What is a throttle motor?
10-20-2009, 04:24 PM | #1 |
117
Rep 1,564
Well im dropping my car off today at the dealer, since they have to change the throttle motor, Well what is a throttle motor? what does it do? I also have alot of lag with my car, Is there any new software that they can update me to?
10-20-2009, 04:26 PM | #2 |
11
Rep 313
It's probably the electronic motor that opens the throttle. Older cars had throttle bodies that were mechanically opened by a wire that pulled on a mechanism when you stepped on the accelerator. Our cars are fly(drive)-by-wire, which means the accelerator being depressed sends a signal to a motor that opens the throttle a specific amount, depending on how much you're pressing on it. Hope this helps.
-A PS...Or I could be totally wrong. |
10-20-2009, 07:49 PM | #3 | |
167
Rep 7,433
-Brian
2X 2006 BMW 325i [Electric Red & Mystic Blue] | ZPP | V1 | Rear Fogs | M3 Lip Spoiler | EAS RemoteKey | BMS Powerbox | Projector90 Headlights w/ LED AE | LED plate lights | OEM Blacklines http://www.tech-shine.com |
10-20-2009, 08:43 PM | #4 | |
15
Rep 445
But the throttle motor does exactly that - operates the throttle. You can hear it if you drive in lower gears slowly enough as not to generate too much road noise - if you gently press on the gas and then release, you should be able to hear the throttle motor buzz. |
