12-11-2009, 12:35 PM | #1 |
Rep 50
N52 (125i) tuning questions...
I have a 125i Coupe here in Colombia and have read about quite a few ECU flashes and tune ups for the N52 engine but I am a little confused because of all the options available (PBX, LET, BMS, etc.. )
Are all these pretty much selling the same type of ECU flash? Which are the most reliable and performant ECU flash suppliers? Which is the easiest to install? Which is the stealthiest vis-a-vis the dealer? And finally, which do you think might help me the most in 2,600 meter altitude (10,000 feet) ? Any guidance is appreciated. Thanks! |
12-11-2009, 01:08 PM | #2 |
Rep 224
When someone says "get turbos" at that altitude, don't be discouraged.
BMS (Burger Motor Sports) offers the PBX. It's a physical chip that can't be detected unless someone opens your ECU and takes a peek. Thus, taking it out for software type things would be recommended. Otherwise, it's dealer safe. Takes about 1.5 hours to install. There are many reviews of this one (all very positive) on this forum and mostly the e90 one. The LET, I believe is just an ECU re-flash, which may offer slightly more power, but it can be over-ridden on dealer updates, etc. So, it's not long-lasting. Not sure on install, just computer work, I suppose. |
12-11-2009, 01:22 PM | #3 | |
63
Rep 1,884
My Youtube Channel
12-11-2009, 02:02 PM | #4 |
375
Rep 17,017
I agree with Brad, the BMS PowerBox is the easiest and safest solution for your car. With all the positive reviews out there, I see no reason not to do it.
12-14-2009, 01:52 PM | #5 |
Joint Chiefs of Staff
4912
Rep 115,980
