How to remove front dome lights *WITH sun roof*
02-19-2010, 11:11 AM | #1 |
Rep 25
Hi,
There was a DIY about how to remove the front dome lights with sun roof but I cannot figure out how to remove the front dome lights, the pictures wasn't clear enough. Can someone help me with clear picture or what so ever...? Thanks! |
02-19-2010, 01:59 PM | #2 |
Reading > Posting
20
Rep 220
I had to use a second set of hands to get my cover off (09 E90). The DIY trick of removing the sunroof gasket or edge material didn't work for me as it seemed to be glued in place. What I ended up doing was pulling the whole assembly towards me and down (away from the front of the vehicle) and having the other person use a small screwdriver to push the tab in. If you look at the rear dome housing you can see their location so person 2 knows where they are trying to aim. Option 2 is take a look at this DIY
http://www.e90post.com/forums/showth...light=euphoria and reference the picture where he talks about bulb location. There are arrows pointing to the clips I am referring to. Good luck with the install
02-19-2010, 02:11 PM | #4 |
81
Rep 4,541
I pryed the dome light cover off and swapped out the bulb... much much easier also same with the map lights...just remove the round black covering (they just slightly snap on off)
02-19-2010, 02:32 PM | #5 |
189
Rep 5,046
EASIEST WAY:
for the sun visors where they snap to the roof closest to the sunroof pop open the little tab and unscrew the screw. Pull out the piece. Do the same on the other side. Your head liner will drop down. |
02-19-2010, 03:47 PM | #6 |
just another bmw douche bag
195
Rep 3,640
There are 2 little metal tabs on the front corners of the dome light assembly (sorta in front of each map light). you can push them in with a screw driver and the whole thing comes right off. no need to take the headliner apart. it's really easy to miss the tabs though, it took me about 15 minutes of fiddling around with it until I realized where they were. after I found them, I had the whole dome light assembly dangling from the roof in about 30 seconds.
02-19-2010, 07:43 PM | #7 |
22
Rep 254
Tthat by far is the easiest way.. I tried pulling my trim for FOREVER and couldnt get it to move, so i did it that way and in 30 seconds i was able to get to the lights.
'07 SGM + DG 335i sedan|Navi|ZPP|Rear PDC|Euphoria 6k LED interior|Matte Black Grills|OEM Blacklines|MTEC A.E's|CF Roundels|Alufelgen 19" CS7 with 15/12mm spacers
If I buy something from you please leave me feedback My Portfolio |
02-19-2010, 07:51 PM | #8 | ||
245
Rep 4,494
I tried going through the sunroof but still didn't get enough room to reach inside and depress the prongs. After removing the visor holders I was able to reach the prongs directly from the front of the car (specifically, where the windshield meets the rearview mirror).
02-20-2010, 12:49 AM | #10 |
165
Rep 2,875
How i did it was wedging my fingers through the roof liner where it meets the front windshield. Once you get your fingers in there, there will be two metal tabs right where the map lights are, push REALLY hard and the whole dome light assembly should pop out.
I had to sit in the seats with my back facing the front windshield and seats all the way back in order to have enough room. Move the rear view mirror accordingly to make enough room for your hands on either side. Hope this helps. I have an 08 E90 FWIW.
'08 AW E90 335i PROcede V5 | BMS DCI | RR DPs | ETS FMIC | FORGE DVs | Stett CP | Vanguard | PSS10 |
02-20-2010, 04:17 AM | #11 |
189
Rep 5,046
Once you unscrew the two pieces holding the sun visors and pull the roof liner down a little bit you can look up and see the two prongs. If not, you can just put your finger in there and feel them. Press around, you'll find it.
02-20-2010, 10:14 PM | #14 |
195
Rep 1,985
02-21-2010, 11:31 AM | #15 |
Rep 25
04-26-2010, 04:22 PM | #16 |
Rep 49
Installing the front dome LED's
Mike,
Success!! The approach to the front dome light assembly from the windshield side was EASY. Maybe there has been a small change in the design/construction of later model e90's (Mine is an '09.), because the approach from the sunroof side was just impossible. Anyway, I am very pleased with he new look and additional light. You have a great product. I would add that I appreciate that you are very responsive to your customers. Best wishes, -Rick
