Coby Wheel
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Regional Forums > UK > UK Technical Forum > No oil dipstick-i am shocked
      01-11-2010, 11:05 AM   #1
bakili
bakili's Avatar
37
Drives: bmw e90
not old 318i  [0.00]
I just realise today, there are no oil dipstick on my e90 318i.
How stupid is this!?
Anyone experienced any problems with oil level sensor?
Is there any way to check oil level manually at all?
really this stupid feature puts me off from car, i will not feel confident taking my car on long jorney.
      01-11-2010, 11:09 AM   #2
flyfs6
49
Drives: BMW i7
Its should be there on right hand side of the engine (when you're facing it), its not obvious is all.
      01-11-2010, 11:10 AM   #3
willhollin
willhollin's Avatar
England
268
Drives: VW T5
Some of the petrol engines don't get one.
      01-11-2010, 11:11 AM   #4
E92Fan
Moderator
E92Fan's Avatar
322
Drives: .
On some of the BMW engines there's no way to check oil manually with a dipstick - you rely on the oil level sensor. No reports of them going wrong either to be honest. You can check the level of the oil electronically on the iDrive if you have it, or using the on-board computer via the info display within the speedo housing. Toggle the up/down lever on the indicator stalk to cycle through the menu until you see the oil can symbol, then press the reset button on the end of the indicator stalk to check the oil level.
You'll get used to it... I regularly take my car on long journeys (2000 mile round trips) and there's never a problem with the oil.
      01-11-2010, 11:20 AM   #5
creepy coupe
creepy coupe's Avatar
1867
Drives: BMW M340I G20
2015 BMW 435d  [0.00]
2009 335i  [0.00]
I had an oil change last month, I left the dealers and checked the level while still on the forecourt, it read full, the next day after only 6 miles, I checked it again and it was below half, I topped up to the max which took .75 of a litre, and it’s has stayed that way ever since.
First miss read I’ve had though.
      01-11-2010, 11:24 AM   #6
bakili
bakili's Avatar
37
Drives: bmw e90
not old 318i  [0.00]
I dont have idrive, but have on board computer, which shows me oil level.
But can you imagine, i drive some where on motorway at 2am in the morning, and oil light comes on to top up 1 litre? Would you trust sensor? What if sensor fault? You put liter of oil-damage engine. If you dont put oil-damage engine?
Tow to dealer, and find out oil sensor was faulty or function correctly
      01-11-2010, 11:26 AM   #7
willhollin
willhollin's Avatar
England
268
Drives: VW T5
You would normally add 1/4 litre of oil and then recheck the level. You are better to have less oil than required rather than it being overfilled.
      01-11-2010, 11:34 AM   #8
E92Fan
Moderator
E92Fan's Avatar
322
Drives: .
Even if it says you need a top up as a first warning, there's more than enough oil in there for the engine to work properly. And as Will says, you add a 1/4l first, check, then add more if necessary.
And have you considered what would happen if you didn't have an oil level sensor? You drive on motorway at 2am, the engine is pissing oil out everywhere but you have no clue until the next time you check your oil, or worse still your engine seizes up...!
      01-11-2010, 11:42 AM   #9
bakili
bakili's Avatar
37
Drives: bmw e90
not old 318i  [0.00]
That true, but anyway, oil dipstick will give more accurate reading-i miss it
      01-11-2010, 11:48 AM   #10
dxb335d
The Tarmac Terrorist
dxb335d's Avatar
England
949
Drives: 997.2 GT3
No more accurate, more ''manual''. Feels normal and makes you feel comfortable knwoing you have checked. I wouldnt like trusting a computer either.
997.2 GT3
      01-11-2010, 12:15 PM   #11
AndyR
Drives: M3
Do you know if the 335i has a manual check? I want to do an early running in oil change myself and would prefer to check with a dipstick rather than on the idrive!
      01-11-2010, 12:18 PM   #12
E92Fan
Moderator
E92Fan's Avatar
322
Drives: .
No it doesn't.
If you do the oil change yourself, you'll need 6.5 litres of oil. Use either the Castrol 5W-30 or better yet, a Silkolene 5W-30 (available from opieoils.com) And you'll obviously need an oil filter (£10)
      01-11-2010, 12:26 PM   #13
AndyR
Drives: M3
Thanks,
Pre-emted my next question!. Cars has gone 2k miles now and I feel happer changing out the oil (even if officially it is not required).
I have purchased the silkolene pro s from opieoils before (oilmansi) as I used it in my S2000 for many years! - great oil and great company!. On offer too at the momenn via a link from the s2000 owners club - circa £35 for 5litres which is a very good price indeed!
Andy
      01-11-2010, 12:31 PM   #14
E92Fan
Moderator
E92Fan's Avatar
322
Drives: .
That's a very good price! If you're going to be going down the Silkolene route, then you should buy the ProS 5W-40 - it's the best oil out there bar none for the 335i engine.
      01-11-2010, 12:47 PM   #15
lesfinnie
Panzer
lesfinnie's Avatar
Scotland
18
Drives: 335d SE
2007 335d se  [0.00]
On my previous car, which had a dipstick but I never checked it, I just relied on the oil level indicator and never had a problem in seven years
      01-11-2010, 02:04 PM   #16
doughboy
doughboy's Avatar
1545
Drives: 2018 M2 Comp 6MT
Tony,
OT I know,
If, as I do, I change the oil every 8K ish, do I still need to use LongLife (LL04) approved oil?
Can I use other high performance, perhaps better, non LL oils instead?
      01-11-2010, 02:11 PM   #17
ElegantSpoon
There I was balls deep in a...
ElegantSpoon's Avatar
29
Drives: BMW E90 320D
I think your a little paranoid.
BMW E90 320D Sapphire Black, Angel Eyes, BMW Performance Extras, Carbon Fabric Trim
      01-11-2010, 02:20 PM   #18
beemerbird
beemerbird's Avatar
England
172
Drives: Merc diesel
O/P I wouldn't worry about it. My 330i didn't have a dipstick and never had any problems.
Neither of my Porsches had a dipstick and again never a problem. With respect a Porsche Turbo is guaranteed to use a certain amount of oil every 1000 miles, certainly much more than your E90 probably ever will. I only had a display showing segments as to the oil level via an oil level sensor and you know what, it worked fine.
      01-11-2010, 02:21 PM   #19
bakili
bakili's Avatar
37
Drives: bmw e90
not old 318i  [0.00]
only bit
      01-11-2010, 03:12 PM   #20
Tunna_uk
Tunna_uk's Avatar
72
Drives: BMW 320d Le Mans Blue
as a time served mechanic, I too was a little perplexed at not having a dip stick, but soon got used to it.
The thing I miss is being able to look at the colour of the oil.....
I think BMW gone down this road because most people NEVER check the oil between services, so this is to prevent engine damage (warning system level warning etc)
Only car nuts/ petrol heads check oil levels
      01-12-2010, 03:43 AM   #21
doughboy
doughboy's Avatar
1545
Exactly my issue too.
I suppose you can peep inside the filler cap, but there's only oil film visible in there.
But its not the same as seeing a nice, clear, golden drop of oil on a dip stick.
      01-12-2010, 04:23 AM   #22
xenon
xenon's Avatar
England
1397
Drives: 2021 G21 330i M-Sport
Luddites. For years you've always relied on a pressure switch for pressure so why not a sensor for level too? That way the car can alert you to low level that 90% of owners never check.
Not only that, it's a hot-wire sensor so it's fail-safe. If the sensor itself fails you will get an immediate notification - you wouldn't just drive around for miles with the level gradually falling in blissful ignorance.
Get with 2010.....
You'll be moaning about no choke next.
Ian
Current: 2021 G21 330i M-Sport
Previous: 2018 A6 Avant S-Line MMI+, 2014 F31 320d M-Sport, 2013 F10 520d M-Sport, 2011 F10 530d M-Sport, 2008 320i M-Sport Coupe, 2002 325i, 2001 318i valvetronic, 1998 318i, 1996 525i, 1990 Porsche 944S2
