Blue Puff on Cold Start
01-30-2010, 02:15 PM | #1 |
59
Rep 743
I'm not sure if this is related to my "potential" mass air flow meter problem but i've noticed the past two days when I start the car I get a big puff of bluey white smoke from the exhaust. It only seems to do this from cold. If I let it tick over for a few seconds and then put my foot down it's all clear as a whistle (well as clear as a dirty diesel gets!)
Can't get it to a garage until next weekend, should I be worried!!? Need some reassurance more than anything! |
01-30-2010, 02:36 PM | #2 |
25
Rep 482
Drives: F30 318d m sport
Is that not a turbo issue? Seals or something possibly rob mate
01-30-2010, 02:39 PM | #3 |
75
Rep 2,927
Drives: E60 530D M SPORT
my one has been doing this for a few months i put it down to cold weather pulls fine when driving just a few mins when cold
01-31-2010, 02:47 AM | #5 |
Zummerzet Zyder Drinker!
112
Rep 5,541
Drives: '06 330D Le Mans Blue
You shouldn't get any smoke from a modern diesel upon start up!
Something is amiss. Robbo - how many miles on the motor?
01-31-2010, 03:39 AM | #6 |
75
Rep 2,927
are cars havnt got DPF so it normal for a little puff, audi's are much worse i was following my cousin 07 plate A6 and that was puffing for 5 miles before it got warm,
01-31-2010, 07:45 AM | #7 |
59
Rep 743
01-31-2010, 08:05 AM | #9 |
37
Rep 427
its normal on diesels
my vw passat tdi did same, puff of smoke on start up. changing glow plugs might inprove a bit, but i would not worry much about it. |
01-31-2010, 11:08 AM | #10 |
59
Rep 743
It did it this morning too, but I did notice that the "yellow rope" warning light was still visible when I accidentally pressed the start enging button.
Could this cause it maybe? I need to get into the habit of putting key in and waiting a few seconds I think! |
02-01-2010, 10:45 AM | #11 |
Dieseasal
204
Rep 6,881
pssh I've never payed any attention to the yellow squiggle thing I just start her up :S Didn't realise I was meant to wait. Googled for that dash symbol the first time it came up and didn't get any results!
Previously: 2003 Peugeot 206 1.6 8v | 2006 E90 320d M-Sport, 19" BBS CH, Full Ice-cold JL audio install, August 2010 Total BMW 6 page feature car. | 2003 Nissan 350Z GT Coupe 286BHP
Now:2010 E92 LCI 335d M-Sport |
Krisbiker20.00 |
02-01-2010, 10:47 AM | #12 |
59
Rep 743
It didn't do it this morning, I waited a few seconds this time. However I didn't see that yellow rope until I held the start/stop button down. Not sure how i'm supposed to wait for it to go out anyway!
02-01-2010, 10:51 AM | #13 |
25
Rep 482
The yellow rope is the glowcoil. You don't have to wait with modern denzils. They heat that quick that it's only on cold mornings you see it just to let you know if there is a delay. Your not doing any damage. Carry on just firing up as you do
02-01-2010, 10:56 AM | #15 | |
The Tarmac Terrorist
949
Rep 29,345
Drives: 997.2 GT3
My van does this every morning. Someone mentioned glow plugs etc. I turned on ignition and left it a fe secs till that light went out and it didnt do it. the 335d has never done it though
997.2 GT3
02-01-2010, 10:58 AM | #16 | |
59
Rep 743
So that explains why it stuttered and turned over a second or so before it fired... |
02-01-2010, 02:06 PM | #17 |
36
Rep 1,135
This may be a controversial post but I read my manual!! That said doesn't really answer the question. The 'yellow rope' is the pre-heat coil but the manual only says:
'When the engine is cold and the temperature is below approx 0 eg C, starting may be delayed by automatic pre-heating. In the instrument cluster, the preheat indicator light comes on.' Certainly it always used to be the case that you wited fro the pre-heat light to go out before starting a diesel bu this doesn't seem too clear |
02-02-2010, 03:37 AM | #18 | |
smokin' kipper
39
Rep 1,467
BTW http://www.e90post.com/forums/showth...highlight=rope Last edited by themetz; 02-02-2010 at 04:54 AM.. |
02-02-2010, 05:00 AM | #19 |
6659
Rep 15,858
On our push button start engines the 'delay', if any, is automatic. Most times even at around zero degrees the start is instant. I noticed when we dropped down to sub -10 degrees there would be a slight delay before engine cranking (from pushing the start button) and a flash of the glowplug light, as more time was needed.
Remember the glowplugs continue to work as necessary, up to a couple of minutes or so, on the warm up cycle, to assist combustion and emissions. Blue/white smoke, even a few seconds after a cold start, can still be a glow plug issue. HighlandPete |
02-05-2010, 10:03 AM | #21 |
yes....spelt with J's
55
Rep 963
Anyone know if NGK stuff will be ok for this car or is this another "BMW is best" scenario?
I too have the "lumpy as a top fuel dragster" start and lovely exhaust fog when cold. Regards Andy |
02-05-2010, 10:14 AM | #22 |
59
Rep 743
The guy from the garage said the plugs would be about £14 each, would that be non OEM ones though?
I opened another thread too, so sorry for asking in two places but anyone know how easy they are to fit? He mentioned the manifold cover needs removing? Easy job? |
