Audison Bit One question
09-19-2009, 03:32 PM | #1 |
300
Rep 3,969
So I'm thinking of picking one of these units up. This is how I think it will work:
OEM HU >>> OEM Amp (L7) >>> BitOne >>> Aftermarket Amp(s) >>> OEM or Aftermarket Speakers In future, I also understand I may be able to replace the OEM amp by a MoBridge DA1000 for a pure digital connection between HU and Processor. Some questions I still have: 1. OEM HU volume. Will the BitOne properly de-EQ at ANY volume level??? (the calibration takes place at 80% HU volume per manual) 2. Does the unit provide an input for a microphone in order to make (one-time) EQ adjustments in response to the speaker outputs in the car environment? 3. Does the unit work with the optional (but nowhere to be found) auto-eq module? I hear talks about an entry level, mid level, and high level bit one. How can you tell the difference between the units? The one I'm looking at is a BitOne.1 Thanks! |
09-19-2009, 04:36 PM | #2 | |
2288
Rep 13,001
2. No 3. So far there is only one bit one, and it does not perform any auto-EQ. I don't see how technically an auto-EQ external module -if existed- could work with another module that does summing, DSP and EQ. Auto-EQ should be done in the same device as the rest of the processing, IMO (i.e. the-someday-in-the-future MS-8). |
09-19-2009, 06:14 PM | #3 |
289
Rep 3,201
Actually, the L7 system seems to have some auto-loudness component to its EQ curve, so you should ONLY calibrate your bitONE at 80% volume. If you calibrated it at a lower volume, it would be trying to defeat the auto-loudness even at higher levels where it isn't present, and you don't want it to.
If you install the bitONE, make sure to buy some very small-gauge speaker wire for your connections on the inputs. The terminals are TINY. You will want a small flat screwdriver too - I used an old a/d/s/ gain screwdriver, but you may want a cheap jeweler's screwdriver that they sell at Home Depot. |
09-19-2009, 09:55 PM | #5 |
43
Rep 262
Where online can I find a BitONE? I am lucking out on finding them online.
Dolby
- 1998 E36M3/4 (retired)
- 2005 E46 330i ZHP (totaled) - 2007 E90 335i Black/Blk/Alu Trim (retired) - 2009 E90 M3 - Jet Blk on Blk mDCT - 1987 E30 325is - track car conversion in progress |
09-19-2009, 10:10 PM | #7 |
43
Rep 262
Why do you say that? I could understand the difficulty in setup for even the average consumer, though.
I was hoping to order it and just install it myself, but I will see if there are any dealers here in town that I could order one from. dolby
09-19-2009, 11:19 PM | #8 |
289
Rep 3,201
Because authorized audison dealers sign an agreement to NOT sell these things over the internet, because they will get all effed up, and then the product - and the brand - will get the blame.
So any online are not warrantied, possibly black market, and probably V1 units which were glitchy at best. That's why |
