Why would this not apply to the 335 automatic?
11-02-2006, 09:58 AM | #1 |
14
Rep 710
The Porsche 911 turbo automatic is faster then the six speed manual 0-60 as well as through the quarter mile http://www.roadandtrack.com/article....rticle_id=4052 No doubt the BMW 335 has the better automatic with faster shifting times and an additional gear. Shouldn't it be faster than the manual version as well? If not why?
11-02-2006, 10:07 AM | #2 |
Moderator
7515
Rep 19,368
Some possibilities:
- Final drive ratio - transmission gear ratios - driver It would be helpful to compare numbers (BMW's are on their site, Porsche's may be too). |
11-02-2006, 10:28 AM | #4 |
Smiling politely
165
Rep 7,931
VWs with DSG transmissions are faster than their manual counterparts, too. I think this is mostly true for that type of auto tranny (uses clutches and I guess no torque converter).
E90 330i Black Sapphire 6MT | 991.1 C4 Platinum Silver 7MT
11-02-2006, 10:38 AM | #6 |
134
Rep 3,132
DSG is a sequential manual, the 335 is an automatic w/ torque converter.
Its the same reason why the new VW GTI is faster in "auto" than manual, even though DSG isnt really an auto but a sequential manual. I always shake my head when people get mad at vw/audi for ripping off porsche since porsche had it first, but uhh. same auto group guys. Its all VW's gadgetry. As far as speed goes, DSG is superior to its SMG/Ferrari F1 counterparts.
2018 R35 GT-R Cicio800 | 2007 E92 335i - RB Turbos, TC Kline DA Coils, HPA M3 Suspension, Quaife LSD, Stoptech BBK, JB4, FuelIT, AR Downpipes, RDSport Quads, Stett OC, Helix IC, Volk TE-37, Vorsteiner V-35, OSS Headlights | Retired - 2015 F82 M4
11-02-2006, 10:43 AM | #7 | |
14
Rep 710
11-02-2006, 10:51 AM | #9 | |
25
Rep 122
__________________________________________________
Future ED Car: E92 335i Montego Blue w/ Black leatherette and Grey Poplar Sport Package, Navigation, Bluetooth, Sunshade, Heated Seats, 6 mt BBS RG-Rs |
11-02-2006, 10:58 AM | #10 | |
14
Rep 710
11-02-2006, 11:21 AM | #11 |
274
Rep 6,510
both the automatic and the manual 335i have been tested to be 4.8 sec 0-60 from all the auto magazines... A manual transmission turbo car tends to loose more boost between shifts, and the boost has to re-build... an auto tranny can maintain the boost... which is why the auto porsche is faster, and which is why although the manual tranny may get more HP to the wheels, the 0-60 times are the same for the auto and 6mt... the auto gets more constant boost, and the mt gets more hp to the wheels...
In a way, YES, this does apply to the 335i, but since we use much less boost than the porsche does, it only helps out enough to make up for the other transmission losses compaired to the 6mt |
11-02-2006, 11:24 AM | #12 | |
Rep 1,035
I don't know if this explanation is correct, but like I said, it sort of makes sense.. Reduced wheelspin may also be a factor. |
11-02-2006, 11:26 AM | #13 |
Rep 18
I think with a car like that, it's just because a manual driver just can't shift fast enough. When you're getting the 0-60 down into the 3's, 10ths of a second start to matter more. The automatic may be getting less power to the ground, but the fact that it can shift faster makes up more than the difference.
11-02-2006, 11:26 AM | #14 |
Rep 89
The driver.
I'm 100% certain I can drive my 335i with step & paddles faster than I could one with a manual trans.
'07 335i Coupe
Space Gray/Blk/Drk Burl, ZPP, ZSP, 205, 2XA, 415, 494, 507 & 609 |
11-02-2006, 12:17 PM | #15 |
Moderator
7515
Rep 19,368
Regarding the boost issue -
Here are the gear ratios from bmwusa.com: Gear ratios - I/II 4.06/2.40 [4.17/2.34] :1 Gear ratios - III/IV 1.58/1.19 [1.52/1.14] :1 Gear ratios - V/VI/R 1.00/0.87/3.68 [0.87/0.69/3.40] :1 Final drive ratio 3.08 [3.46] :1 [] = automatic Now, when I look at this, I don't see how anyone could possibly make any conclusions about how the boost is effecting things, when the drivelines have vastly different gearing (especially the diff). IMHO. I'll bet the story is the same with the Porsche. |
11-02-2006, 12:34 PM | #17 |
Rep 155
The Porsche 997 TT is a AWD. Traction is the most important factor in 0-60 times. With an automatic transmission and AWD, the computer can finely control the amount of power delivered to each wheel to minimize loss of traction.
11-03-2006, 06:56 AM | #18 |
81
Rep 1,055
its because of the variable turbine geometry on the turbos ! when combined with an automatic transmission the angle of the turbochargers can be adjusted much quicker, hence providing maximum torque quicker. Thus expect a quicker 0-60mph time and a MUCH quicker 0-100mp/h time.
dont speculate with bull$hit http://forums.beyond.ca/showthread/t-109329.html
2007 CLS55 AMG / 2003 BMW 745Li
03-02-2007, 07:27 PM | #19 |
14
Rep 710
So I assume with the extra turbo boost the PROcede provides, the auto will definitely be faster than the manual. Just like the Porsche example, right?
03-02-2007, 07:38 PM | #20 | |
41
Rep 3,200
In response to your question: The way the Porsche works is different from the way the 335i works. The 335i has really small turbos whereas the Porsche's are bigger. I'm fairly certain the Porsche is running considerably more boost than the 335i. Another question to consider is if the AT can handle the increased power without premature failure. The 335d uses an AT because it has so much power but there have been conflicting post on weather the 335i has the same tranny as the 335d. The auto 335i is afaik as fast as or faster than the manual now, so I can't imagine it becoming slower than the manual with a PROcede.
328xi Coupe, Montego Blue on Black with Alum, Step, Sport, Premium, CA, PDC, Cold Weather (Damn Pennsylvania winters)
Current Mods: Heavy right foot - Planned Mods: Lightweight right foot |
03-02-2007, 07:51 PM | #21 |
Your resident 4um troll
125
Rep 2,020
LOL you auto grannies are really reaching into thin air trying to prove your slushboxes now, comparing a 335 auto to a porshe auto thats probably had close to a million more poured into it in the way of R&D
i would point out all the differences between the two cars and the actuall trannies themselves, but its like trying to get through a brick wall with some some firecrackers
RAWRrrrr
03-02-2007, 08:20 PM | #22 | |
41
Rep 3,200
