I found it. Google is your friend. Its a ZF six-speed, but I still don't know what its max torque rating is.
11-04-2006, 12:30 AM | #7 | |
57
Rep 1,019
Drives: Monaco Blue E92
'07 Monaco Blue 335i ordered 9/4 built 9/21 shipped 9/28 arrived 10/12 at dealership 10/18 vroom 10/19 christened 11/3... |
11-04-2006, 12:31 AM | #8 |
118
Rep 390
Drives: '16 M3, Lotus Exige S260
Coming from the Audi S4 world, the Quattro was the limiting factor most often for performance jumps. W/O the "xi" on the 335 I would think there would be little difference in aftermarket limitations between the two. This particular auto seems to lock up the torque converter frequently, thus allowing more power. And in a manual you can always be more gentle with clutch release as a driver, thus saving your driveline.
_Scott |
11-04-2006, 12:34 AM | #9 | |
118
Rep 390
For example, when desiring extreme engine braking, the manual driver can leave a gear fully engaged, while the auto driver may be in the same gear the torque coverter allows slippage and thus less control. This is why a typical auto can be in "1st gear" and you will not be moving at a stop. _Scott |
11-04-2006, 12:37 AM | #10 | |
Addicted to AutoX
17
Rep 171
Automatics will prevent any possibility of a money-shift, BUT it WILL also shift at redline (unless you have software) and kickdown mode overrides all other modes and upshifts no matter what. So, you do not have 100% control.
11-04-2006, 12:37 AM | #11 |
57
Rep 1,019
Ummm... I am not sure what you mean. If I do not apply the break in 1st, the car moves forward, even on an incline.
11-04-2006, 12:40 AM | #12 | |
57
Rep 1,019
11-04-2006, 12:42 AM | #13 | |
57
Rep 1,019
11-04-2006, 12:46 AM | #14 | ||
Addicted to AutoX
17
Rep 171
11-04-2006, 12:50 AM | #15 |
57
Rep 1,019
Do you know if the AT in the 335 will shift at redline?
11-04-2006, 12:57 AM | #16 | |
Addicted to AutoX
17
Rep 171
You know what, I really need to go test drive one of these babies already .
11-04-2006, 01:02 AM | #17 |
35
Rep 491
from what I know regarding AT's and Audi's, it is the torque that the tranny can't handle. With MT you can swap the clutch and you're good to go. With AT you could upgrade the torque converter and the valve body to allow it to take more..but at a cost
The auto in the 335i is a ZF 6 speed in a car making ~300lb/ft torque. Trannys can usually take more torque than their particular application, kind of like a buffer... but the question is how much...350lb/ft...400lb/ft...finding this out would definetly reveal the modding potential for the AT If someone can find the ZF tranny model number, it would be interesting to look up the specs on this bad boy...from the reviews it seems to be quick and good even for a 'slushbox' |
11-04-2006, 01:22 AM | #18 | |
Rep 68
Slipping the clutch is how a manual 1990 Nissan Sentra (for example) can burn tire, something it's engine could never do on it's own. The best way to learn how to drive a manual is in under-power cars which have a very fine line between gaining power and stalling, you really learn how to operate that clutch. |
11-04-2006, 01:26 AM | #19 |
177
Rep 2,355
GET suspension!
2006 E46 M3 ZCP 6SPD-Interlagos Blue - 6SPD - SSK - AA Headers -AA Tune - Navigation w/ Splashscreen Mod - 3M Crystalline Series 60 - Carbon Splitters - Swissvax Treated - Bridgestone
2012 Yamaha FZ8 - Matte Black/Grey - Michelin Pilot Pure 2CT - Vortex Rear Sets - Yoshimura R-77D & Fender Delete - Spectro Race Oil - GP Reverse Shifting |
11-04-2006, 01:26 AM | #20 |
177
Rep 2,355
everyone car drops need
11-04-2006, 01:46 AM | #21 | |
118
Rep 390
About Torque Converters (long)
The automatic transmission's torque converter is the "magic" component. This is actually a hydraulic fluid coupling, that sits between the transmission and the engine. In old automatic cars torque converters relied solely on the hydraulic fluid to "push out" to the ends to couple the transmission to the engine. Thus, there was little if any engine braking. In more modern cars (since the 80's), a locking torque converter is used. This allows the automatic to function like a manual transmission car (not the shifting gears part, the direct connection part) when the transmission decides that power should be routed 1:1. Now in this new transmission BMW has taken it to a new level. This automatic has 2 very intersting features. First, it has the steptronic function. This is nice, and allows you to force the auto to stay in a particular gear. The other feature is that the torque converter actually decouples from the transmission completely at a stop. This is an automotive first, and actually is solely for fuel consumption, since it uses less gas sitting still than having the hydraulic torque converter connected. Think of it as moving the transmission to neutral on a stop. This is the reason the new e92 has the "brake assist" function for starting on hills -- the auto can actually roll backwards since the engine and transmission are decoupled. However, even with these advances, you do not control how or when the torque converter is locked, disconnected, or partially engaged. The transmission itself controls how much engine power is routed to the transmission. Hopefully it makes the right choice. However, let's say you wanted to do a huge smokey burnout. In a manual, you can choose to leave the clutch disengaged and then rev the engine, and then engage it fully. In the auto, the torque converter will choose to engage no matter what you do. You could also do other usefull things with slippage without the point of a smokey burnout, like as is common in AWD cars (my S4, the new 335xi, etc) -- which is slipping the clutch to keep the engine from bogging, or in 3rd gear disengaging the clutch, spooling up the revs, and then reengaging the clutch to have a quick jump in speed-- without changing gears. Overall I think the 335's automatic is the best true automatic ever made, but it is still not a manual transmission. DSG and SMG are a whole different conversation as well. _Scott Member of the Society of Automotive Engineers. |
11-04-2006, 09:29 AM | #22 |
57
Rep 1,019
Thanks all for ejumicating me! :-) Good stuff!
