New BT Code: 2E69 Knock sensor signal 2
09-14-2009, 10:05 AM | #1 |
88
Rep 870
I did a search, looks like no one has seen this code yet. Is it just bad gas? I am on JB3 v1.3 on the first occurance I was on Map 5, on the last 2 I had JB3 to map 0.
If it's low octane gas (I almost always use Shell - We have 93 Octane in Ohio) What is the remedy? put some octane booster in the gas tank? 2E69: 2E69 Knock sensor signal 2 Error will cause a warning light Error is currently present Test conditions have been completed Event 1Odometer 24872kms 15454miles Engine speed 3,104.00 rpm air mass measured 208.00 kg/h voltage knock values cylinder 6 0.31 V voltage knock values cylinder 4 0.29 V Event 2Odometer 24912kms 15479miles Engine speed 2,912.00 rpm air mass measured 200.00 kg/h voltage knock values cylinder 6 0.29 V voltage knock values cylinder 4 0.25 V Event 3Odometer 24944kms 15499miles Engine speed 2,944.00 rpm air mass measured 144.00 kg/h voltage knock values cylinder 6 0.31 V voltage knock values cylinder 4 0.29 V
2007 E92 335i / 6MT / Monaco Blue Metallic / Gray Dakota Leather / Comfort Assist / Premium / Sport / Heated Seats / Navi / Active Steering / Active Cruise Control / Park Distance Control / Rear Sunshade / Sirius MODS PicoTray / M3 Steering Wheel / Front OEM Aero Lip / Bimmian Aluminum Pedals / CDV / Ram Air Scoops / Painted Reflectors / HID 5000k / LED Angels / M Perf. Shifter / Euro Light Switch / 8500 x50 / Center Armrest Pouch / JB4 / BT
09-14-2009, 10:19 AM | #2 |
133
Rep 4,764
Have you changed plugs at 15k miles on a tune?
09-14-2009, 10:28 AM | #5 |
133
Rep 4,764
09-14-2009, 10:31 AM | #6 |
307
Rep 5,175
09-14-2009, 10:33 AM | #7 |
133
Rep 4,764
09-14-2009, 10:37 AM | #8 |
307
Rep 5,175
09-14-2009, 10:44 AM | #9 |
88
Rep 870
What would clearing the codes do? I was going to leave it there for the dealers to see but i can.
09-14-2009, 10:51 AM | #11 |
307
Rep 5,175
09-14-2009, 11:11 AM | #12 |
133
Rep 4,764
Change the plugs if you have not already.
08-23-2010, 06:59 AM | #13 |
Rep 83
any updates ? have the same problem
Procede V5, AMS FMIC, AR c-less DPs & Borla exhaust, DCI, CDV, STETT Charge Pipe+BOV, KW CoilOvers, CMGS Meth kit CM10, AR additional oil cooler, Quaife LSD, TD stage 1 turbo upgrade, RIX Gauge, ACT street clutch
08-26-2010, 01:36 PM | #14 |
Rep 83
nobody ?
08-26-2010, 01:42 PM | #15 |
Joint Chiefs of Staff
4920
Rep 115,999
Physical knock sensor codes have nothing to do with engine knock or tuning/mapping but instead indicate an electrical problem with the sensor. Possible wiring issue but most likely just a bad sensor. Leave the codes in and dealer it.
Mike Last edited by Mike@N54Tuning.com; 08-26-2010 at 06:51 PM.. |
08-26-2010, 01:45 PM | #16 |
1743
Rep 17,960
Drives: A Lot
Garage List 2018 Ducati Panigal ... [0.00]
2016 Mazda CX5 [0.00] 2017 Aprilia Tuono ... [0.00] 2019 BMW M2 Competi ... [0.00] 2015 BMW M5 Competi ... [10.00] 2016 Ducati XDiavel S [0.00] 2016 AMG GT S [0.00] 2011 Ferrari 458 It ... [0.00] 2017 Charger Hellcat [0.00] 2015 KTM Super Duke ... [0.00] 2016 KTM RC390 [0.00] |
Talk to your tuner. You don't want to see any knock/knock sensor related codes. Ever.
08-26-2010, 03:12 PM | #17 |
88
Rep 870
08-30-2010, 08:51 AM | #18 |
Rep 83
Thank you all for the advice !
changed sparks (wanted to change anyway) and nothing happened, ordered a new knock sensor from my dealer and installing this week, hope limps will be gone forever. It happens even on stock and even in 3rd (even during city runs, never before !), before was rare and happened in 4th or 5th just in WOT conditions. I get also some other codes (DPfix v3 set to 11(max) !!! ) 2F6C: 2F6C Exhaust fumeflap, input signal Error will not cause a warning light Error is currently present Test conditions have been completed Timeout Freeze Frame Information Odometer 23704kms 14728miles Speed 64.00 km/h time since start end 972.80 s pedal sensor 1 18.36 % voltage Kl. 87 13.81 V 2E69: 2E69 Knock sensor signal 2 Error will not cause a warning light Error is currently present Test conditions have been completed Freeze Frame Information Odometer 23712kms 14733miles Engine speed 3,488.00 rpm air mass measured 176.00 kg/h voltage knock values cylinder 6 0.27 V voltage knock values cylinder 4 0.27 V 3100: 3100 boost-pressure control, deactivation Error will not cause a warning light Error is currently present Test conditions have been completed I know 3100 means the limp mode and 2F6C it might be from golf tee "mod". Everytime I get this code just for cyl 4 & 6, it might be also triggered by the air mass or just voltage ? I have my meth installed already, turbo upgrade and LSD ordered and can not move on because of this fckn sensor or whatever it is ....
08-30-2010, 09:01 AM | #19 |
88
Rep 870
I called my service advisor and left him a voicemail. I guess I did take the car in and they fixed it. I'll let you know when they call me back.
08-30-2010, 09:48 AM | #20 |
Rep 83
reverence
08-30-2010, 10:27 AM | #21 |
88
Rep 870
Ok, after a couple of voicemails and finally staying on hold for a while, i talked to the guy.
They replaced both my knock sensors and cleared the codes. My knock sensors were bad. Problem fixed.
08-30-2010, 05:12 PM | #22 |
Rep 83
Thank you so much, I ordered just one for the time being.
Have a beer on me !
