E90 brakes @ 10k miles? premature wear?
09-19-2006, 05:20 PM | #1 |
missing two turbos.
577
Rep 4,859
Drives: fast around corners.
I currently have 10,500 miles on my E90 330i ZSP.
My brake just started to make that squeaking noise. I know its the brake.. It sounds just like when the brakes were worn out on my previous cars. Isn't this a bit early? I remember my previous car's brake worn out @ 12k miles and the dealership replaced it under warranty for premature wear problem. Im pretty sure BMW will replace it for me if they find it worn out already.. but what the hell? I don't even drive THAT hard... I don't even track/autocross my car...
06 AW E90 330i ZPP/ZSP/Step/Expired Warranty : Prior Design Front : ACS Rear : ACS Roof : BlackLines : Simota Intake : Carbon Fiber Interior Trim : : MTEC V3 : 24% Charcoal : V1 Hardwired : Solaris Invisibulbs/LED interior : |
09-19-2006, 07:11 PM | #3 |
MAUI BUILT
485
Rep 7,781
Drives: 2006 330i MT
Sean, I must be more gentle on the brakes than you, I'm at 13K and my brakes still have lots of life left!
Danny
Arctic/Blk Leather/Alum.Trim/MT/ZSP/Sunshades/Blk Lines/M3 Illuminated Knob/Alcantara Performance Wheel/M-E-Brake Handle/Euro Fog Switch/Koni Yellows/H&R Sport Springs/19" VMR V718's w/PS2 Tires/M-Tech Body Kit/Carbon Fiber Spoiler/Bimmian Interior Bulbs/OEM Eye Glass Tray/SSK/Alcantara Boot/Split Armrest/OEM Dual Rear Power Outlets/Rear Ashtray Delete/OEM Alum. Pedals/Osram 6000K/Brex Rings/LED Side Markers/BMS Power Box
09-20-2006, 02:12 PM | #4 |
189
Rep 2,068
how do you know that the brakes are worn out? i thought the squeaking noise has to do with oil as well, just did an oil change yesterday and there's no more squeaking noise like last time
danny any thoughts?
mod = crack
09-20-2006, 02:26 PM | #5 |
fresher den you
34
Rep 986
Drives: 2004 x3
mine did that too at about 15k they probably need to be adjusted thats all!
2004 x3, blue water metallic, sports pack, panoramic moonroof, xenon, hi-fi radio.
09-20-2006, 05:50 PM | #6 | |
MAUI BUILT
485
Rep 7,781
I've never heard any squeaking noises related to the oil. Sometimes, a low oil level or very dirty oil can cause noisey valve movement, but that sound is more the valve's "tapping" then squeaking.
It' pretty easy to tell if your down to the warning indicaters built-in to the brake pads, they either squeak when applying the brakes or if they are worn down enough, squeak when rolling. Danny Quote:
09-20-2006, 06:01 PM | #7 | |
155
Rep 6,158
maybe if the OP had properly maintained his brakes and changes his brake oil more often they wouldn't be worn out now |
09-25-2006, 09:07 PM | #8 | |
45
Rep 1,738
2006 325i - Sparkling Graphite
2000 S2000 - New Formula Red 2007 Chev Silverado crew cab Z71 |
09-25-2006, 09:07 PM | #9 | |
45
Rep 1,738
09-27-2006, 01:09 PM | #10 |
Streifenden Komet
Rep 120
Drives: 525i was a 325is
I jad a 93' 325is and the brakes always squeaked a little bit after like 5,000 miles. Granted that i drive my car harder than the roads allowed. Ask the mech if he puts on the anti-squeak paste when they put the pads in. Worst case you take your rim off and see how your pad looks. Is it just squeaking say in the morning or after the rain, if so it's rust. Best way to get rust off go down a street with very little traffic make sure no one is behind you or cops. Gun to 60 and apply just short of the abs. the drive a little more and apply half as much force. Oh also make sure your rotors don't have grooves from the pad. you can feel them on the face of the rotor if so your not getting even pad wear nor all of the pad. Which is dangerous duh! but just get out and check it out. You might even think of upgrading your pads to PAGID metal masters!! semi-metallic, they were on my 3er and i stopped whether i was ready to or my tires were.
"Drive like you live" CFBA:rocks:
335i will be the new turner car for this decade! If it's a bimmer, it's badass. It's more fun to drive a slow car fast, than a fast car slow; F- That just go to driving school and you can do both. |
09-28-2006, 01:32 AM | #11 |
missing two turbos.
577
Rep 4,859
Im lost about this whole brake thing you guys discussed about.
What kind of POS brake system requires brake fluid change every 10,000 miles or less? All the previous japanese cars I've owned were brake problem free.
09-28-2006, 02:13 AM | #12 | |
Got Seoul?
116
Rep 2,862
Drives: 2012 535i MSport
Can you say Alooooha?
[SIGPIC][/SIGPIC] |
09-28-2006, 02:15 AM | #13 | |
Got Seoul?
116
Rep 2,862
[SIGPIC][/SIGPIC] |
09-28-2006, 01:18 PM | #15 |
1671
Rep 6,586
some people just love to ride those brakes, bad, bad people
If you step on it at the light, then step on the brake -- there is your answer If you brake when cruising uphill -- there is your answer If you brake every time idiot in front of you brakes -- there is your answer If you just keep tapping on the brakes for no reason -- your answer If you shift into the neutral and wear the brakes instead of braking with the engine -- blah, blah, blah... If you're under 20 -- there is your answer |
09-28-2006, 03:31 PM | #16 | |
missing two turbos.
577
Rep 4,859
09-28-2006, 03:49 PM | #17 | |
1671
Rep 6,586
Anyhow, you can put platinum brakes in it and if you drive like a teenager, they will wear out in 10k miles. I've had Civic, and Accord, and VW, and many others and never had work on brakes done before 35k miles, so... I am at 10k with my e90, and they look like the day I picked up the car... So... |
09-28-2006, 04:14 PM | #18 | |
missing two turbos.
577
Rep 4,859
This thread really is becoming a moot point. Im getting my car in for a service soon, I'll just those service guys deal with it.
09-28-2006, 04:37 PM | #19 |
52
Rep 1,024
Try going out and bedding in your pads. It often helps with squeeking. I have 6k miles on my car so far with about 5 days at the track and my brakes are still fine, no squeeking or shuddering. I bedded them in at between 2k and 3k miles though. I didn't bother bedding them in while I was on ED or I would have done it after about 500 or so miles.
http://www.zeckhausen.com/bedding_in_brakes.htm I dunno how many times I've posted this link on the forums, but it's got some great info on how and why you bed in brakes.
330i Monaco Blue, Terra /w aluminum trim, SP, PP, CA, PDC, Nav, Folding Seats, Sat Prep European Delivery Blog Picture Gallery |
09-30-2006, 10:02 PM | #20 | |
341
Rep 16,407
11-01-2006, 07:30 PM | #21 |
177
Rep 2,355
alright there are definatly some "special" people on this forum
2006 E46 M3 ZCP 6SPD-Interlagos Blue - 6SPD - SSK - AA Headers -AA Tune - Navigation w/ Splashscreen Mod - 3M Crystalline Series 60 - Carbon Splitters - Swissvax Treated - Bridgestone
2012 Yamaha FZ8 - Matte Black/Grey - Michelin Pilot Pure 2CT - Vortex Rear Sets - Yoshimura R-77D & Fender Delete - Spectro Race Oil - GP Reverse Shifting |
11-01-2006, 07:30 PM | #22 |
177
Rep 2,355
im reffering to the person talking about "anyone under 20==there is your problem"
