328i = SULEV
10-23-2006, 05:41 PM | #1 |
21
Rep 106
328i = SULEV
Interesting find...
http://www.epa.gov/orcdizux/datafile...MON_INI_R1.PDF It has 2 listing for the 328i, one is ULEV and one is SULEV (this is for US only). What's the deal? Will it be a special California version only maybe? Anybody have details of engine differences? Thanks. |
10-23-2006, 09:12 PM | #8 |
United States Marine
318
Rep 2,748
no, Sulev cars don't get diamonds, as far as I know...
CALIFORNIA 328 BUYERS! DON'T GET A SULEV! it will be gutless, and boring. get the REGULAR 328i. The e46 Sulev (M56) has more engine problems than ANY other e46, and has NO GUTS. very slow. Matt |
03-11-2007, 04:51 AM | #9 |
Rep 16
Sounds like you know about BMW SULEV engines... Please elaborate on the differences between a SULEV & a ULEV car...
03-11-2007, 09:31 AM | #11 |
STEVIL Empire
219
Rep 6,297
I have been doing research on this since I got my VIN and found out my 328i was being built with the N51 engine. This is what I know so far.
This is from BMW introduction of 2007 engines: N51 Overview In order to comply with SULEV requirements, the N51 is another variant of the N52 engine. There are various measures to meet the EPA/CARB standards, some of which are familiar from the previous SULEV (M56) engine. Some of the SULEV measures for the N51 include: • Near engine catalyst with additional underbody catalyst • Secondary air system • Optimized combustion chamber geometry in cylinder head • Modified piston crown for lower compression • Plastic valve cover with integrated crankcase vent valve and separator (from N52KP) • Stainless steel fuel lines with threaded connections • Radiator with “Prem-air” coating • Throttle system - EGAS08 carried over from N52KP • Airbox with Activated carbon filter for EVAP control • Purge system pipes are made from “optimized” plastic There are 5 states that adhere to CARB SULEV engine requirements. CA, NY, ME, VT & MA. The N51 is being used in both auto and manual trannies. It is basically the same engine as the N52 with slight modifications that reduce the CO2 emissions. As far as performance, I'm told there is no perceptable difference to the N52 other than that it adds about 30 lbs. to the car. I'm waiting for my car to get on a ship in Bremerhaven and I will gladly post my impressions after I take delivery. If anyone else has the N51 and is currently driving it, maybe you could post your impressions as well.
2007 E92 328i 6MT-Space Gray/Black Dakota/Gray Poplar w/heated seats-PCD 4/27/07 (SOLD)
2009 E90 328i xDrive 6AT-Space Gray/Oyster Dakota/Dark Burl Walnut w/ZPP,ZCW,Xenons-ED 4/17/09 - Redelivery 5/30/09 (SOLD) 2014 E84 xDrive28i 8AT-Alpine White/Black Nevada/Silver Matte w/ZMV,ZLP,494 - DD 3/14/14 (SOLD) |
03-11-2007, 09:42 AM | #12 |
418
Rep 12,276
Whew! Sure am glad I'm getting the REAL engine in my car!
Just kidding Steve... Ain't I a rascal?
I think it is bad luck to be superstitious |
03-11-2007, 12:41 PM | #13 |
45
Rep 1,738
Which should equal less power. Also, there was some discussion in another thread as to why the curb weight of the 328 has increased so much vs the 325. I suspect that the weight of the N52 328 has not increased very much. It looks like the N51 may be maybe quite a bit porkier due to the added emissions equipment. Less power and more weight is usually not a good thing.
2006 325i - Sparkling Graphite
2000 S2000 - New Formula Red 2007 Chev Silverado crew cab Z71 |
03-11-2007, 02:59 PM | #14 |
STEVIL Empire
219
Rep 6,297
If I feel I've been shortchanged on the power rating, I'll have the engine dyno'd and if it's it not within advertised specs, I would think a class action suit would be in order. Thinking that BMW isn't that shady, I would hope this isn't the case.
We shall see.
03-11-2007, 04:27 PM | #15 | |
1676
Rep 6,593
Honda for example in Cali has 2 HP less than the rest of us...I drove them both and did not feel any difference. Why is the Bimmer screwing things up so much? |
03-11-2007, 04:28 PM | #16 |
38
Rep 1,762
How do you find out if you have the N51 or the N52?
2008 E90 335i | Silver Grey | Terra | Piano Black | ZSP | ZKO | ZAT | ZKI | ZPL | ZKL | 2007 E91 328xi | Black Sapphire | Terra | ALuminium | ZKO | ZKI | ZPL Past Cars: 2004 ///M3, 2002 E46 330xi, 2003 GTI 1.8T, 1996 Neon |
03-11-2007, 04:34 PM | #17 |
STEVIL Empire
219
Rep 6,297
Either look on your engine block where it is inscribed or let me know the 4-7 digits of your VIN and I'll be able to tell you. PM me if you want.
03-11-2007, 04:48 PM | #18 |
38
Rep 1,762
Thanks buddy.
03-11-2007, 05:31 PM | #19 | |
418
Rep 12,276
But seriously, don't let your blood pressure get too high until you get the car and give it a workout. The power might be measurably different to instruments but not to the driver. But if there really is a problem, this is a matter for your legislators more than BMW. I'm certain BMW would rather leave the engine pure. Oh, did I mention I'll have the N52? Just wondered if I'd mentioned that...
03-11-2007, 05:33 PM | #20 |
STEVIL Empire
219
Rep 6,297
This is where you can put your N52
03-11-2007, 05:33 PM | #21 |
51
Rep 1,928
hybrids are a joke!!!!!! biggest car company con right now!!! i could buy a diesel and kill a prius and get my constant 40 mpg which is what i KNOW some prius owners get around me!!! hybrids are a joke right now in the future they will rock but right now...THEY are pointelss the technologie just isn't there...esp when i can take one of the lexus modesl the g something and look at the NON-HYBRID car and it has LOWER annual gas consumption than the hybrid!!!!!!! i mean that is a joke in itself!!!!! why do they even bother!!!! when i saw that i was like why do people buy these toyota's pieces oh shiat!!!! diesels are way way more eficient now and california hates them...stupid cali!!!!!! don't vote for arnold he is an idiot!!!!! so funny how they voted for him and now look things just keep getting worse!!! even though i don't think he is too concerned with emissions..i mean he is the hummer man!!!!!!
________ Walmart Gift Cards Last edited by purplewidow; 03-29-2011 at 07:36 PM.. |
