Some good news on 335i fuel pump problems
11-03-2006, 01:06 PM | #1 |
1312
Rep 10,185
Its good news
Apparently 90% or more of the problems are actually a software fault causing the high pressure pump to only put out 5 bar or less and not a mechanical problem. And the problem has only been seen in a very small amount of the delivered cars They have issued dealers the procedure to test/fix the problem on affected cars with a software fix. Unfortunately there have been a few isolated cases of mechanical pump failures, but nothing more than expected for a new part launch
BMW if you are reading, I need a job, Please. |
11-03-2006, 01:26 PM | #2 |
12
Rep 233
I'm a little confused. If it's a software problem, how is it only affecting some cars. I understand if you're talking about a physical part breaking. Obviously the part could break on some cars and not others. But if it is software related, how is it only affecting some cars. Is it something to do with environment or load? I realize that you may not know the answer to these questions (which are posed by a novice anyway), but I thought I'd ask. Nonetheless, this is good if it is true.
11-03-2006, 01:33 PM | #3 |
1312
Rep 10,185
Its a software calibration problem on certain cars
Im guessing there may have been some problem when loading the software during manufacture or setting the calibration or something like that Its fixed by a software recalibration and update
11-03-2006, 02:00 PM | #5 | |
1312
Rep 10,185
