BIMMERPOST Universal Forums General BMW News and Cars Discussion
      12-10-2009, 10:05 AM   #1
Heinzftw
Heinzftw's Avatar
295
Drives: 2000 Civic+2008 Accord
E30 Buyers Guide?
Out a whim, on craigslist I finally found a decent E30 325i and am seriously debating whether or not to pull the trigger. What are a few things to look for? Thanks all!
http://sfbay.craigslist.org/sby/cto/1501779007.html
http://bmwe30325i.shutterfly.com/27#27
Originally Posted by Javi335 View Post
saw you comment and i'd lay on my bed and cry, then i put some Yulio Iglesias music, no more problem.
      12-10-2009, 10:44 AM   #2
Spec 1
Faster in the Corners
Spec 1's Avatar
52
Drives: '91 E30, '05 ZX6-R, '06 300C
That 3rd light in the front is yuck.
Rust under the passenger foot well.
Electrical problems with the gauge.
Working HVAC.
Timing belt on the inline 6's (the I-4's have a timing chain instead)
Taillight seal
Otherwise most are rock solid.
'91 M42 E30 - All sorts of goodies.
      12-10-2009, 12:13 PM   #3
ZJP
125
Drives: F10 535xi / B6 S4
I think the main thing on the 6cyl E30's was just the timing belt (needs to be replaced every 50k-60k).
      12-13-2009, 09:27 AM   #4
ENINTY
173
Drives: 2006 325i Sport
Here's a few things to look for:
Leaking steering rack seals (the tirerod boots will be full of fluid).
Sticking antenna mast.
Gages inactive (board may have bad solder joints or bad ground)
Rust under the battery tray.
AC compressor (based on age).
Missing front air dam lip (it pops off easily and people loose them parking)
Check if the heater core was replaced. Some E30s had plasic heater core sides (BMW upgraded it to all aluminum later). There was a recall where BMW put in a valve in the heater core inlet hose to prevent scaling in case the heater core blew). It's easy to replace the heater core BTW.
Clock display will not be working
Radio is toast.
If it is a two door, the seatbacks may not come back to the upright position.
