Lowering ... how far to go!?
02-01-2010, 06:54 AM | #1 |
59
Rep 743
Tempted to look at buying some Eibach springs. I don't want to have to drive like a chav in a corsa over speedbumps etc though.
- How low is too low? (any recommendations /photos kicking around?) - How is fitting? doable myself or a garage job? If so how many hours in a garage do you think? Thanks! |
02-01-2010, 09:36 AM | #4 |
25
Rep 482
Drives: F30 318d m sport
Rob mate you've caught the moddin bug! It's a bastard if it gets the better of u!I would say that if u plan to drop it that much your gonna have to uprate the struts. Did u say your milege was about 60k in another post? It would be your call but you don't want to get it dropped for the struts to start giving you bother! Also depends on your driving style, have you considered coilovers?
02-01-2010, 09:50 AM | #5 | |
59
Rep 743
I'm not sure what coilovers are? |
02-01-2010, 10:42 AM | #6 |
25
Rep 482
Coilovers are fully adjustable shocks and springs mate. It can get more complex depending on what you require and the money you want to spend. The more money the more adjusting you can do. Ride height, how stiff, rebound rate, camber etc. You also get fixed rate coilovers that have a fixed stiffness and it's just the ride height you can alter. With coilovers made you really need to get them set up by a proffesional. If you read steviehoops thread on his m3 he has spent decent cash on bilsteins and correct setup. If there not right you car can bounce all over the camp and it's not clever. My advice would be an eibach shocks and springs kit. Choose your ride height, wheather it be 50/40mm and some stiffer shocks. Get them fitted and you don't have to worry about them again. Plenty of guys have changed the springs with the m sport suspension because the shocks are a bit stiffer but you would be best changing your shocks with the se suspension. I've had coilovers before and I was constantly adjusting and it got to be a pain. The benefits with them also is you can get the car lower with larger wheels. But I don't imagine you want the slammed look. Just a decent drop to give the car a more aggresive stance and tidy up the gaps in the arches. Hope this helps bud
02-01-2010, 10:58 AM | #8 |
25
Rep 482
No problem bud. I'm sitting in my van skiving anyway. Can't turn the ignition on till at least 5.15 or the tracker will kick off!
02-01-2010, 11:08 AM | #10 |
25
Rep 482
Heating engineer mate. For a well known company
so if my laptop says I'm somewhere and my van ain't there it will flag up! There's always someone watchin mate.It's scary how accurate the gps is. I've seen my bosses laptop. It's starts as a map of the world, a few zooms and there's my van clear as day! |
02-01-2010, 11:14 AM | #11 | |
59
Rep 743
02-01-2010, 11:25 AM | #12 |
18
Rep 339
02-01-2010, 12:45 PM | #13 |
25
Rep 482
02-01-2010, 01:27 PM | #14 |
Panzer
18
Rep 405
Do not go for "sportline" they were fitted to my car by mistake. The box said Eibach pro but it was the wrong springs in the box. The car was a disaster with these search the forums and you will see the results. I would say 50mm is not wise on a road car but the choice is yours.
02-01-2010, 01:43 PM | #15 |
42
Rep 822
Eibach Pro kit spings give the best ride height imo.
Matched up with Koni Yellow adjustables is a great combination, or Koni FSDs if you want a more compliant, but slightly less dynamic ride. |
02-01-2010, 02:27 PM | #16 | |
Lamininist
82
Rep 1,030
I'm pairing my Pro-kit up with a set of FSD's on wednesday so should be able to comment further on this in due course. Cheers Yves |
