Close please
10-10-2009, 02:53 AM | #6 |
84
Rep 1,575
Why dont you ask Vince ,instead ??
Procede V4 , Catless DPs, Forge FMIC, Injen Intake, VK Oilcooler, Hartge Quads Exhaust, Modded CDV, Synapse BOV Kit, BMW Performance 335i SSK Kit, P3 vent boost gauge Space Grey 335i -> See more pics HERE |
10-10-2009, 08:08 AM | #10 |
161
Rep 7,377
tell Vince to send you another one. Probably defect.
07 335i AT - MOTIV 750 - MHD E85 BMS flash - BMS PI - JB4G5 - Okada Coils - NGK 5992 Plugs - Helix IC - Snow Stg. 3 - Stett CP - Custom midpipes with 100 HJS Cats - Bastuck Quad - PSS10 - QUAIFE LSD - BMS OCC - Forge DVs - AR OC - ALCON BBK - M3 Chassi - Dinan CP - Velocity M rear Toe arms - Advan RZ-DF - LUX H8 - Level 10 AT upgrade
10-10-2009, 08:08 AM | #11 | |
208
Rep 9,339
we had a similar problem with the VK dp's... the flange that sits in the turbo is a tight, tight fit.... Just keep working at it. I know it's a tight space, but try twisting a bit with the exhaust bolts not connected to the dp's to give you some more wiggle room. Shoot me a PM if you think you might need some help... we're right in NJ, so not too far from u Good luck! Last edited by Alex@AKMotorwerk; 10-10-2009 at 08:53 AM.. |
10-10-2009, 08:34 AM | #12 |
61
Rep 1,121
Just keep trying at it, I had the same problem until I found out that the rear was hitting the bracket where you would screw the stock dps thus not letting the vk downpipe sit flush with the turbo housing...make sure the vk is not hitting anything in the back...thats my sugestion..
10-10-2009, 08:52 AM | #14 | |
208
Rep 9,339
10-10-2009, 09:28 AM | #15 |
47
Rep 693
Thanks for the help. I will try to move that bracket out of the way in the rear. I will go at it again later tonight. I gotta work 16 hours today. I'll keep you posted
10-10-2009, 10:33 AM | #16 |
Rep 1
I had the same problem with the forward downpipe. I measured the flange diameter of the VK downpipe with a set of calipers and found out that it was .040 to .050 inch larger that the stock pipes. I used a file to to bring the diameter down and it slipped right in without a problem.
10-10-2009, 11:02 AM | #17 |
148
Rep 1,738
10-10-2009, 11:06 AM | #18 |
198
Rep 2,485
Defected? Did it sneak away to Havana or Moscow or something?
2006 E90 330i (retired)
2009 E90 335i (retired) 2012 E70 X5 50i M Sport (retired) 2016 F10 535i M Sport |
