BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > DIY Guides/ Discussions
Mporium BMW
      12-24-2009, 01:10 PM   #1
kmarei
kmarei's Avatar
Egypt
685
Drives: 2018 Audi RS5 coupe
2018 Audi RS5  [0.00]
Exclamation Camaros kit replacment ?
i saw this the other day on the best buy website http://www.bestbuy.com/site/PAC+-+Lo...9046098&st=pac TR-4&cp=1&lp=1
i think this can be used to trigger a relay that powers an HID kit
so the oem wire feeds this low voltage trigger which in turn activates a relay which turns on the HID Kit
this way you get the same functionality as the camaross kit but for a total cost of $20 (2 low voltage triggers) and the HID kit (around $75)
just make sure you get a kit that comes with the relay, so you don't use the OEM angel eye wire to power the HID. The wire is not thick enough and might cause problems
the low voltage trigger activates at 0.8 volts
so it will turn on and remain on irrespective of if the Angel eyes were being dimmer by the car or not
i.e full brightness all the time
      12-24-2009, 01:41 PM   #2
MMMorish
Just call me J.J. McClure
MMMorish's Avatar
156
Drives: E92 M3 & C4 Corvette
Huh?
MODS: Meisterschaft GT Racing Exhaust / BMC Air Filter / UUC SSK & DSSR (Modded)/ RPI Scoops / Passport SRX Hardwired / Custom Wrap 3M Clearbra / 20% Tint / 50% Windshield Tint / Key Hole Delete / Matted Out Accessories / VRS Type II Diffuser / Smoked Reflectors / Euphoria 6K LED Interior Lights / Rear Fog Light Mod / 6000K HID's / 6500K LUX H8 Angel Eyes / RDash License Plate LED Kit / LED Xenon Reverse Lights
"M3 drivers have no friends"
      12-24-2009, 05:23 PM   #3
dillon733
dillon733's Avatar
96
Drives: Jet Black e92 M3
Originally Posted by MMMorish View Post
Huh?
+1
      12-24-2009, 08:38 PM   #4
kmarei
kmarei's Avatar
Egypt
685
sorry, let me rephrase it.
In the stock system, when your headlights are off the angel eyes get about 10.75 volts
but when you turn your headlights on, the voltage to the angel eyes is lowered to 3.3 volts.
if you hook up a regular HID kit for the angel eyes, when the headlights are off, the HID kit gets enough voltage to turn it on and everything is fine.
but when you turn your headlights on, the voltage goes to 3.3 volts, which is not enough to turn on an HID kit. Even if you use a relay, most relays need at least 7-9 volts to activate.
this is why people paid over $200 for the camaross kit.
with this PAC low voltage trigger, it needs 0.8 volts only to activate
so it would turn on with 10.75 volts (headlights off) or 3.3v (headlights on)
so the OEM wire would go to this PAC low voltage trigger and from there it turns on a relay which connects the power wire to the HID kit.
      12-26-2009, 01:13 PM   #5
E92-Lighting
E92-Lighting's Avatar
858
Drives: Next Generation LED Lighting
not a bad idea...
      12-26-2009, 01:42 PM   #6
kmarei
kmarei's Avatar
Egypt
685
Originally Posted by E92-Lighting View Post
not a bad idea...
you can actually use this with non HID bulbs
like the camaross elite kit
which basically means you give your angel eyes the full voltage not the lowered OEM voltage
so even your regular OEM bulbs would look brighter/whiter
and GP thunder would look brighter/whiter as well
all you need are these low voltage triggers and 2 relays
      12-26-2009, 06:30 PM   #7
major_kusanagi
SWARM & COIN
major_kusanagi's Avatar
17
Drives: 09 AW/FR/CF E92 M3
So, let me see if I get it right. Positive and ground in the engine bay then from there to the triggers then from there to OEM wiring and to GP h8. Is this what you are suggesting?
      12-26-2009, 06:59 PM   #8
kmarei
kmarei's Avatar
Egypt
685
yes so the trigger just functions as a switch for the positive of the battery
only connecting the positive to the bulb when the OEM wire gives it power
i.e it will function exactly the same as the OEM bulb, but brighter.
day time running, parking light etc will all function as stock
but brighter
you'd still need a resistor connected to the OEM wire so the car doesn't sense that the bulb is no longer connected to it
this is what i did but i hand't tried the low voltage triggers so my angel eyes turn on and off with the AUX wire in the engine bay.
which is not the same as the OEM wire
i used to have the Angel eyes turn on as soon as i unlocked my car
now they only turn on when the key is in the ignition
i will install the low voltage triggers in my setup, once i am done with the stereo upgrade
installing SWS-8s and an amplified subwoofer in a tiny enclosure to the back of the ski hatch, so it fires into the car.
      12-26-2009, 07:07 PM   #9
major_kusanagi
SWARM & COIN
17
Thanks!! Any resistors you'd recommend? Been experimenting with AEs.
but brighter
      12-31-2009, 04:31 AM   #10
r9ndy
Drives: 05 545i
10 Ohm 10W 5% Wirewound Resistor at radio shack
http://www.radioshack.com/product/in...ductId=2062291
would do the trick
      12-31-2009, 11:18 AM   #11
MMMorish
MMMorish's Avatar
156
Someone please put a plug n' play kit together and market this thing at a cheaper price than other kit out there. Oh ya, make it better than the other ones too.
Thanks
      01-12-2010, 11:46 AM   #12
alex310
71
Drives: 335I Coupe/M3 Sedan
You rock man, you only need one of these, because relay kits only need one signal, and two resistors and a HID kit with a relay kit. Man your great, I'm going to try this today!
      01-12-2010, 02:18 PM   #13
kmarei
kmarei's Avatar
Egypt
685
let me know how it goes
i want to do the same thing
just too busy doing a stereo upgrade now
the reason i said use 2 is if you ever use your parking light
you need to be able to individually turn on and off each light
if you don't then 1 is all you need
      01-12-2010, 02:20 PM   #14
kmarei
kmarei's Avatar
Egypt
685
i'm also going to order another one of these to connect to the remote wire of the head unit
so i can activate the amps, subs etc with direct power, not overload the remote wire of the HU
i think this would also work for, whats is it, the logic 7 system? that only puts out 5v on the remote wire?
5v would switch this on and provide a full 12v output to fee the amps
up to 2amps so you can power a lot of amps with this
      01-12-2010, 04:46 PM   #15
alex310
71
Just tried it man, the Pac Audio TR-4 Adapter still doesn't give out enough juice to turn on the relay, it only puts out about 1.5-2amps when I tested it, so the TR-4 will not work, I just paid 20bucks for one adapter since Best Buy only ships it and the retailer who sold it priced it high I guess. I'll try running a small capictor on the wire see if it can pump up the AMPs.
      01-12-2010, 05:15 PM   #16
alex310
71
Okay, I just tried the capictor idea, no go, the capictor keeps a small charge so that small charge keeps the Pac Audio adapter active which in turn keeps the lights on. SUCKS!!!
      01-31-2010, 11:47 PM   #17
Boost3dm3
Boost3dm3's Avatar
26
Drives: E92 M3
did you hook up the relay properly because 1-2A is more than enough to energize the coil inside the relay. I think it should be set up like this correct me if Im wrong Kmarei.
Become a BMW CCA member; please use member #405205 as a reference . Click here to join online
      02-01-2010, 05:53 AM   #18
camaross305
camaross305's Avatar
135
Drives: 2008 M3
It wont work.... It has do with the amps the trigger needs too....I tried this a long time ago with different types of relays. lol
      02-01-2010, 01:26 PM   #19
kmarei
kmarei's Avatar
Egypt
685
what kind of relay were you using?
all the relays i have seen need between 90-200ma to trigger
so 1.5 amps is more than enough to trigger a relay
did you wire it like the diagram above?
      02-01-2010, 01:28 PM   #20
Boost3dm3
Boost3dm3's Avatar
26
Drives: E92 M3
so am I assuming correctly the diagram is the same technique you used? If so then it looks like all the parts needed
for a camaross replacement kit would be <$100
      02-01-2010, 01:29 PM   #21
kmarei
kmarei's Avatar
Egypt
685
exactly
but shouldn't 30 and 87 be reversed?
constant power to 30 and 87 is to the HID ballast?
      02-01-2010, 01:30 PM   #22
kmarei
kmarei's Avatar
Egypt
685
i haven't used it yet, but i see no reason why it won't work
pac triggers the relay, relay powers the HID ballast
m3post
