Guys diagnose my fault and give me an approximate cost. Going dealers on Thursday...
01-19-2010, 07:13 AM | #1 |
GTR'in it
169
Rep 4,434
Hey guys. Service time. Need replacement of brakes (with sensor too I assume). Couple of services that have just gone red too . Not sure what they are...
(pics are blurry as my cousin took them whilst driving) Any idea of cost if I take to the stealers?? Want to know what I'm paying for and any alternatives I have... Car is running fine though. |
01-19-2010, 07:21 AM | #2 |
1867
Rep 13,043
Drives: BMW M340I G20
1st Service due, cost will depend on mileage and or time since the last service
2nd Rear pads 3rd Brake Fluid |
01-19-2010, 07:26 AM | #3 |
GTR'in it
169
Rep 4,434
01-19-2010, 07:29 AM | #4 |
1867
Rep 13,043
Brake fluid is every two years, so 12/2009 is when it should have been changed.
01-19-2010, 07:35 AM | #5 |
GTR'in it
169
Rep 4,434
01-19-2010, 07:39 AM | #6 |
1397
Rep 8,083
The car on the lift means a full service as opposed to oil service. Fluid will be £80, brakes £100 if only pads needed, service itself about £250.
You're looking at about a monkey all in.
Ian
Current: 2021 G21 330i M-Sport Previous: 2018 A6 Avant S-Line MMI+, 2014 F31 320d M-Sport, 2013 F10 520d M-Sport, 2011 F10 530d M-Sport, 2008 320i M-Sport Coupe, 2002 325i, 2001 318i valvetronic, 1998 318i, 1996 525i, 1990 Porsche 944S2 |
01-19-2010, 07:39 AM | #7 |
Moderator
322
Rep 5,493
Is the car in warranty? If not, don't go to a dealers - go to an independent as it's likely to be cheaper. Try Bexley Motor Werks in Bexleyheath
You'll be needing a few things doing, depending on which service interval it is and the mileage... Oil change + filter Microfilter Air filter (possibly) Rear brake pads Brake fluid You can buy your own oil and brake fluid if you want, and have the service place do the rest.
... ... DMS Remap Review ----- Quaife LSD Review ----- Hartge Antiroll Bars Review ----- Bilstein PSS10 B16 Ride Control Review ----- Detail by ShineOn ----- Paintshield Review |
01-19-2010, 07:58 AM | #8 |
1867
Rep 13,043
If under warranty haggle the quote and shop around, just because the cars booked in doesn't mean you couldn't change who does it.
01-19-2010, 08:29 AM | #9 | |
1545
Rep 8,970
12/2009 was - wait for it - last month!! yep that's right - last month, so whatever it is is now 1 month overdue! magic! |
01-19-2010, 08:46 AM | #10 | |
GTR'in it
169
Rep 4,434
I was referring to the symbol itself. I know the service is overdue you plonk! I referred to the manual I got and couldn't see the symbol. In the manual it states if the red exclamation mark with the brackets around it is lit, means brake fluid level is low NO reference to the 4th pic I put up. And correction I meant 4th pic in post 3 |
01-19-2010, 08:58 AM | #11 |
The Tarmac Terrorist
949
Rep 29,345
Drives: 997.2 GT3
Hilarious Sunny, Love that Pic!!!!
997.2 GT3
01-19-2010, 09:52 AM | #13 |
GTR'in it
169
Rep 4,434
01-19-2010, 10:16 AM | #14 |
GTR'in it
169
Rep 4,434
It is not a full service. The first pic comes on when I start the car and usually means from my experience that I need the overdue services to be dealt with. PLUS I've had an oil change and filter when I had the fiasco with my car stopping randomly. I've got ages till I need to change the Microfilter likewise with any other service after these two.
This brings me to perhaps getting brakes and brake fluid done at Kwik Fit or Mr. Clutch (local). Doesn't seem like I need to do it at the dealers or a certified BMW specialist do I? |
01-19-2010, 10:21 AM | #15 |
1397
Rep 8,083
On mine I get an oil can for an oil service and the car on a lift for an inspection. Anyway, if you're out of warranty get it done elsewhere or DIY. The Mr. Clutch might not have the ability to reset the "mileage to go" on the brake pads but the other warnings you can reset yourself.
Ian
01-19-2010, 10:42 AM | #16 | |
GTR'in it
169
Rep 4,434
£90 for brakes £24 for fluid |
01-19-2010, 11:35 AM | #17 |
Rep 19
Do the brakes yourself.. really easy and it's about £30 for pads and £20 for sensors from a blueprint. When the pad sensors are gone it triggers the red lift light and the parking brake light. Once the sensor is replaced it will then tell you what still needs to be done. (you could always just connect the two wires in the brake sensor cable to fool it into thinking it's been done and then see what else is outstanding..
01-19-2010, 02:23 PM | #18 | |
72
Rep 797
Drives: BMW 320d Le Mans Blue
01-19-2010, 06:06 PM | #19 | |
Rep 19
Any idea how they do work? Just for personal knowledge.. |
01-20-2010, 07:26 AM | #21 |
15
Rep 295
It is every 2 years for the pollen filter. Normally done at same time as brake fluid change as the covers are off and it is cheaper in terms of labour cost to do the 2 together.
01-20-2010, 11:21 AM | #22 |
72
Rep 797
They hit the disc early on and start to wear down, the resistance changes and the miles remaining in the brake pads is estimated and displayed on the dash..... or something like that
