ciggarette lighter only on when engine on? solution?
10-23-2009, 03:59 AM | #1 |
28
Rep 355
does anybody know how to keep this one on as long as the key is in?
now it will only on when i press start on the start engine button. i wouldnt mind installing oine that can be used all the time in the back seat. since i want to be able to use my dvd and mobile charger all the time |
10-23-2009, 10:18 AM | #2 |
Bimmer Fan
42
Rep 104
Drives: 2021 BMW M5 Competition
LOL.... I was thinking the same thing as you. Lots of posts but no answers
10-24-2009, 09:14 AM | #4 |
28
Rep 355
10-25-2009, 02:01 PM | #5 |
46
Rep 967
Radio shack has it. Just need unswitched power and a ground. I wired up a few of them in my old car and they worked great. You will need to cut a decent sized hole in a panel, but if you do it on a panel that's cheap to replace it's no biggie.
| PROcede Rev3 | Vishnu Meth | DCI | BMW Perf. Exhaust | AR Coated/Catless | CP-E FMIC | Quaife | |
10-27-2009, 04:49 AM | #7 | |
BMW Fan
11
Rep 553
It is not difficult to add an unswitched power outlet. You need a fuse holder which will be attached to the positive battery terminal. The size fuse you use will depend on the amount of current you will be drawing. Probably 15 amp or 30 amp at most. You need to know the power consumption of the component that you plan on powering to decide on the appropriate fuse. You also need a 12 volt socket and a length of positive and negative wire, at least 10 gauge wire. The 12 volt socket can be placed wherever you like, then the 10 gauge pos/neg wires need to be routed to the battery where the positive wire will connect to your fuse holder and the negative to the negative battery ground on the car body. If you don't understand everything in these instructions, pay someone to do it for you. |
11-03-2009, 02:32 AM | #8 |
65
Rep 396
simple solution buy the flashlight cigarette adapter for glove compartment. its like $12 and charges when car is off!
http://www.bavauto.com/fland.asp?par...00%20004%20073
11-04-2009, 01:13 PM | #9 | |
Rep 24
E91 318i first registered 12/2007, 2008 model, European. |
11-13-2009, 02:06 PM | #11 | |
65
Rep 920
Drives: 06 E90 330i 6MT, 01 E46 330i
Mar 05 Build date,2006 E90 330i, Sport Package, Premium Package, TR MT-1's . V-1 Hard-wired power with custom V-1 Concealment Display . Rear fogs, Rear power outlet's, M short shifter knob, BlackLines, BMW Strut tower bar, CDV Delete, Front M3 wishbones + tension struts, BMW Performance shocks and springs, BMW Performance Brake kit F&R, OEM short shift kit. Rear M3 Guide rods and Wishbones.
2006 E-90 330i with 302,000 miles. |
