jb3 question
09-24-2009, 01:34 AM | #1 |
35
Rep 763
jb3 question
can i safely run map 5 with just a dci and catless downpipes no intercooler? or am i stressing out the turbos to much? i know an intercooler allows me to run the same power on less boost but now im raising the boost is that going to be a problem with out it? i dont want to take risks or anything like that if its to risky please tell me thank you very much everyone!
09-24-2009, 01:40 AM | #2 |
161
Rep 7,377
you can run map 7 with that setup and 93 octane.
07 335i AT - MOTIV 750 - MHD E85 BMS flash - BMS PI - JB4G5 - Okada Coils - NGK 5992 Plugs - Helix IC - Snow Stg. 3 - Stett CP - Custom midpipes with 100 HJS Cats - Bastuck Quad - PSS10 - QUAIFE LSD - BMS OCC - Forge DVs - AR OC - ALCON BBK - M3 Chassi - Dinan CP - Velocity M rear Toe arms - Advan RZ-DF - LUX H8 - Level 10 AT upgrade
09-24-2009, 01:40 AM | #3 |
63
Rep 989
Yes, you can! you can run map 7 as well...with dp's and dci...
EURO E92 M3 2008 6MT Interlagos ///Fully Loaded! Evolve-R ECU Flash/Gintani Sport Exhaust/MS Stg2 Intake Kit/H&R Springs/MS 18/15 mm spacers/Bmw Perf. Grills/Gloss Black side gills/LCI Tails/LUX V3's/RD license plate leds |
09-24-2009, 02:03 AM | #5 |
161
Rep 7,377
the only problem is that you will heatsoak faster on map 7 , you will notice this if you do lots of pulls but for normal driving the car will be much faster.
09-24-2009, 07:05 AM | #7 |
161
Rep 7,377
Map 5 is about 14.5 Psi and map 7 15.5 psi.
However you will pass the 110F IAT temp quick if you push it constantly and the PSI will drop a lot. As i said before for daily driving is fine to run map 7 with NO IC with occasional WOT.
09-24-2009, 11:26 AM | #13 |
Seasoned Lurker
Rep 160
09-24-2009, 11:58 AM | #15 |
Seasoned Lurker
Rep 160
Nope, I mean there are settings you can tweak to essentially create your own map. Check out n54tech.com for all the details but you can set things like boost, throttle sensitivity, A/F ratio, etc. Also, yes it can display IATs.
09-24-2009, 12:02 PM | #16 |
241
Rep 4,936
+1
[SIGPIC][/SIGPIC]
09-24-2009, 12:04 PM | #17 |
161
Rep 7,377
The boost gauge is a must have if you run jb3, i actually miss it now after GIAC flash.
09-24-2009, 12:15 PM | #18 | |
335
Rep 4,633
Map switching often is seriously overrated. You test a a few maps to see which you like and you set it there. Your foot controls the power. I went from map 4 to 7 and i havent touched it in forever! Map 4 was nice, map 7 worked properly/healthy/strong in my car so i stuck with it. |
09-24-2009, 01:15 PM | #20 |
161
Rep 7,377
i have been running fully modded map 6-7 for about 20.000 miles before changing to GIAC. never had a limp or problem.
09-24-2009, 01:18 PM | #21 |
35
Rep 763
thats awesome!!! im scared to go to map 7 daily i feel like its to much stress on a stock core like pistons and all that can the stock block handle 400 whp if i do meth and full upgrades?
