      09-16-2009, 02:57 AM   #1
135iFreak
Doin' A Fly By
135iFreak's Avatar
South Africa
30
Drives: 135i AW/BB M-Sport
2008 135i  [0.00]
HELP with Error Message
Hey Guys,
I got a real shocker yesterday on the way to gym, my 135i came up with an error message that read:
"Engine Fault! Reduced Power"
But the car didn't feel like there was any less power...When I pull off, I let the car idle for about 3/4 mins and then switched of and on again. The error message didn't pop up again today and the car seems fine.
If anyone knows what the heck just happened there, please let me know.
135i M-Sport
A/W, Boston Black Interior, 18" CSLs
      09-16-2009, 04:26 AM   #2
Lester
295
Drives:
Someting failed, it could have been a momentary fuel pressure symptom. Go to your dealer and have them read the code.
      09-16-2009, 10:46 AM   #3
Shifty
Spinning
Shifty's Avatar
South Africa
Drives: Space Grey 135i Coupe
Fuel pressure pump imo...welcome to the club ^_^
      09-16-2009, 01:56 PM   #4
Notion-Za
South Africa
28
Drives: '16 M4 ZCP
dude, b4 the failure did u feel the engine like hesitate?
shifty frm css? xD
2016 M4 ZCP
2018 Ford Ranger WildTrak 3.2
      09-16-2009, 03:51 PM   #5
Shifty
Spinning
Shifty's Avatar
South Africa
Shifty from war3, cod, hon ?
Etc etc etc
      09-17-2009, 05:53 AM   #6
135iFreak
Doin' A Fly By
135iFreak's Avatar
South Africa
30
2008 135i  [0.00]
Hey guys,
Shifty, no loss in power whatsoever, it didn't even shudder,backfire or smoke...
I got some advice, and he says that it's probably an inferior fuel problem.. Is this a possibility -(I did fill at a garage that wasn't my first choice the other day)?
135i M-Sport
      09-17-2009, 11:12 AM   #7
Shifty
Spinning
Shifty's Avatar
South Africa
Have u added an ECU by any chance?
Extract from your garage
...Performance/Handling Modifications
Its a secret
This will throw out an error message like that...
      09-17-2009, 02:54 PM   #8
Notion-Za
South Africa
28
Drives: '16 M4 ZCP
error messages with an ECU chip would also include something along the line of a torque limit exceeded. If you have ecu'd, there are a few bmw people at a few garages that will bypass the mod. You just have to know who to talk to
If it is the fuel, (and im going out on a limb here) the filter or something(not to sure) might have had a build up of carbon(?) which could cause the HPFP to have problems
2016 M4 ZCP
      09-17-2009, 05:03 PM   #9
Shifty
Spinning
Shifty's Avatar
South Africa
I'm almost certain it is the HPFP...may have something to do with the fuel...
I was told to only use 95 octane... O_o
What exactly did u put in
      09-18-2009, 01:02 PM   #10
Spec Volcanic
Spec Volcanic's Avatar
22
Drives: 2011 BMW 1M
I that the same error after a spin at the Track...
power very reduced...
turn the car off and back on and everything was good again
      09-21-2009, 01:59 AM   #11
135iFreak
Doin' A Fly By
135iFreak's Avatar
South Africa
30
2008 135i  [0.00]
Thats exactly what happened on mine, I was driving medium to hard and then the message popped up, when I switched it off and back on again, the message was gone and hasn't appeared since.
Shifty.. Like you said, I only ever fill 95 octane..
135i M-Sport
      09-22-2009, 01:10 AM   #12
ghusheshe
135 Addict
South Africa
Drives: VO 1M
Happened to me yesterday after I filled up with 95 Octane from Shell on the M2 highway. Pulled off and drove for about 10 Kms and the light came on. Called Lyndhurst Auto explained what happened. I was told to pull over on the side of the road, switch the engine off and on again. Light disappeared. It might have been inferior fuel with particles that upset the catylyst converter I am being told. Now I'll be extra carefull where I fill up...
      09-22-2009, 04:22 AM   #13
135iFreak
Doin' A Fly By
135iFreak's Avatar
South Africa
30
2008 135i  [0.00]
You said it dude, no more dodgy Fuel Stations
135i M-Sport
      09-22-2009, 01:18 PM   #14
aacabriolet
aacabriolet's Avatar
No_Country
118
Drives: '14 435i Coupe
Shell 95 is supposed to be one of the best?
      09-22-2009, 02:05 PM   #15
Shifty
Spinning
Shifty's Avatar
South Africa
I also believed that...but I think this may be related to a dodgy filling station rather than a dodgy fuel type...? Correct me if I'm wrong 135Freak.
Off Topic...what fuel do you guys generally stick to? Obviously its 95+...but shell, bp, engen...?
      09-23-2009, 09:17 AM   #16
aacabriolet
No_Country
118
Shell and Sasol
      09-24-2009, 03:41 PM   #17
gmza
14
Drives:
I've had dodgy Shell before...repeatedly. In fact I had ongoing fuel consumption issues until I started changing my regular filling station from one of the nearby Shells to a nearby Caltex.
My average consumption used to be ~16.5l/100km. It's now around 13l/100km. Yes, partly due the engine now being run in, but the biggest change happened fairly quickly after I changed filling stations.
No suprise then that my fuel pump packed up at a very low mileage (they usually last at least 10,000km before dying; mine lasted only 2,100km). Sure, the 1st and 2nd gen pumps die anyway, but fuel quality affects how soon it happens. 3rd gen pumps can generally cope with whatever is thrown at them (within reason).
It really is more a case of the particular filling station rather than the brand. I try fill up at the same station whenever I can.
      09-25-2009, 07:13 AM   #18
Notion-Za
South Africa
28
Drives: '16 M4 ZCP
Guys remember that in the stations that are not frequently visited, couldnt the petrol in the tanks cause some sort of impurity or even cause the fuel to go off? I normally stick to going to gas stations which tend to be more busy. I normally take Shell or BP 95. Im on my own budget but theres no way im saving money by putting 93 in.
Just becarful with your fuel pumps. There has been quite a few cases on the main forum where 135's HPFP has failed on the high way. I dont think that would be a fun thing to go through!
2016 M4 ZCP
      09-26-2009, 01:46 PM   #19
135iFreak
Doin' A Fly By
135iFreak's Avatar
South Africa
30
2008 135i  [0.00]
95 Octane is a must up here at the reef, you feel loss in power with 93 up here - filled my Z4 up once and the power losses were absolutely ridiculous..the 1er only gets fed 95 regularly!
As for consumption, the 1er has leveled off at around 12.1 l/100Km which I think is brilliant(Even though I do drive the car hard often)!
135i M-Sport
      09-26-2009, 01:51 PM   #20
aacabriolet
No_Country
118
Amazing! I'm averaging on 14.2 l/100KM at the moment.. Got it down from 17.4..
120i Cabriolet..
Will try BP or another fuel out and see if that helps. Or try to lighten my foot..
      09-26-2009, 08:43 PM   #21
Shifty
Spinning
Shifty's Avatar
South Africa
I'm getting around 14.9 with 1 000km's on the clock. I do think this will come down further...but I do push it (no lectures on running a car in...thx )
It dropped from 18.1 so I'm pretty happy with where it is at the moment.
Oh...and I'm using BP95
      09-29-2009, 04:59 PM   #22
Carbonic
South Africa
Drives: 135iM
2008 135i Coupe  [0.00]
I triggered a system shutdown when I spun off at Phakisa - restored itself after being shutdown and restarted. I have an OBD dongle that I use to check for error codes, nothing logged. Obviously the system shuts down if it gets abnormal readings from the various accellerometers, yaw sensors, ABS sensors, etc, which generally happens when you're flailing around at 190... (not to mention the "nearly-shat-your-pants sensor in the driver's seat).
The dodgey fuel scenario also makes sense - is going to mess with air-fuel ratios and confuse the ECU as well.
I use Engen 95 pretty religiously - get about 11.5l/100 and she pulls like a train.
2008 Alpine White 135iM, High gloss black / satin chrome trim, Xenon lights, Hi-Fi sound, ext. lighting package, BMW Performance wheels, side skirts, pedals, gear knob, exhaust, high gloss black grills, carbon mirrors, carbon decklid spoiler, 35% security laminate, Tii graphics
1addicts
