ZPOST
Go Back   ZPOST > Marketplace > Sponsors Classifieds
  TireRack
      12-22-2009, 05:54 PM   #1
ModBargains.com
475
Drives: JB E92 335i
**********s | KW Coilovers Variants 1,2 & 3!!!
**********s is proud to present to the Bimmerpost community KW Coilovers Varients 1,2 & 3 !!!
[img]http://www.**********s.com/images/Products/KW_Coilovers/KW_head2.jpg[/img]
Call in today for the ABSOLUTE LOWEST PRICE on all KW Coilovers. Please give me a call at (714) 582-3330 ext 8006 for the special price !!
About KW Coilovers
Is your Vehicle looking a little too high? Do you still feel insecure about the sharp turns you attempt around the corners? Is your current body kit not doing the job of creating that AGGRESSIVE appearance? Treat your vehicle and yourself with the best suspension system out there--KW's Coilovers! Not only does this system lower your car perfectly, but it provides HUGE performance benefits.
KW designed and manufactured every coilover to CUSTOM fit your vehicle, unlike other coilovers that may be a "special one-coilover-fits-all", guaranteeing MAXIMUM handling and performance for your vehicle. Along with handling, this system makes sure your car is given a perfectly AGGRESSIVE stance, not a vehicle that's touching the floor. Maybe you're not the one for aggressive looks and ultimate performance, but for comfort. Well, KW took that into consideration, and integrated adjustable comfort technology.
KW is known for their signature colors, individuality, quality, and security. Take a look below to read more into which KW Coilover Variant is the BEST option for you!
[IMG]http://www.**********s.com/images/Products/KW_Coilovers/4_reason_02.jpg[/IMG]
KW Variant 1
Sportive - Harmonic with KW factory pre-set up dampening
The ideal systems for customers wishing to rely on the experience of KW engineers, yet determine their own degree of lowering. In extensive driving tests our engineers have set the dampers for the best balance between sporty driving, comfort and safety.
  • Optimally adjusted, sporty and comfortable dampening technology
  • inox-line stainless steel technology at no extra charge
  • Individually height adjustable
  • German TUEV-tested lowering range
  • High-quality components for long life
  • Comprehensive documentation for ease of us
KW Variant 2
Sporty and Personalized with adjustable Rebound Dampening
The system intended for the experienced driver who requires to not only determine the individual lowering of their vehicle, but adjust the damper setting to fine tune the system to their needs. The adjustable rebound damper allows adjustment of the pitch and roll behavior of the vehicle, adapting it to one‘s own driving preferences.
  • Damping technology with individually adjustable rebound
  • inox-line stainless steel technology at no additional charge
  • German TUEV-tested adjustment parameters
  • Comprehensive documentation for ease of use
  • Infinitely adjustable rebound damping
KW Variant 3
Race Technology for the Road with: Adjustable Compression Rebound Dampening
The new Variant 3 is state-of-the-art technology for the skilled and experienced driver. The separate and independent compression and rebound damping options allow a truly individual driving set-up. These unique systems with the 3 individually adjustable components, allows for adjustment of the compression of the damper in the low-speed range, while the high speed set-up, so decisive for driving comfort, has been preset by our engineers
  • Independently adjustable damping technology -rebound and compression damping
  • Individual height adjustment
  • 14- level adjustable compression damping
  • Unique, independently functioning damping power adjustment
[img]http://www.**********s.com/images/Products/KW_Coilovers/variant1.jpg[/img] [img]http://www.**********s.com/images/Products/KW_Coilovers/variant2.jpg[/img] [img]http://www.**********s.com/images/Products/KW_Coilovers/variant3.jpg[/img]
What are Coilovers?
A coilover suspension basically gives you a matched lowering spring and shock absorber combination with the added benefit of adjustable ride height and spring rates through a moveable spring perch or perches. Coilovers are to your car's advantage by reducing unsprung mass, increasing suspension travel, and allowing the car to be corner balanced.
Why do KW's cost more than other Coilovers?
The answer is simple, you get what you pay for when it comes to vehicle suspension. As such a crucial component of your vehicle, suspension is definitely something you do not want to cheap out on. KW is known for their reinforced and durable suspension components. KW's coilovers have been carefully crafted and designed by studying the flaws of competitors and improving on them. In addition KW coilovers can go lower than just about any other brand and allow you to set your car to a "slammed look", "sporty look", or anywhere in between. In the unfortunate event that anything should happen to your coilovers, KW's warranty backs all their products from manufacturer's defect.
Function
  • Infinitely adjustable within German TUEV-tested adjustment parameters
  • Shortened struts for increased spring travel
  • Trapezoidal threads for simple height adjustment
  • Three different damping technologies for individual adjustment
  • Elastomer bump stops with integrated dust boot protection
  • Easy to read documentation
  • Ready to use comprehensive solutions
  • Visually perfect – safe and unique motion dynamics
Quality
  • Strut housings in inox-line stainless steel technology
  • Anodized aluminum spring collars and add-on pieces
  • High-quality, high-tensile racing springs
  • Special ventilation and sealing system
  • High-quality damping components
  • Hardened, chromium-plated piston rods
  • Special guide and sealing systems
  • Pistons with V-shaped Teflon seals – optimal sealing with minimal friction – temperature-resistant, durable damping technology
Any questions feel free to call me at (714) 582-3330 ext 8006 or e-mail me at Alan************.com
Alan
      01-21-2010, 03:51 PM   #2
ModBargains.com
475
Drives: JB E92 335i
PMs replied thanks!
      01-22-2010, 05:59 PM   #3
flat_out
Drives: Z4MC
how much for club sports or v3s?
      01-22-2010, 09:19 PM   #4
schwank
30
Drives: 06 z4 m coupe
Id like to know too!
      01-22-2010, 11:35 PM   #5
Diokaef
Engineer
Diokaef's Avatar
216
Drives: M235I 2015, 335i 2011
2008 Z4M Coupe  [6.33]
+1 and would you give discount if I also get the brembos big brake kit F&R??
      04-02-2010, 12:41 PM   #6
ModBargains.com
475
Drives: JB E92 335i
All PM's sent and replied thanks guys!
      04-06-2010, 01:05 PM   #7
ModBargains.com
475
Drives: JB E92 335i
Thanks for all the inquires all PMs sent and replied!
      04-16-2010, 11:06 AM   #8
ModBargains.com
475
Drives: JB E92 335i
All pms replied guys thanks!
      05-28-2010, 01:59 PM   #9
ModBargains.com
475
Drives: JB E92 335i
All pms sent and replied guys
Shoot me over a PM, email me at Alan************.com or give me a call at ************** ext 8006 for the best price guaranteed !
      06-14-2010, 06:06 PM   #10
ModBargains.com
475
Drives: JB E92 335i
All pms sent and replied guys thanks!!!
      11-09-2010, 12:27 PM   #11
ModBargains.com
475
Drives: JB E92 335i
      04-28-2011, 02:45 AM   #12
ModBargains.com
475
Drives: JB E92 335i
All pms sent and replied thanks!
      04-28-2011, 03:47 AM   #13
elude
elude's Avatar
20
Drives: BMW
can you send me a PM for a price shipped to 92124 for KWV3 for an 06' Z4M Coupe?
      04-28-2011, 10:04 AM   #14
ModBargains.com
475
Drives: JB E92 335i
Sure thing, pm coming your way
      05-05-2011, 03:46 AM   #15
ModBargains.com
475
Drives: JB E92 335i
more order shipped thanks guys!!
      05-06-2011, 09:48 AM   #16
nutzkicker617
nutzkicker617's Avatar
28
Drives: Z4 M Coupe
How much for KW V3 for a Z4M Coupe picked up cash?
      05-19-2011, 03:56 AM   #17
ModBargains.com
475
Drives: JB E92 335i
PM coming right up
zpost
