TNT Racewerks
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > General E90 Sedan / E91 Wagon / E92 Coupe / E93 Cabrio > Headlight washer leaking
      10-10-2009, 01:46 PM   #1
777ER
777ER's Avatar
36
Drives: 2007 328xi
On my '07 E90 with 47,000 miles now. I noticed the driver's side headlight washer has been leaking for about a week now.
The leak varies from about a pint to a gallon in a week.
Since it was washer fluid, I took the driver's front wheel wheel off and the front section of the wheel well liner off to get access to the driver's side headlight washer and find it dripping from where the connection is (clip on/off with a purple o-ring on the hose), disconnected it and the o-ring looks good, wiped it down and reconnected it, the leak stopped.
However when I set the headlights washer off to test it, it drips again but this time I traced it to the headlight washer cylinder from the inside of the car. When I set it off and clean it between tests, the leak rate is random.
Not sure if it's supposed to come from there but when the headlight washer extended and sprayed, it retracts then washer fluid comes dripping out along the bottom of the plastic cylinder on the outside from inside the car.
It seems like the driver's side headlight washer is defective. I asked a co-worker who's bro is a BMW tech, was told it's a common problem and the front fasica would have to come off to replace the headlight washer....I was like oh man....
Since there's about 3,000 miles left before the warrenty expires, I'm a bit worried about the techs taking the whole front off since I could get to it from the driver's side wheel well.
-Chris
2007 Montego Blue 328xi
Sedan | Poplar trim | Steptronic | Cold Package | Power front seats w/memory | Xenon Adaptive Headlights | PDC | 2008 Plate LED's | PBX | LUX v5.2
      10-10-2009, 02:54 PM   #2
fullrev
2011 E92 M3
fullrev's Avatar
34
Drives: 2011 E92 M3
Replace the headlight washer.
Inside fender liner has to come off to replace it. Kid doesn't know what he's talking about.
Profit.
2011 E92 M3 6MT
Gone - 2007 E90 335i
      10-10-2009, 10:29 PM   #3
Tee-Dub
Tee-Dub's Avatar
35
Drives: 2008 135i
WARRANTY!!!!!!!!!!!!
      10-19-2009, 07:42 PM   #4
777ER
777ER's Avatar
36
Drives: 2007 328xi
Last tuesday while pulling out of a gas station, SES light came on. Called dealer the next morning to make a service appointment...2 days later the light went out.
Today they replaced both headlights washers while they were at it...tech found the right side leaking but little compared to the left side.
they didn't have to remove the front fasica to replace it...just the wheel well covers.
They did pull fault code 2AD8 and did SIB 12-16-07 to correct it.
      10-19-2009, 08:17 PM   #5
bavarian19
bavarian19's Avatar
517
Drives: Car
glad to see it is fixed
