better MPG with or without cruise control?...
11-26-2009, 05:00 PM | #1 |
21
Rep 110
Anyone ever put this to the test? (ie reset the OBC before a motorway run and tried this with and without CC at the same speed?)
I'm sure when I apply the CC the 'MPG meter' shows slightly worse than I would get without it, but then I can't see any reason for this. Anyone got any ideas on this? |
11-26-2009, 05:12 PM | #2 |
Rep 74
in my experience intelligent use of CC can be as good as nonCC driving.
Over long distances on the motorway going on the flat or downhill, CC is very efficient. The only time is loses out is uphill (even a gentle incline on the motorway). In petrol conserving driving mode I would lay off the pedal a bit and try and coast up the slope as much as poss (within reason). In practice its subtle in that I might slow down by 5-10 mph. CC will however push as much fuel into the engine to maintain a static speed. This can be countered by gently clicking CC down when going uphill. |
11-26-2009, 05:21 PM | #4 |
21
Rep 110
I would've expected it to be better overall, but I've not put this to the test, and I suppose it depends on the system.
When you slow down quickly using the CC stick it must actually apply the brakes, so this can't be good for MPG if it's braking on downhill bits. Otherwise it's better surely, as the speed can't creep up? |
11-26-2009, 05:21 PM | #5 |
1882
Rep 7,000
11-26-2009, 05:34 PM | #6 |
697
Rep 7,308
Drives: see above.
I used to find it (cc) better on my 320D - maybe to do with keeping at a constant speed tho - rather than getting a move on when bored!!
11-26-2009, 05:42 PM | #7 | |
275
Rep 9,218
People tend to allow cars to lose a little speed uphill and gain a little speed downhill - especially when cruising on motorways. The cruise control fights this, trying to keep a constant speed and therefore uses more fuel. |
11-26-2009, 06:03 PM | #8 |
571
Rep 7,519
Drives: 2009 E90 335i MT
Cruise control here is almost useless. Anytime you turn it on some lorry driver or geriatric will pull in front of you on the four-lane and putter along at 52½ mph causing you have to drop off CC. Get around them and put it back on and some other yokel will do it again within a mile or two. About the only time I can keep CC on for any duration is through construction zones or reduced speed limit areas like Elkesley on the A1.
2009 E90 335i Montego Blue · Black Leather · Burl Walnut · 6MT · US Spec
SatNav • ZPP • ZCW • 6FL • TPMS • iDrive • PDC • HWS • Xenons • BMW Assist • Power Rear Sunshade • Logic 7 European Taillights • Rear Foglamp • OEM Alarm • PicoTray • DataToys XM-DVR • Multi-view Processor Quaife ATB LSD • Short Shift Knob • Hartge Anti-Roll Bars • AP Racing Front Brakes • 19" Style 269 |
11-26-2009, 06:34 PM | #9 |
GTR'in it
169
Rep 4,434
11-27-2009, 02:38 AM | #10 |
21
Rep 462
Maybe this should be the next area for BMW'd Efficient Dynamics, frugal cruise control.
I'm sure it could be done. CC isnt intelligent enough to know its going up a hill, all it know is that the speed is dropping for some reason so open the taps until the speed comes back up (a bit of PID). A few more 1's and 0's in the software could make it more fuel efficient. |
11-27-2009, 03:56 AM | #11 |
Defected to the dark side.....
210
Rep 5,795
Drives: BMW M5 LCi
I haven't used it much on the M3 but I was pretty sure in the 'vert over a long motorway distance the cruise was more economical. Prob down to the fact that it didn't accelerate to three figure speeds every time there was a gap in the traffic
11-27-2009, 05:19 AM | #12 |
1545
Rep 8,972
I just use it to avoid speeding when bored on the mway.
Great in 50mph mway average speed zones too, set at 55, go past everyone but knowing you'll be fine.... Is is pretty frugal set at say 70, but when you start using it at 90, then uphill you'll be into low tens mpg IMO. I often preset it at 35, then when approaching a 30 limit just re-select it, the car brakes for you spot on down to 35 then maintains that speed. |
11-27-2009, 06:36 AM | #13 | |
21
Rep 462
11-27-2009, 07:25 AM | #14 | |
1545
Rep 8,972
ACPO guidelines are +10% +2mph, so 30+3+2 = ACTUAL 35mph is the limit. But an 'actual' 35 would be near 40 on the speedo.. so there's bags to play with... You need a GPS speed device / camera locator, I don't use the car speed these days, especially when limits are concerned.... |
11-27-2009, 07:33 AM | #15 | |
141
Rep 6,912
E92 M3, Jerez Black, Fox Red Novillo, 19'' M Double Spoke, folding mirrors, lumbar support, front seat heating, PDC, USB, DAB, EDC, Bluetooth, Logic 7, High Gloss Shadowline, big smile
11-27-2009, 07:41 AM | #17 |
21
Rep 110
11-27-2009, 08:38 AM | #18 |
571
Rep 7,519
With ACC the car is doing all the work but still going up and down, up and down, up and down, ad infinite making it pretty useless as a fuel conservation device. ACC is only good here if there is little traffic in front.
11-27-2009, 09:10 AM | #19 |
19
Rep 840
11-27-2009, 09:31 AM | #20 |
571
Rep 7,519
Four guys rent a Winnebago for a vacation across Wyoming and Montana. A couple of miles outside Cheyenne, three are sitting in the back playing cards. The driver gets out of the seat and walks back to the others and says, "Deal me in." One of the card players asks who's driving. The driver-no-longer-driving says, "Oh, no problem. I put it on cruise control."
SatNav • ZPP • ZCW • 6FL • TPMS • iDrive • PDC • HWS • Xenons • BMW Assist • Power Rear Sunshade • Logic 7 European Taillights • Rear Foglamp • OEM Alarm • PicoTray • DataToys XM-DVR • Multi-view Processor Quaife ATB LSD • Short Shift Knob • Hartge Anti-Roll Bars • AP Racing Front Brakes • 19" Style 269 Last edited by SoYank; 11-27-2009 at 01:59 PM.. |
11-27-2009, 01:46 PM | #21 | |
Rep 274
11-30-2009, 04:45 AM | #22 |
Rep 448
I think the argument as to whether its more economical or not depends on the type of CC you have on the car. As mine isn't the auto braking version as found on 6 cylinder models it gains the MPG on downhill sections as the CC seems to back off a touch as you would if you were driving it manually.
I use cruise all the time driving a 117mile yomp up to Carlisle every couple of days for work at 6 in the morning. Perfect. Its only every so often when it needs switching off. Motorway inclines shouldn't affect the mpg too much as they are designed to be flatter than A-road gradients. At an indicated 80mph (approx 77mph on the sat nav) I get about 47-49 mpg maybe a touch more. That also includes going over Shap which is the steeper of the motorway gradients. There are two things with CC, one is the average speed sections and maintaining the speed through there make it really good at keeping your license clean. The other is you notice how many people can't modulate their speed very well as you play overtake tennis 5 or 6 times!!!!
Now - E90 320d M Sport, Le Mans Blue, sun protection glass, Auto lights and wipers, 193M, a big grin Previous - Seat Leon FR, Golf Gttdi (x2), Mk3 Fiesta SI, E30 318i Peugeot 205 Roland Garros, Mk2 Fiesta Ghia (it had a rev counter!!!!) |
