Brake Pads WORN Light!!! Need advice.
11-22-2009, 01:06 AM | #1 |
40
Rep 565
First off, i have an 06 e90, and when i started my car today, it said brakes worn, need replacement brakes. When I check the status of the brakes through idrive, it says there is still 20k miles before I need to change, and it shows all status okay, however the break light is remaining on. About two weeks ago I was having restraint system issues, and the dealer said that the car is having electrical problems due to low voltage. What do you guys think?
11-22-2009, 04:35 AM | #2 |
167
Rep 7,433
i think that you should take your car to the dealer again and ask what's up
-Brian
2X 2006 BMW 325i [Electric Red & Mystic Blue] | ZPP | V1 | Rear Fogs | M3 Lip Spoiler | EAS RemoteKey | BMS Powerbox | Projector90 Headlights w/ LED AE | LED plate lights | OEM Blacklines http://www.tech-shine.com |
11-22-2009, 02:29 PM | #4 |
67
Rep 1,543
Drives: M235i
If it's still covered under extended maintenance/CPO warranty, why not take it in? I'm not going to mess with shit I know little to nothing about in my driveway unless I absolutely have to.
11-22-2009, 03:10 PM | #5 |
Rep 45
The computer doesn't actually measure how much pad is left, it "estimates" how much is left. The warning light is actuated by a sensor on the pad. If the sensor or wiring hasn't gone bad, you need to replace the pads. Simply pull off the wheel and look to see how much pad you have left! If you aren't already grinding the pad plate against the rotor, you probably will be soon.
jmd_forest |
11-22-2009, 05:26 PM | #7 | |||
Ski bum
317
Rep 6,198
1999 e46 328i Ti Silver / Black[retired] 2007 e90 335xi Jet Black / Black[retired] 2011 e70 X5 35d Vermillion Red / Cinnamon 2011 e92 M3 LeMans / Fox Red extended |
11-22-2009, 07:57 PM | #8 |
2054
Rep 6,119
With something as important as brakes, I wouldn't mess around. Get it checked out asap.
When you say impact instead of affect/effect, you are communicating that you don't understand the difference between the two words, and are too lazy to learn.
11-24-2009, 02:52 PM | #9 |
Rep 60
The Brake Light Indicator is more Reliable then the Computer Estimated Replacement Schedule. If you rims are the Open Spoke Design. I would look in the Rim and look at the Caliper to See how Much Pad Life you got.
-Anthony@F1 Autohaus |
12-18-2009, 04:44 AM | #10 | |
101
Rep 2,095
Drives: 2019 Toyota Tacoma TRD OR 4x4
E90 325i|Sparkling Graphite Metallic|Steptronic|Black Leatherette/Dark Burl Interior|OEM Alarm|35%Front/5%Rear Tint|RD LED License Plate Lights|Rear Fogs Activated|Debadged|Smoked Sidemarkers|Blacklines|Depo P90v2|Matte Black Grille|BMS PBX|AFE Drop In|Charcoal Filter Delete|Air Scoops| RM Silicone Intake Hose| Magnaflow 14815| 19" Avant Garde M310|Continental DWS|M3 Lip Spoiler
