BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Suspension | Brakes | Chassis > Springs performance purpose
      12-25-2009, 06:51 PM   #1
ni8shadow
ni8shadow's Avatar
43
Drives: e90 328i 6MT
Besides determining ride height and lowering center of gravity, do springs have a performance purpose?
I have the BMW perf. susp. dampers on my 328i but the springs I have are from a 335i. Since the 335i is heavier I noticed that my drop is not as low as other 328i's with similar setups. Never bothered me much as it makes going up curbs easier. But I wanted to know if I am missing out on anything performance wise.
      12-25-2009, 10:24 PM   #2
D.yi
52
Drives: SB e92 335i
why do you need to get up curbs easier?
      12-25-2009, 10:28 PM   #3
SV Concepts III
375
Drives: BMW Duh
Aftermarket springs are typically stiffer to reduce body roll and lower to lower center of gravity. I don't have the exact spring rates off hand but if the 335 spring rates are stiffer, then you will notice reduced body roll as well.
      12-25-2009, 10:37 PM   #4
ni8shadow
ni8shadow's Avatar
43
Lol meant drive ways. Some are steeper than others.
So since I have 335i springs, does that mean better performance due to the extra stiffness?
      12-27-2009, 02:49 PM   #5
marconi118
94
Drives: 06/07 e93 335i
what is the mark on the springs? T3 D5 etc...
The higher number indicates the stiffer spring. the letter indicates if it is performance spring or ZSP or regular....
      12-30-2009, 11:15 PM   #6
ni8shadow
ni8shadow's Avatar
43
Springs say D5, does that mean zsp?
      01-02-2010, 12:36 AM   #7
luckyu
luckyu's Avatar
25
Drives: 2007 328i, 1998 328i
Yes, you are missing out, because the BMW perf shocks are matched to the BMW perf springs, and because the perf springs are stiffer. Add the springs and your car will turn in better, roll less, and have a better, smoother ride.
I installed BMW perf shocks on my 328i without changing the springs, because I was told they were designed to work together. That information is incorrect. I later installed the performance springs, and experienced the very changes I listed above.
      01-02-2010, 05:06 AM   #8
ni8shadow
ni8shadow's Avatar
43
When the perf kit first came out, Tischer did tell me that if you had zso springs you didn't need the yellow perf springs. With the new kit apparently you do. I wonder if the dampers are different now.
