12-02-2009, 12:39 PM | #1 |
BimmerPost Supporting Vendor
516
Rep 3,613
▀▄ eas - Macht Schnell Ashtray gauge Panels for e9x M3 now available
Monitor your engine’s vitals and race with confidence while adding some style points with our ashtray gauge panel for your M3.
The Macht Schnell gauge panel is an exact component replacement for your stock BMWs ashtray, comfortable housing three of your favorite 52mm gauges within and angled for easy viewing. The textured finish allows an OEM feel as if this were offered from your local BMW parts counter. Injection molded from ABS plastic, this panel will resist warping or bending in high-heat applications. The smooth textured finish is a perfect match for your BMWs interior, giving the OEM-like appearance you expect. The Macht Schnell ashtray gauge panel mounts using the factory ashtray mounting holes with no cutting, drilling or gluing necessary. Ashtray can be replaced at any time if the vehicle is turned in or sold. Gauges not included, packages are offered fully loaded with Stri gauges if desired. Features: - Gauge panel houses three 52mm gauges - Injection molded ABS plastic construction - Textured finish to match interior design - Mounts utilizing factory ashtray mounting locations, no drilling necessary Macht Schnell - e9x 3-series Ashtray Gauge Panel http://www.europeanautosource.com/pr...oducts_id=2383 Models Supported: 2008+ e9x 3-Series, including M3 |
12-02-2009, 12:40 PM | #2 |
516
Rep 3,613
Stri DSD warning gauges offer full function, features, and extreme accuracy.Driven by rugged stepper motor, control by advance microprocessor, DSD is the latest technology in precise monitoring device. DSD gauge series is equipped with laboratory grade sending units.
Click the accompanying images above to be brought to its specific page on our site. Available Gauges: - Digital Stepper Drive (DSD) Series, Boost Pressure (30psi Imperial Measurement) - Digital Stepper Drive (DSD) Series, Boost Pressure (45psi Imperial Measurement) - Digital Stepper Drive (DSD) Series, Water Temperature (Imperial Measurement) - Digital Stepper Drive (DSD) Series, Oil Temperature (Imperial Measurement) - Digital Stepper Drive (DSD) Series, Oil Pressure (Imperial Measurement) - Digital Stepper Drive (DSD) Series, Exhaust Temperature (Imperial Measurement) - Digital Stepper Drive (DSD) Series, Voltmeter (Imperial Measurement) - Digital Stepper Drive (DSD) Series, Fuel Pressure (Imperial Measurement) DSD gauge series are equipped with laboratory grade sending units. All electrical pressure sensors are temperature compensated for highest accuracy. Features: - Glass domed lens to eliminate glare - Warning - User Preset - Peak Recall - Automatic Self Calibration - Short Circuit Auto Detect - Racing Spec Sensors - Extreme Accuracy - 270 Degree Full Sweep - High Resolution - Sequential Open/Closing Mode - LED Backlighting - Titanium Finish Casing Click the accompanying images above to be brought to its specific page on our site. Available Gauges: - Digital Stepper Drive (DSD) Series, Boost Pressure (30psi Imperial Measurement) - Digital Stepper Drive (DSD) Series, Boost Pressure (45psi Imperial Measurement) - Digital Stepper Drive (DSD) Series, Water Temperature (Imperial Measurement) - Digital Stepper Drive (DSD) Series, Oil Temperature (Imperial Measurement) - Digital Stepper Drive (DSD) Series, Oil Pressure (Imperial Measurement) - Digital Stepper Drive (DSD) Series, Exhaust Temperature (Imperial Measurement) - Digital Stepper Drive (DSD) Series, Voltmeter (Imperial Measurement) - Digital Stepper Drive (DSD) Series, Fuel Pressure (Imperial Measurement) DSD gauge series are equipped with laboratory grade sending units. All electrical pressure sensors are temperature compensated for highest accuracy. Features: - Glass domed lens to eliminate glare - Warning - User Preset - Peak Recall - Automatic Self Calibration - Short Circuit Auto Detect - Racing Spec Sensors - Extreme Accuracy - 270 Degree Full Sweep - High Resolution - Sequential Open/Closing Mode - LED Backlighting - Titanium Finish Casing Unlike the standard DSD Series, the DSD-SLMII turn completely black when unlit for a "stealth" appearance. Click the accompanying images above to be brought to its specific page on our site. Available Gauges: - Digital Stepper Drive (DSD) Series, Boost Pressure (30psi Imperial Measurement) - Digital Stepper Drive (DSD) Series, Boost Pressure (45psi Imperial Measurement) - Digital Stepper Drive (DSD) Series, Water Temperature (Imperial Measurement) - Digital Stepper Drive (DSD) Series, Oil Temperature (Imperial Measurement) - Digital Stepper Drive (DSD) Series, Oil Pressure (Imperial Measurement) - Digital Stepper Drive (DSD) Series, Exhaust Temperature (Imperial Measurement) - Digital Stepper Drive (DSD) Series, Voltmeter (Imperial Measurement) - Digital Stepper Drive (DSD) Series, Fuel Pressure (Imperial Measurement) DSD gauge series are equipped with laboratory grade sending units. All electrical pressure sensors are temperature compensated for highest accuracy. Features: - Glass domed lens to eliminate glare - Warning - User Preset - Peak Recall - Automatic Self Calibration - Short Circuit Auto Detect - Racing Spec Sensors - Extreme Accuracy - 270 Degree Full Sweep - High Resolution - Sequential Open/Closing Mode - LED Backlighting - Titanium Finish Casing[/QUOTE] Unlike the standard DSD Series, the DSD-SLMII turn completely black when unlit for a "stealth" appearance. Click the accompanying images above to be brought to its specific page on our site. Available Gauges: - Digital Stepper Drive (DSD) Series, Boost Pressure (30psi Imperial Measurement) - Digital Stepper Drive (DSD) Series, Boost Pressure (45psi Imperial Measurement) - Digital Stepper Drive (DSD) Series, Water Temperature (Imperial Measurement) - Digital Stepper Drive (DSD) Series, Oil Temperature (Imperial Measurement) - Digital Stepper Drive (DSD) Series, Oil Pressure (Imperial Measurement) - Digital Stepper Drive (DSD) Series, Exhaust Temperature (Imperial Measurement) - Digital Stepper Drive (DSD) Series, Voltmeter (Imperial Measurement) - Digital Stepper Drive (DSD) Series, Fuel Pressure (Imperial Measurement) DSD gauge series are equipped with laboratory grade sending units. All electrical pressure sensors are temperature compensated for highest accuracy. Features: - Glass domed lens to eliminate glare - Warning - User Preset - Peak Recall - Automatic Self Calibration - Short Circuit Auto Detect - Racing Spec Sensors - Extreme Accuracy - 270 Degree Full Sweep - High Resolution - Sequential Open/Closing Mode - LED Backlighting - Titanium Finish Casing[/QUOTE] |
12-02-2009, 12:41 PM | #3 |
516
Rep 3,613
Here is the mounting process:
Flawless fit: Installed in our Project M3: Installed in our Project 135 w/ Stri DSD White backlit gauges: Last edited by brandon @ eas; 12-02-2009 at 12:57 PM.. |
01-08-2010, 05:17 PM | #5 |
516
Rep 3,613
03-02-2010, 12:49 PM | #7 | |
8105
Rep 18,795
Drives: BMW
Oil Press/Water temp should be in any vehicle, we'll be monitoring boost as well in our e92 project.
03-08-2010, 12:21 PM | #9 |
254
Rep 4,048
I would suggest having a professional installer look at it. I've done wiring for gauges before, and on certain cars it's not so difficult, but I cant say that for these cars.
