Clutch engagement feel / control
11-02-2006, 11:25 PM | #1 |
Rep 24
Quick question - I searched. I've seen discussions on the shifter feel, but not the clutch feel and control. As some of you may know, I have a G35 which I'm interested in trading for a 335i. But, I haven't test driven one because I'm afraid I'll love it too much and I'm not ready to pull the trigger for a bit.
Anyway, what I don't like about the G is the on/off feel of the clutch. The S2000, on the other hand is quite progressive. The weight isn't the problem, just a poorly designed clutch in my opinion. You can feel exactly what the clutch is doing and modulate accordingly on the Honda. Not so on the G. It also doesn't help that it chatters on take off and the dealer "can't replicate." Is the BMW clutch an on/off switch or progressive? I find it nearly impossible to engage/disengage the clutch on the G smoothly and I've been driving stick exclusively for well over 10 years. Thanks for the feedback... |
11-02-2006, 11:57 PM | #2 |
BMW, can I have some LSD please?
88
Rep 1,591
Haven't driven the manual on the G35, but on the 3-series, there's a CDV (clutch delay valve) that slightly slows down the engagement of the clutch. This was put in by BMW most likely to smoothen out the transmission shock that you're feeling on the G35's manual.
The 3's clutch is quite good. Easily modulated and progressive. And the drive by wire helps if you're creeping along in 1st or 2nd gear in heavy traffic. Just go for a test drive and you'll see for yourself! (But make sure you leave your checkbook and credit cards at home if you're not ready to buy yet!!)
2006 330i | TiAg | Black | Al | 6MT | Sports Package | Logic 7 retired
2008 335i | AW | Black | Al | 6MT | Sports Package | Logic 7 retired 2013 328xi | Red | Gray | Al | 8AT | Sports Line | Premium | Executive | Heat Pkg retired 2017 340i xDrive | Estoril | Black | Al | 8AT | M Package |
11-03-2006, 02:58 AM | #3 |
Member
306
Rep 22,825
I previously owned an 04 GCoupe and agree that the clutch required more modulation then the usual. I also had to rev more then usual to avoid the chatter you are describing.
The BMW clutch is very easy to use. In my opinion, more so then the S2000. The engaging point is obvious which makes the grabbing point during excelleration seemless. The shifter even feels better then the G, but not even close to the S2. |
11-03-2006, 07:03 AM | #4 |
550
Rep 6,563
all these new terms make me feel like a rookies...what is drive by wire, what is progressive, modulate? what do they mean in a manual trans?
On a side note, the 06 330i manual feels much better than 05 325i manual. Throw is a little shorter on 06 e90 vs 05 e46. That much I do know from having driven both cars. |
11-03-2006, 07:43 AM | #5 | |
Car Junkie
21
Rep 1,279
Drives: 335is / R8
I owned an 03 coupe and had to follow the same pattern as you describe. Also, the 335i has a slight notchy feel to it, but no where near the notchy rubbery feel of the G35. |
11-03-2006, 08:07 AM | #6 | |
11
Rep 613
By progressive/modulate I think the OP was just talking about how he works the clutch. |
11-03-2006, 08:19 AM | #7 | |
550
Rep 6,563
11-03-2006, 08:25 AM | #8 | |
25
Rep 251
11-03-2006, 08:33 AM | #9 | |
550
Rep 6,563
11-03-2006, 08:42 AM | #10 | |
11
Rep 613
11-03-2006, 08:44 AM | #11 | |
Rep 68
11-03-2006, 08:52 AM | #12 |
550
Rep 6,563
how do yall know these thing? reading books? Good to know some of the technical details. Now hopefully, some of you would understand why i like to take my car apart. I don't do engine or elctrical which is a good thing.
11-03-2006, 09:21 AM | #13 |
65
Rep 920
Drives: 06 E90 330i 6MT, 01 E46 330i
I have driven my friends 04 G35 6MT and I have and 06 E-90 and the clutch is way easier than the G's to use smothly I find it very hard to stall, even starting off in secound is no problem at all.
Mar 05 Build date,2006 E90 330i, Sport Package, Premium Package, TR MT-1's . V-1 Hard-wired power with custom V-1 Concealment Display . Rear fogs, Rear power outlet's, M short shifter knob, BlackLines, BMW Strut tower bar, CDV Delete, Front M3 wishbones + tension struts, BMW Performance shocks and springs, BMW Performance Brake kit F&R, OEM short shift kit. Rear M3 Guide rods and Wishbones.
2006 E-90 330i with 302,000 miles. |
11-03-2006, 09:23 AM | #14 | |
Smiling politely
165
Rep 7,931
E90 330i Black Sapphire 6MT | 991.1 C4 Platinum Silver 7MT
11-03-2006, 09:26 AM | #15 | |
550
Rep 6,563
11-03-2006, 09:27 AM | #16 | |
72
Rep 402
Drives: 2023 G01 LCI X3 M40i
My Garage | Phytonic Blue | Black Sensatec | Carbon Fiber Trim | Parking | Premium | Remote | Wireless | Harmon Kardon | 19" 887M Bi-color Midnight Grey |
11-03-2006, 09:53 AM | #17 | |
Fast Like Tiger
13
Rep 372
What year is your G? If it is an 04 or earlier, have you had your tranny replaced by the dealer at any point? My dealer replaced my tranny because of a problem with the regulators going into 3rd and 5th. It was supposedly a known problem as this particular dealer had a wall of 6MT transmissions out behind the shop from 03's and early 04s. Anyway, I know the head mechanic outside of my client-dealer relationship. He advised me that all of the new transmissions came with a replacement clutch and that they were required to install it with the new transmission. Apparently the original problem stemmed from partial engagement of the clutch plate. The new one is riveted or textured in some way that does not allow partial engagement (i.e. it would slip if you let the clutch out slow on an agressive takeoff and you would hear a grinding or chattering noise as the rivets slipped.) I had this noise after my transmission was replaced, was given this explanation, and advised not to worry about it. I've been driving stick almost exclusively for 14 years and have never burned through a clutch, so I know it's not me. Supposedly, the newer models have this same characteristic, though I have no independent confirmation. |
11-03-2006, 11:55 AM | #18 | |
550
Rep 6,563
11-03-2006, 11:58 AM | #19 | |
25
Rep 251
11-03-2006, 12:07 PM | #20 |
50
Rep 1,159
I've driven an s2k ... that clutch is absolutely beautiful compared to the e90 ... but Honda's in general are probably the most user friendly clutch I've ever driven. Sometimes I find they don't bite hard enough though.
No, the e90 clutch is not even remotely as user friendly as the s2k, and probably closer to the G. But it's by no means hard either. |
11-04-2006, 05:03 PM | #21 |
Rep 24
2005 G
[QUOTE=Hegemony]Previous G owner here.
What year is your G? Mine is a 2005 that the dealer says in fine so its all original. I hear it chatter (and so does the passenger) and usually a few times per trip, I FEEL it shake the car when pulling away from a light for example. I can even feel it through the pedal when releasing the clutch at speed going into 3rd or Its just what I expected in a 35,000 sport coupe I love driving stick. I'm hoping I'll enjoy BMW's 6mt. |
11-13-2006, 02:49 PM | #22 |
Fast Like Tiger
13
Rep 372
Sorry for not getting back to this earlier.
My G was an early 04, so much has changed between my model year and yours. When mine did chirp/grind it was usualy on a quick take off heading up hill (ex. turning left at a high traffic intersection between oncoming traffic.) And again, this was only after I had my transmission and clutch replaced under warranty. If you're concerned about the specifics on what you're experiencing in the G, I suggest going to your service center and being stern about having the head mechanic ride with you, duplicating it for him, and have him explain what's going on to you. They should be more than willing to do this, and if they aren't, take it somewhere else. Don't leave it up to them to drive the car when you're not around and figure out what's going on. In my 04, the explanation I was given was that the new clutch plate was not allowed to partially engage. It was either engaged or it wasn't. On or Off, etc. It could be that the 05's have the same type of clutch plate, but that's pure speculation on my part. Clutch feel is different between the BMW and the G. I do not have my E92 335 yet. It is still on order, but I test drove one several times before I decided to trade. Clutch feel to me is typical BMW style. I had a 98 M Roaster a couple of years back and it felt similar to the 335 I drove. Engagement point is in a different spot and has a wider range in the BMW, imo. |
