FS: OEM M3 Gauge Cluster
01-29-2010, 04:12 AM | #1 |
176
Rep 1,251
Drives: E92 M3
sold
2013 Scion FR-S
2009 BMW E92 M3 2008 BMW E90 335i 2005 BMW X3 3.0i Last edited by JHFW89225; 04-25-2023 at 02:27 PM.. |
02-03-2010, 09:10 PM | #4 |
176
Rep 1,251
Drives: E92 M3
bump
2013 Scion FR-S
2009 BMW E92 M3 2008 BMW E90 335i 2005 BMW X3 3.0i |
02-06-2010, 01:52 PM | #5 |
Bimmer Turbo Land
39
Rep 398
What if I just needed the right odometer RPM guage face?? Will you be interested to part out for sell?
Lumma BDK, M3 CF Hood, I-Forged Triumph 19", AP-6pt-360FR, AP-4pt-345RR, M3 CF Lip, ACS CF RFS, CF Grill, JB3 3.0, Stett DV CHG Pipe + DCI + FMIC, NST Pulley, F+R Full M3 Susp Kits, M3 E92 Q-pipes Ex, UR Catless DP, Ohlins C/O, Eibach Sway, M3 Dash Cockpit, CF Wrap Interior, M3 CF Pedals, M5 Shft Knob, LED ATW, OSS Design BlackOut LED Angel Eyes!!!
02-07-2010, 04:21 PM | #6 |
126
Rep 993
Drives: F85
Sweet, speedometer goes to 200....
02-09-2010, 06:02 PM | #8 |
176
Rep 1,251
Drives: E92 M3
bumped updated new pics !
2013 Scion FR-S
02-09-2010, 11:13 PM | #9 |
198
Rep 4,647
will it change mileage?
SGE92TT......................... 12.331 Sec @ 117.89 Mph............................POWERED BY
l BMS DCI l HELIX IC l FORGE DVs l RR OCC & CP & SCOOPS l AR 3" DPs l AE QUADs l BLISTEIN PSS10 l P3 VENT GUAGE l VISHNU PROCEDE V5 AUTOTUNE l Lots of Window Stickers |
02-10-2010, 02:12 AM | #11 |
176
Rep 1,251
Drives: E92 M3
To clarify, will not in any way mess with original car's mileage or computers. This is a purely plug n play cosmetic parts. Basically pull off your needle & replace with M3 ones, replace 335i ring with M3, replace 3 series tachometer with M3 ones.
2013 Scion FR-S
02-10-2010, 07:25 PM | #12 |
143
Rep 6,333
is the RPM calibrated?
2017 BMW M4 DCT Lease Transfer: https://f80.bimmerpost.com/forums/sh...8#post23736398
02-10-2010, 09:03 PM | #13 |
Lord of the Rings
86
Rep 470
Drives: 20 Audi SQ5,05 BMW 330i ZHP
Garage List 2021 BMW M2C [0.00]
2020 Audi SQ5 [0.00] 2019 VW Golf Alltrack [0.00] 2018 Ford F150 [0.00] 1977 VW Scirocco [0.00] 2005 BMW 330i ZHP [0.00] 2007 Audi RS4 [0.00] |
I have to ask. Do you get a functioning temperature gauge in the tach portion of the cluster?
Thanks, Chuck |
02-10-2010, 09:26 PM | #14 |
61
Rep 1,121
Im very interested in this but Im not sure whats included?
or how is going to work? is the whole cluster included so I can just swap it my 335i? does it needs calibration? what about speed is it accurate,since its setup to 200mph and the 335i only to 160mph? I dont want to break open my cluster, I want straight PnP |
02-10-2010, 09:40 PM | #15 | |
97
Rep 2,415
'16 f30 AW 340i M-sport 8-speed Auto BMW ///M Performance Power and Sound Kit with Carbon Tips / Gloss Black Performance grilles |
02-10-2010, 11:16 PM | #16 |
176
Rep 1,251
Drives: E92 M3
Take a look and see if your up to it, its fairly simple DIY, just be patient.
(Pics associated with each step are under the description): Tools: Torx T-10 Thin Flat-head screwdriver (I can't stress thin enough) Playing card I would recommend unhooking the negative terminal on your battery just to be safe. Move the steering wheel down as far as possible Pull it towards You fully - Now there is sufficient space to remove the cluster - it is not necessary to remove the steering wheel! Remove the 2 torx screws on top of the cluster Tilt the upper side of the cluster out of the dash to reveal the connector Open the safety latch on the connector, but leave the connector in place Move the cluster out between the steering wheel and the dashboard. Start by removing the 4 T-10s on the back of the cluster, circled in red. The cluster is still held together by clips (6 in total); 2 on the top, 2 on the bottom, one on each side. Work the bottom clips free first, then the sides. The cluster should be half-way apart now, which will make the top clips easier, don’t use too much force...nothing needs to be broken. Now that the cluster is in halves, grab the playing card and thin screwdriver. Slide the playing card under the needle, between it and the gauge face. This should keep the face from possible being scratched or indented. Now place a thin screwdriver between the card and the needle and gently twist upward. The needle will most likely bend away from the force of the screwdriver, use your hands to brace the clear/red portion and gently pull upward while you twist with the driver. You'll hear a slight pop when the needle is released from the friction fit, it should be easy to pull off after this. Try not to twist the position of the needle, the gears seem delicate, repeat for the other 3 needles. Now you need to remove the back portion of the cluster. It's only held on with one clip, simple to remove. Insert the screwdriver into the space between the socket and the back piece (circled in red), twist the screwdriver to one side to release the clips. I typically will hold the cluster by the black piece alone to help the clips release when I’m fooling around with the screwdriver. Not much force is needed. (4) Next you need to separate the circuit board from the white portion of the cluster. This is rather simple as well, just unhook the 4 clips circled in red. Place the circuit board someplace safe...preferable in an anti-static bag. Removal of the gauge faces is up, again pretty simple to do. There are two white clips that hold them on (circled in red). Pull the white clips outward, then push the clear plastic piece down...should pop out with relative ease. Do this for both the tachometer and the speedometer. Note the position of the speedometer backing plate, as the M3 one will need to be oriented in a similar manner for the cruise control indicator. The speedometer backing plate just simply pulls off, it’s clipped into place very loosely. The tachometer side is a little more difficult, as it's held in place with 4 clips, circled in red. Carefully work them free by pressing inward, working on at a time. Insert the white plastic ring, oriented in the manner show in the pic. It just clips into place with ease. Clip the tachometer backing plate onto the white plastic ring, it snaps in with ease as well. At this point it’s going to be loose as it’s normally held in place by a gear assembly. Choose the proper position your cars redline then double sided tape the plate and clip together so it won’t rotate. Press the gauge faces into place, they just slide down and snap back in. To reinstall the needles, start at 3k on the tachometer and press the needle down halfway, then rotate it slowly towards zero. This should apply enough force to zero the cluster as well as get the needle accurately aligned. It might take a couple tries, but make sure you get it right. Once its properly aligned, press the needle down fully. You should be able to get your screw driver between the needle and the gauge face still. Repeat this for each of the other 3, TAKE YOUR TIME! Reassemble the cluster reversing the steps detailed earlier.
2013 Scion FR-S
02-12-2010, 06:19 AM | #18 |
Rep 16
nvm ur just looking for the needles
Hi Joshua,
I'm very interested in the red needles. Do you have it? How much to send to Portugal? Thanks, Henrique
Henrique
Porto - Portugal BMW E90 320d |
02-18-2010, 03:38 AM | #19 |
176
Rep 1,251
Drives: E92 M3
bump!
2013 Scion FR-S
02-18-2010, 07:04 AM | #20 |
Rep 16
Bump! ??
Sorry, can´t understand you. Can you get me the red needles or not? Thanks
Henrique
02-18-2010, 02:22 PM | #21 |
176
Rep 1,251
Drives: E92 M3
i prefer to sell as a whole for now...
2013 Scion FR-S
02-24-2010, 04:36 AM | #22 |
176
Rep 1,251
Drives: E92 M3
bump !
2013 Scion FR-S
