01-27-2010, 05:49 AM | #1 |
136
Rep 677
To L or not to L?
Hey guys,
I'm going to be purchasing a brand new 50D in the near future but can't decide what lens i should get. I'm tossing up between the EF-S 17-55 f2.8 or the 24-70mm L series f2.8. I have read reviews of both and they both sound like awesome lenses. Pros of the 17-55mm : Its $400 cheaper, its wider (i like doing close ups etc. so the extra 7mm will most likely make a difference. Cons : It can not be used with a full frame sensor so when i upgrade to a 5D in 18months or so i will have to get a new lens. Apparently the L's are weather sealed but the 17-55 is not. Any other pros/cons? Any recommendations? I've been thinking I'm best off buying a lens for the camera I'm buying now and not the one i may buy in the future |
01-27-2010, 07:13 AM | #2 |
Apex Everything!
976
Rep 4,378
Drives: 2007 Honda S2000, 2017 GT350
EF-S is designed for a crop camera so comparing a EF-S @ 17mm and EF @ 24mm is a bigger difference than you think. It's not just a 7mm difference on a crop camera.
L lenses are (generally) going to be sharper, provide a much better image quality, bokeh, and better colors. After you own an L lens, you won't want to buy anything else. That could be a con. :P However, if you need something wider, then you might not have much choice. I bought the EF-S 10-22mm back when I had a crop. I was in the same scenario as you (only I wanted an ultra-wide). I wanted to get the L ultra-wide, but knew it wouldn't be wide enough on a crop camera. So I just went with the EF-S. Used it for a year and sold it when I moved to full frame. Lenses hold their value fairly well as long as you take care of them. Another option for you is possibly going with the 16-35mm/2.8 L? That could be wide enough for your needs on a crop for now and will be a must-have lens once you go full frame.
2011 E92 M3(Sold). 2007 Honda S2000 (Track Car). 2016 Cayman GT4 (Sold). 2017 Shelby GT350 (AKA Crowd Killer).
My pet project: https://stickershift.com |
01-27-2010, 08:27 AM | #4 |
I'm takin' the day off.
111
Rep 339
as per radiantm3,
go for what is best for your needs now. if you get the 17-55 you will be able to sell both. If cash is tight consider a secondhand 40D. 18 months is a long time in the photography world. the 17-55 is basically an L just without the red ring.
If I were to agree with you we would both be wrong.
01-27-2010, 10:14 AM | #5 |
1569
Rep 29,202
If you're only going for one lens, go with the 17-55, because the 24-70 is not wide enough on a crop body, so you need a second wide lens like the 10-22.
F10 520d M-Sport Alpine White | HRE P43SC 20x9+20x11 | Michelin PSS 255/35+295/30 | KW V3 Coilover | M5 Front Sway Bar + M550d Rear Sway Bar | 3DDesign Front Lip | BMW M Performance CF Spoiler | BMW M Performance Diffuser | BMW M Performance Black Grills | BMW M Performance Pedals | |
01-27-2010, 10:19 AM | #6 |
55
Rep 815
The 17-55/2.8 is widely regarded as the best zoom lens in the EF-S system. While its build quality isn't up to L standards its optical quality certainly is. The EF-S system isn't going anywhere, and if you go full frame you'll find it easy enough to sell the 17-55.
My advice would be to find one used for about $800-850. When/if you need to sell it you'll be able to turn it around with minimal loss. |
01-27-2010, 10:20 AM | #7 |
12
Rep 283
I would get the 24-70. I had the 17-40 and I just sold it bc i needed more reach instead of the wideness.
wtb: tial bov w charge pipe, Injen intake |
01-27-2010, 12:05 PM | #8 |
95
Rep 2,012
I'd say if your planning on going to FF in 18 months, i'd still say you should pick up the 17-55 2.8 IS because of the 3 stop IS, it's a very sharp lens and a lot of pro photogs keep a crop body with them just so they can use this lens. I think during the 18 months, the 17-55 is a better focal range for you to develop your photographic eye and reflexes which i think is more important than gear. And besides, the 17-55 2.8 IS keeps it's value very well and there doesn't seem to be a successor in line unlike the 24-70 L which is due for mark II.
IMO, buy a used 17-55 2.8 IS, and sell it to fund for a 24-70L when you go FF. |
01-27-2010, 12:05 PM | #9 |
167
Rep 2,355
umm.. 17-55mm f2.8 is just as sharp as the 24-70L. 17-55mm also has IS, while 24-70L does not. It makes a difference if you do a lot of indoor shooting or your hand isnt exactly steady.
The only real downside of 17-55mm is, IMO, it is not FF capable and it is not L. Weather-sealed or not, that doesnt really make a big difference unless you shoot in extreme conditions often (say in desert most of the time, in extreme cold or hot weather, etc). 24-70mm is not even close to wide enough if you use that as your only lens and walk around lens. OR get this 16-35L MKII. its wide enough, its a L, its sharp. In Summary, 17-55mm IS USM is certainly built like a L and performs like a L. PS. You're getting a 50D? I might be considering selling mine. (in excellent condition and still have all original box/manual/everything). Have used this for about 9 months now. PM me if you're interested.
2015 F80 Fully loaded (minus the CCB) YMB M3 / Individual Amaro Brown
BBS | KW | Vorsteiner | IND | Akrapovic | BMW CF Performance Interior | Brembo | Eibach 2008 E92 335i (sold) |
01-27-2010, 12:06 PM | #10 | |
167
Rep 2,355
01-27-2010, 12:06 PM | #11 | |
1154
Rep 1,543
Depends on what you tend to shoot, though (obviously). I only take occassional telephoto/zoom shots so I just suffer without. 90+% of my pix are close or require something wide so I'm a little biased...
- Jeff
bosstones' flickr |
01-27-2010, 09:32 PM | #12 | |
71
Rep 1,027
i want something fast in this range. What a horrible hobby. I went the second hand 40D route. great camera...probably too much for my hands. but i would say 'give a 50d a hard look' as i think the prices are better than when i purchased courtesy of 7d and you may be able to get another stop of useable ISO. 17-55 FTMFW
Just like Indiana...I love my whip
01-28-2010, 04:07 AM | #13 |
95
Rep 2,012
As a matter of fact, I have a LN 50D for 850 and it comes with canon grip, extra battery and has every that came with it brand new except for the box. I do have the box for the battery grip tho. Let me know if your interested. I can take some pictures as well.
01-28-2010, 05:32 AM | #14 |
136
Rep 677
Thanks guys, some very valid points. I think i will be going for the 17-55 as its got the IS and because it has a much for usable focal range for my style of photography.
PNF - I have just purchased wheels for my car so it looks like it will be at least another month until i have some spare cash for a camera. That and being in Australia i figure i'm better off buying one over here so i have the warranty etc. |
